Old Dec 11, 2014, 04:38 PM
Joined Jun 2009
What does the vang do and how?
Can anyone explain the function of the vang? Should it be tightened to keep the boom from lifting? Should it be loose enough to allow the boom to lift? What should the "normal" "start" position/adjustment? I understand the vang is for putting "twist" in the mainsail, but I just cant seem to grasp the concept.
Please help this confused newbie out.
Rider/Writer is offline Find More Posts by Rider/Writer
Old Dec 11, 2014, 04:53 PM
United States, MO, St. Louis
Joined Jan 2014
It simply pulls down on the back of the boom and "Controls" twist/tightness of the leech. With no vang the back of the boom would go way up in a breeze and the leech would blow open.
It isn't hooked to the back of the boom but since the front of the boom does not move up or down when the vang is shortened it pulls down on the back. As long as it is over 45 degrees to the boom it tries to pull down and forward but as mentioned the front can't move so the back comes down. You can have a solid rod type vang that pushes up as well and some boats use that to open the leech in light air. Or something as simple as string that only pulls down.
The Enigma is offline Find More Posts by The Enigma
Old Dec 11, 2014, 05:33 PM
Joined Jul 2011
For the vang to work properly it is important that your mainsheet only controls the position of your boom off of the centreline.
If your main sheet is pulling the boom down any appreciable ammount that could be causing your confusion.
If tihs is happening your vang would have little or no effect, it being overriden by the mainsheet.
Psychosis is offline Find More Posts by Psychosis
Old Dec 11, 2014, 06:24 PM
AA5BY's Avatar
East Texas
Joined Aug 2007
The vang is not used when working to weather or close hauled. It is used on a broad reach and off wind and as noted to pull the boom down and reduce sail twist when the mainsheet is payed out.
The vang is also not used in heavy air, because one wants the ability to quickly twist the mains'l and dump air to avoid becoming overpowered and broaching. The boat is probably near hull speed anyway and thus the vang has no great value compared to a lot of liability
In light to moderate air, the vang is critical to good performance off wind.
AA5BY is online now Find More Posts by AA5BY
Old Dec 12, 2014, 10:51 AM
Joined Jul 2011
Maybe I set my boat different from yours but I use the vang to give the correct shape to the mainsail leech when going to windward.
Without it you would be relying on the mainsheet to control the leech, a recipe for a burnt out winch.
Old Dec 12, 2014, 11:05 AM
Don't lie to my dog.
Gregg28's Avatar
United States, DE, Wilmington
Joined Jun 2005
I always use the main sheet to control twist going upwind and the vang for off wind. This gives you the ability to not only have two different twist settings, upwind and downwind, but also some twist adjustment going upwind. This is the reason most big boats have a traveler. It allows you to adjust twist with the sheet and angle of attack with the traveler. If controlling twist with the sheet burns out your winch, you need a bigger winch. Also, vang tension going upwind forces the boom into the gooseneck, which bends the mast which flattens the bottom of the main. Sometimes you want that (heavy wind) but most times you don't.
Gregg28 is online now Find More Posts by Gregg28
Old Dec 12, 2014, 11:30 AM
United States, WA, Port Townsend
Joined Feb 2006
I wonder if it would make an interesting poll, do you use the vang to set upwind shape or downwind shape?
Using the vang upwind seems similar in my mind to setting the mainsheet and playing the traveler on a big boat. Otherwise you can't ease the angle of the main without also opening the leech. I think it's common on many RC boats that the fastest setup is not to have the main boom centered upwind, but a few degrees out.
There is a reason IOMs have a mast ram on the other side of the boom connection.
lhurt is offline Find More Posts by lhurt
Old Dec 12, 2014, 01:29 PM
Joined Jul 2011
RW if you were confused before!!!!!!!!!!!!
Old Dec 12, 2014, 01:33 PM
AA5BY's Avatar
East Texas
Joined Aug 2007
I should clarify that my comments are from a perspective of full size sailing rather than from my limited RC sailing. No doubt the two don't always gehaw.
Old Dec 12, 2014, 02:55 PM
poltergeist's Avatar
Pomona, CA
Joined Apr 2007
I've sailed "big" boats all my life, and model boats for the last 10 years or so. The statement below is totally wrong in my experience. In heavy air downwind, you need the vang to control main twist. Too much twist causes the mainsail to push the masthead to windward, causing oscillations and "broaching" to windward. When reaching, easing the vang can reduce weather helm.
