Old Oct 02, 2011, 06:18 PM
Marietta GA.
Joined Jan 2011
StykerF27Q with 6xI setup help
Guys, I just got this thing and I can`t get it set up correctly..I have elevon selected in the menu. I had it hooked up per the DX6 and PZ manual with the R. aileron in the elev port and the L. in the aileron port..this would not work even if I tried to reverse the servos in the transmitter..I had to swap the two aileron plugs around now it works and I flew it like this but my throws are not even..my right servo moves more than the left by about 4mm..my end points are all set a 100 as well as my trim and subtrim at 0...any ideas? thx..Jason
mazjag is offline Find More Posts by mazjag
Old Oct 02, 2011, 06:45 PM
Joined May 2011
I believe this is the best way to do it:
http://www.rcgroups.com/forums/showp...2&postcount=35
PepeM is offline Find More Posts by PepeM
Old Oct 02, 2011, 10:06 PM
Marietta GA.
Joined Jan 2011
hey thanks, I`ll try that..a lot of the guys at the club were messing with my transmitter with no luck..They said the DX6 has its limitations...
Old Oct 04, 2011, 05:25 PM
Marietta GA.
Joined Jan 2011
I tried that and it works like a champ..thanks again.. now i need to work on my hand launch as I got bit by the thing, but not that bad..
Discussion Need help with futaba fx30 and jeti tu2 setup hexa Radios 1 Sep 18, 2011 11:40 AM
Discussion apprentice with futaba 7c setup help first plane bigemike Parkflyers 1 Sep 13, 2011 09:55 PM
Discussion I can setup heli but need help with Plane Lompma Beginner Training Area (Aircraft-Electric) 1 Sep 04, 2011 06:51 AM
Discussion I am having serious issues with my Spektrum 6xi taekwondo Radios 2 Dec 25, 2008 05:46 PM
Discussion Problem with Horizon Hobbies and Spektrum 6xi taekwondo Electric Plane Talk 15 May 07, 2008 08:17 PM
