Old Dec 14, 2011, 11:27 PM
Team White Llama!
gundamnitpete's Avatar
Mini-Review
Fat Shark Predator Review - All in one for $270!
Hey guys, here's a quick video review of the new Fatshark Predators from Hobbyking. It should answer any questions you have, if not just ask and i'll try to fill you in.
Fat Shark Predator Review (15 min 0 sec)
Predator includes:
- Predator VGA headset with integrated head tracking and 5.8G receiver.
- Zipper carry case
- Head tracker data cable (for Turnigy 9X)
- AV cable (for connecting to external AV devices viewing/recording)
- 5.8G 3dBi antenna
- 700mAh 7.4V battery pack with RC charger leads (charged via standard RC chargers)
- Adapter plug for headset battery connector to XT60
- Manual
Specifications:
- FOV 25 degree diagonal, full color VGA resolution LCD display
- Interpupillary distance: 63.5mm fixed
- NTSC/PAL auto select (interlaced)
- Magnetic, inertial, gyro head tracker
- -85dBm 5.8G 7 channel receiver
- Battery: 700mAh, 7.4V
- Power consumption @ 7.4V: 140mA/290mA (wire/wireless)
You can get yours here:
http://www.hobbyking.com/hobbyking/s...et_System.html
hope this helps!
gundamnitpete is offline Find More Posts by gundamnitpete
Team White Llama!
Reserved for 2.4ghz mod.
Old Dec 15, 2011, 02:44 AM
Joined Jun 2010
i wonder how they are compared to the Dominators
nabazul is offline Find More Posts by nabazul
Old Dec 15, 2011, 02:52 AM
jsullivan05's Avatar
Near Saint Louis MO. (IL Side)
Joined Aug 2009
Very nice review pete, I'm actually recommending this entire setup to a friend of mine that wants to get into RC and FPV specifically. You just can't beat the price of that thing. I have Dominators, Headplays, a cheap set of goggles I bought from ebay, and an LCD. If I could have started with this kit I think I would have found FPV WAY more enjoyable in the beginning.
jsullivan05 is offline Find More Posts by jsullivan05
Old Dec 15, 2011, 07:41 AM
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Use Permabond 105 - difficult rubbers adhesive to fix the eyecup issue. Better than epoxy.
Great review. I love the animations
-Alex
IBCrazy is offline Find More Posts by IBCrazy
Old Dec 15, 2011, 08:31 AM
wallaguest1's Avatar
Joined Nov 2006
no one got the predators and the foxtech ones? i wonder how they compare each other in terms of image quality. I like the more compact design and all "buil it" design of the foxtech ones, but i wonder if the FS are better in video qulity
wallaguest1 is offline Find More Posts by wallaguest1
Old Dec 15, 2011, 08:47 AM
Team White Llama!
definitely. I wish they were out when i first started. I used to put a 19" tube TV in my trunk
-Alex
thanks Alex! i'll add that suggestion in the annotations.
well, the foxtechs are $450, and the predators are $270, so not exactly an apples to apples comparison as the preds are nearly half as much. A fully loaded set of dominators would prolly be a better match.
Old Dec 15, 2011, 08:48 AM
Team White Llama!
the screen size difference between the preds and bases is about 180%. The differnce between the preds and doms is about 115%, so they'll be closer to the doms than the bases.
hey Fatshark, if you are reading....
*hint hint*
Old Dec 15, 2011, 09:00 AM
Joined Mar 2006
gundam good review pete, thanks.
scrape is offline Find More Posts by scrape
Old Dec 15, 2011, 11:27 AM
Team White Llama!
^ nice little pun there ^
thanks scrape, glad you liked it.
Old Dec 15, 2011, 12:12 PM
Post # 20 million
Kev.au's Avatar
Joined Aug 2009
Have you tested the head tracker?, that's the only reason i'm holding off from buying a set.
Nice review btw.
Kev.au is offline Find More Posts by Kev.au
Old Dec 15, 2011, 12:40 PM
Team White Llama!
Nice review btw.
Give me a few days Kev, I'm setting up a pan tilt just for the head tracker. That said, it's fatshark so I'm not anticipating any problems.
Once I've got it going, I'll post a flight vid/mini review. Thanks!
Old Dec 15, 2011, 05:58 PM
Joined Nov 2006
why predators with HT and receiver got a price of 270$
and dominators, without any rx, and ht, got a price of 299$ ?
Old Dec 15, 2011, 06:05 PM
Team White Llama!
I don't have the dominators to compare myself, but from what i understand the Kopin LCD's in the doms have closer pixel spacing, so you can get a bigger FOV with less pixel appearance.
If picture quality is your #1 concern, the dominators should have the best of the bunch, not saying either the bases or the preds have a bad image.
hope that helps
Old Dec 18, 2011, 03:43 PM
Team White Llama!
sorry for the bump fellas, but it's been brought to my attention that these DO have an AV out.
previously i have stated they didnt, so i just wanted to correct that
video of the 2.4 mod is coming soon, again sorry for the bump!
New Product 6DOF 10DOF 11DOF IMU All In ONE+ MCU and ALL in ONE II with GPS and sensors CSG_EU Multirotor Talk 115 May 28, 2013 12:46 PM
Discussion Do Fat Shark goggles have diopter lens slots? MikeSSS FPV Talk 8 Jan 14, 2013 09:20 AM
Discussion fat shark predator goggle eye pieces yzguy FPV Talk 8 Jan 12, 2012 10:27 PM
Sold NEW Fat Shark Base RCV922 Goggles for sale! Voguna FPV Equipment (FS/W) 3 Sep 14, 2011 03:22 PM
Discussion Does the wired fat shark have head tracking? Windrider1345 FPV Talk 3 Jul 04, 2011 10:02 AM
