Old Mar 02, 2002, 12:57 PM
define("BEASTMODE", "1");
KeithLuneau's Avatar
United States, LA, Moreauville
Joined Jan 2002
Question
Anyone ever cover the bottom of a MiniMax's wings?
I tried this with my Tigetmoth once, and did fly faster and more agile, but it became underpowered with the stock DX-A. Now that I've got my MiniMax, with a little more power, I was considering trying it again, but I'd like to hear from someone else who's tried it.
Thanks for the help,
Keith
KeithLuneau is offline Find More Posts by KeithLuneau
Old Mar 02, 2002, 08:34 PM
Goin' Vertical
Tigger's Avatar
Salem, OR
Joined Nov 2001
Spaulding has...
So Slow,
Look at the bottom post on this page for more info. My gearbox is giving me fits so I haven't tried it yet. Spaulding says it really speeded things up.
tIgGeR
Tigger is offline Find More Posts by Tigger
Old Mar 03, 2002, 07:40 PM
Goin' Vertical
Tigger's Avatar
Salem, OR
Joined Nov 2001
I DID IT!
I covered the bottom of a spare wing set with Aluminum Foil today. I just got it as tight as I could and overlapped the top of the wing about 1" all around. I didn't have much cling so I just taped the edges to the top of the wing.
Flight test...
Had to retrim abit of up but she flew away nicely.
Didn't note any major speed increase but felt it flew a bit faster..maybe 25% in dives and 10% in level flight. Turns were crisper with no washout. Loops were tighter. Was able to do a 3/4 outside loop and pull off a 1/2 rudder roll from inverted.
It's makes a quicker nimbler plane w/o sacrificing the forgiviness that all Mini Max pilots have grown to love.
This was will an 8cell pack. Your mileage may vary.
tIgGeR
Old Mar 03, 2002, 10:11 PM
Joined Jan 2002
Hey tigger, sounds fun. If the damned weather would ever clear up here, I'll try it. I'm probably going to use Reynolds Wrap. Could you pull off any inverted flight?
Keith
Old Mar 03, 2002, 10:23 PM
Goin' Vertical
Tigger's Avatar
Salem, OR
Joined Nov 2001
Inverted Mini Max
Keith,
I was able to fly inverted and actually rudder roll upright. Without the mod I always had to perform the deadly inverted half loop to get level. Removing the camber of the airfoil definitely makes inverted flight a little safer.
tIgGeR
P.S. Please give yourself at least 100' of altitude before trying this.
Old Mar 03, 2002, 10:31 PM
White Knuckle Flier
_AC_'s Avatar
Spokane Valley, WA
Joined Feb 2002
Re: I DID IT!
Did you really use Aluminum Foil?
_AC_ is offline Find More Posts by _AC_
Old Mar 03, 2002, 11:55 PM
Goin' Vertical
Tigger's Avatar
Salem, OR
Joined Nov 2001
Re: Aluminum Foil
"Did you really use Aluminum Foil?"
Yep. Seemed to work fine.
tIgGeR
Old Mar 04, 2002, 12:30 AM
White Knuckle Flier
_AC_'s Avatar
Spokane Valley, WA
Joined Feb 2002
I thought people were using plastic wrap to cover their wings... but I guess aluminum foil isn't all that heavy.
Glad to hear it works!
Old Mar 05, 2002, 09:36 PM
Goin' Vertical
Tigger's Avatar
Salem, OR
Joined Nov 2001
Aluminum Wing Cover
On a sunny day it really makes the plane shine!
That's a spare wing so I can go stock in seconds.
tIgGeR
Old Mar 05, 2002, 09:52 PM
San Diego, CA, USA
Joined Aug 2000
Mini-Max to Crazy Max upgrade
You could always buy the Craxy-Max wing and another servo...
$12 at Hobby-people.net. You'd probably need a larger motor, Graupner Speed 300 (370 type motor) fits the stock gearbox.
3m-77 thinned with naptha and painted on with a q-tip will glue reynold's wrap extremely well... The stuff also shrinks with a hairdryer...
Spam is offline Find More Posts by Spam
Anyone ever use this site's chatroom? himszy Submarines 0 Aug 17, 2005 07:09 PM
Question Has anyone ever used Blue Bird's ESC's? Airborne 2007 Electric Plane Talk 1 Jul 04, 2004 02:28 PM
Micro-Glider West Wings Swallow--Has anyone ever delt with this model? 525cj Scratchbuilt Indoor and Micro Models 2 Mar 31, 2003 08:31 AM
Question Anyone ever cover the underside of a TM wing? KeithLuneau Parkflyers 3 Feb 11, 2002 07:17 PM
Anyone ever cut theirown Zagi type foam wings? slowflyer Foamies (Kits) 5 Jun 23, 2001 01:07 AM