On my models, I use the "rigid" vang to set and maintain twist both upwind and down. I've seen and heard of models with "spring loaded" vangs that allow some twist control upwind with the mainsheet. I'm not convinced they're worth the weight and complexity...but that's just me.
Of course there are also servo controlled vangs in some classes that allow them. Those are probably optimum except for the weight and complexity.
Kevin
C-J #551
[QUOTE=AA5BY;30175800
QUOTE]
poltergeist is offline Find More Posts by poltergeist
Old Dec 12, 2014, 10:05 PM
Big Boats Rule!
boater_dave's Avatar
Wisconsin
Joined Jun 2007
I think everyone is bouncing on different sides of the same idea. The vang controls mainsail twist. Its usefulness varies per the conditions. Gusty verses shifty. And as the sheet brings the boom in those forces may over ride the vang settings. And some boats react differently than others.
I usually set the vang a little looser on gusty days to depower a bit. The boat is big and heavy, so it doesn't squirt out in a puff like an ultralight displacement type (or cat). I can always control the sheet via tx.
Dave
boater_dave is offline Find More Posts by boater_dave
Old Dec 13, 2014, 01:05 PM
Joined Jun 2009
Dear Posters,
While I thank you all for your input on my questions I am now more confused than ever. The opinions given here tend to counterdict each other. I still have no clear understanding of the concept. Should I loosen the adjustment ring on the vang so that the boom flops up and back slightly? How much? Should I tighten the adjustment so that the boom does not move up at all? When should I do either of these adjustments and why? Forgive my ignorance, but I am an old guy and I dont have 20 plus years of RC sailing left to figure this stuff out by trial and error.
Thanks, R/W
Old Dec 13, 2014, 01:54 PM
Gregg28's Avatar
Joined Jun 2005
OK, first, what does the vang do?
The vang primarily pulls the outboard end of the boom down. This increases the length from the head of the sail to the clew, which tightens the leech. A tight leech is called "closed" and puts very little twist in the sail. Easing the vang allows the boom to rise, shortening the distance from the head to the clew, allowing the leech to "open." See picture, two boats, one leech open and one closed.
When do you want the leech open or closed?
Typically, going to weather you want it closed. This allows you to sail closer to the wind or point higher. However, if the boat is overpowered (heeling too much) you may want to open the leech to bleed off some of the heeling force. Also if your speed is down and you want to accelerate quickly, opening the leech gives you more power, but slightly less point.
When you are off the wind, you want the twist to give you more power since you are not interested in sailing close to the wind.
How do you use this?
The easy answer is to trim the vang for the closed leech all of the time. This gets you 90% of the way there, but does not give you the ability to "shift gears," or accelerate quickly when your speed is down. Nor does it allow you to open the leech up when you are off the wind. This is all fine for cruising, but it is not racing fast.
If you adjust the vang for a reach, with some twist, and then use the main sheet to control the leech when you are close hauled you have much more control and flexibility to adjust for conditions.
So, either way is OK, it just depends on what you want to do.
Old Dec 13, 2014, 10:34 PM
Canada, ON, Ottawa
Joined Dec 2007
Thanks Greg28... I am less confused now!!
Cheers;
Eric
racer944 is offline Find More Posts by racer944
Old Dec 14, 2014, 01:36 PM
Will fly for food
davidjensen's Avatar
Bellevue WA,
Joined Dec 2003
Here is another question about the vang. How many use a ridged vang, one that holds the boom from going up or down. Yesterday when I was sailing the new boat the leach of the main was closing too much when pointing and pulling the sheets all the way in. I assume it is due to the vang allowing the boom to lower (closing the leach) with the main sheet. I had to loosen the sheets a little to get some twist back into the main. After reading Greggs reply I guess I'm right where I should be.
davidjensen is offline Find More Posts by davidjensen
Discussion How does Banggood do it? Ohio_Danimal Banggood.com 43 Oct 02, 2014 08:17 AM
Discussion What does the trim system feature do on the devo f4? Dante DAngelo Multirotor Talk 0 Jan 11, 2014 07:05 PM
Discussion What does the trim system feature do on the devo f4? Dante DAngelo Mini Multirotors 0 Jan 11, 2014 07:04 PM
Discussion What Does an ESC Do and How Does It Do It? -Link Please Murocflyer Power Systems 12 Jun 19, 2009 02:15 PM
Vang!?! We don't need no stinkin Vang! Do I? lost&confused Sailboats 8 Sep 19, 2004 12:43 PM
