Old Oct 22, 2014, 08:15 PM
windrnone is offline
Find More Posts by windrnone
lownslow
windrnone's Avatar
United States, FL, Cape Canaveral
Joined Nov 2011
Agreed, I will do it again, the beastX was confusing me, I will try again, I prefer to know it is correct as well..
windrnone is offline Find More Posts by windrnone
Old Oct 24, 2014, 05:48 AM
lownslow
windrnone's Avatar
Joined Nov 2011
OK got it, had to find instructions to set endpoints with beastx and external BEC, all is good now, ...thanks!
Old Nov 04, 2014, 08:08 AM
Clintstone is offline
Find More Posts by Clintstone
Castle Support
Clintstone's Avatar
USA, GA, Statesboro
Joined Oct 2007
http://www.rcgroups.com/forums/showthread.php?t=1649655
Clintstone is offline Find More Posts by Clintstone
Old Dec 01, 2014, 08:17 AM
CaptainElios is offline
Find More Posts by CaptainElios
Flying to help
Joined Apr 2013
Castle ESC 100A near the Servos - help needed
HI,
I would like to know if the Castle ESC 100A was near the cables and the Servos, will it cause any EMI?
Please have a look at the photo, help needed.
CaptainElios is offline Find More Posts by CaptainElios
Old Dec 17, 2014, 02:32 PM
Castle Support
Clintstone's Avatar
USA, GA, Statesboro
Joined Oct 2007
Please email me at clint@castlecreations.com
Please include the photo and please describe in the email the issue you are having.
Thanks very much I am looking forward to hearing from you.
Old Mar 28, 2015, 11:02 PM
capt soap is offline
Find More Posts by capt soap
capt soap's Avatar
dallas tx
Joined Jun 2003
I have a brand new edge 100 lite. Bec is reated at b5 amp. How many miro servoes will thst handle 6-8 ? Lee
capt soap is offline Find More Posts by capt soap
capt soap's Avatar
dallas tx
Joined Jun 2003
I have a brand new edge 100 lite. Bec is reated at 5 amp. How many miro servoes will that handle 6-8 ? Lee
Old Mar 29, 2015, 04:59 AM
RC Man is offline
Find More Posts by RC Man
A man with too many toys
United States
Joined Feb 2001
There is a tremendous variation in servo current requirements depending on your application. Need to know aircraft or helicopter, weight, sport or hard aerobatics, size of the servos (brand and numbers)? Also what servo voltage will you be running the servos?
RC Man is offline Find More Posts by RC Man
Old Mar 29, 2015, 11:51 PM
capt soap's Avatar
dallas tx
Joined Jun 2003
Freewing f-18, 90 mm foamy. Did ok with the stock 85amp for years.... now more amp draw from the motor, 12 blade rotor. will cc100 do ok, or do I need to add the 10 amp serperate cc bec?
Old Apr 01, 2015, 10:18 AM
Castle Support
Clintstone's Avatar
USA, GA, Statesboro
Joined Oct 2007
capt soap - Which 85 did you use?
You can use the internal BEC of the EDGE 100 on the bench and test the servos all at once... after testing you can look at the data log from the ESC and see if the voltage is dropping.
The internal BEC has a peak rating of 5 amps .... what is the current rating on your servos? Thanks very much.
For Sale Two new TowerPro 25 Amp ESCs twinster2 Aircraft - Electric - Power Systems (FS/W) 1 Jan 26, 2013 03:19 PM
Sold 1 New-Power 30a escs. $11.50 shipped conus wyldkrd Aircraft - Electric - Power Systems (FS/W) 2 Jan 18, 2013 10:16 PM
Sold 4 Nearly new "Simonk" Rc Timer 40 amp esc's Navy Jet Mech Aircraft - Electric - Multirotor (FS/W) 3 Jan 18, 2013 09:08 PM
Sold Eflite 60amp esc with bec and switch brand new Eboyles Aircraft - Electric - Power Systems (FS/W) 1 Jan 18, 2013 02:51 PM
Sold Brand New 3DHS 47" Edge 540, with Hacker motor and esc ThomasLee Aircraft - Electric - Airplanes (FS/W) 0 May 24, 2011 01:52 AM
