Old Jul 16, 2014, 11:28 AM
Extreme Sports's Avatar
South Africa, GP, Johannesburg
Joined May 2012
Shaping pool noodles to form fuselages
Pool noodles make great SPAD fuselages, especially for flying wings or pushers (since they tend to be a bit flexible, I have not yet tried using one in a tractor application). They are cheap, light, easy to construct and double up as a shock absorber.
The nose can be shaped by carving as one would do for any other foam, but the finish tends to be less than smooth. I have heard of folks using a clothes iron to shape EPP, and I assume this could also work for pool noodles - the catch being that the iron is not going to be much use for ironing clothes again
I use a slightly different technique that seems to work well, even for quite complex shapes (i.e. F16 fuselage). The trick is to cut the profile you want on the INSIDE of the noodle and then pinch the resulting 'wedge' together and glue with contact adhesive. This keeps the nice smooth surface finish of the original noodle intact. I usually just do the cutting by eye, but you could use a paper template to be a bit more precise. As with everything, practice makes perfect and its definitely worth practicing on some scraps before cutting your first nose.
Once again, hopefully a schematic and some pictures will make this technique a bit clearer.
Extreme Sports is offline Find More Posts by Extreme Sports
Old Jul 16, 2014, 01:12 PM
Crash Test Dummy
Brunei, Brunei-Muara, Masin
Joined Nov 2013
Use a Teflon iron shield, you can slip it off when you're done and your iron remains pristine.
They are only a few bucks.
http://www.amazon.co.uk/HQ-UNIVERSAL...m/B000PK31XI/2
immike is offline Find More Posts by immike
Old Jul 16, 2014, 04:23 PM
Australia, ACT, Canberra
Joined Feb 2013
Thanks ES. SO simple yet effective!
pzanni is offline Find More Posts by pzanni
Build Log Peanut Miles Sparrowhawk build testing Vac Forming Depron Cutting Techniques agricola1 Scratchbuilt Indoor and Micro Models 27 Jul 14, 2013 11:12 AM
Discussion Best building techniques for a newbie? ennobee Scratchbuilt Indoor and Micro Models 5 Apr 08, 2013 03:19 PM
Discussion Building Technique Questions. highnpressurized Balsa Builders 7 Mar 12, 2013 06:24 PM
Advanced Covering Techniques with Solite jreed Electric Plane Talk 22 Aug 07, 2003 07:55 AM
