Old Aug 05, 2015, 09:53 PM
scottishslayer is offline
Find More Posts by scottishslayer
scottishslayer's Avatar
Australia
Joined May 2008
ZMR250 FPV Range non existent, SE Melb.
Hi there, this question has been asked a million times with a million different answers, so hopefully you can find an answer for me.
I have a pretty standard ZMR250 setup, and it flies great LOS, but the range on my FPV system is about 30-50 meters at best which has resulted in a few broken props.
To rule out any interference from the quad, I have completely removed the FPV system and have been testing it as a standalone unit. My setup is as follows:
- RC832 600mw receiver
- Have tried both 600mw TS832 and Aomway 200mw vtx's with almost no change in range.
- Range is seemingly unaffected by using either the stock whip antennas or the two different sets of matched CP antennas I have tried. Nothing of great quality CP antenna-wise, but I assume even with the whips in a straight LOS i should get more than 30-50m.
My receiver is powered by a 3s 1050mah, which also powers my Quanum V2 goggles. I also tried a larger battery to make sure everything was getting enough voltage.
Both the receiver and transmitter are getting 11-12.5V depending on the battery's state of charge.
All the antenna fittings match up correctly.
Finally, I made an LC Filter and put it on, with no change.
I haven't tried any other form of receiver as I'm doing this alone and don't know anyone else that can help me out. I'm in the East/South East suburbs of Melbourne if there are any locals willing to help!
I hope someone can point me in the right direction as its my first go at FPV and after putting a lot of work in to my first quad build it's been a pretty disheartening experience.
Thanks in advance
Craig
scottishslayer is offline Find More Posts by scottishslayer
Old Aug 05, 2015, 09:59 PM
6KillaBC is offline
Find More Posts by 6KillaBC
DareDevil
6KillaBC's Avatar
Australia, VIC, Windsor
Joined Jul 2015
I wish i could help you, i'm in sth east also, the other guys will help you i'm sure, and then maybe come along to the next Melbourne meet. The guys are great to talk to and have a wealth of experience mate, all the best! : )
6KillaBC is offline Find More Posts by 6KillaBC
Old Aug 05, 2015, 10:10 PM
rocketnz is offline
Find More Posts by rocketnz
Australia, NSW, North Bondi
Joined Apr 2013
your channels do not match. There is alot of confusion around this as the diagrams are probably showing the switches as black and white and the real switch could be blakc or white.
move all dip switches to extremes on both RX and TX, if you get no video, move the RX switches to the other extreme, you should get video.
range check.
rocketnz is offline Find More Posts by rocketnz
Old Aug 05, 2015, 10:30 PM
Australia
Joined May 2008
The TS832 and RC832 both have an LCD display for channel selection, so those are as simple as making sure both numbers are the same. Thanks for the quick help so far though guys
Old Aug 06, 2015, 04:47 AM
AussieNewbie is offline
Find More Posts by AussieNewbie
A regular at PP
Joined Jan 2013
When you look at the VTX and its antenna, does one of them have a pin in the middle and the
other has a hole?
Similarly, when you look at the VRX and its antenna, does one of them have a pin in the middle and the other has a hole?
AussieNewbie is offline Find More Posts by AussieNewbie
Old Aug 07, 2015, 06:03 AM
custards1 is offline
Find More Posts by custards1
Australia
Joined Nov 2009
did the vtx get turned on without an antenna attached at any point? As that is what can cause this
custards1 is offline Find More Posts by custards1
Old Aug 07, 2015, 09:49 PM
DaZa_AU is offline
Find More Posts by DaZa_AU
Fly it like you stole it!
DaZa_AU's Avatar
Australia, VIC, Melbourne
Joined Feb 2013
Come along to one of our weekly Tuesday night meets and get someone to have a look at your setup. Something doesn't sound right!
Deets on the meets can be found here:
http://www.rcgroups.com/forums/showthread.php?t=2423703
DaZa_AU is offline Find More Posts by DaZa_AU
Old Aug 14, 2015, 04:55 AM
Australia
Joined May 2008
Thanks for the help folks, upgraded to an ImmersionRC Uno v4 and all my problems have disappeared. Don't you just love buying brand new stuff thats faulty?!
I'd love to come to a meet, but I think I'll give myself a bit of time to get my head around everything first. Having a blast so far though!
Cheers
Craig
Sold Synergy E7 non-SE TT Viper39427 Aircraft - Electric - Helis (FS/W) 3 Jul 24, 2014 06:07 PM
Discussion Republican wastes lots of money looking for non existent voter fraud btown2 Life, The Universe, and Politics 5 Dec 18, 2013 10:35 PM
Discussion T-Rex 450 SE v2 FPV : long range low level + looping Serveurperso FPV Talk 17 Mar 14, 2009 05:53 PM
Complaint Please delete trader feedback for non-existent transaction. Doubletap Site Suggestions / Complaints 2 Dec 18, 2007 09:36 PM
Discussion Arguing existence/ non-existence of God. Viper Pilot Life, The Universe, and Politics 43 Aug 03, 2007 09:26 PM
