Old May 06, 2015, 04:34 PM
gonzalo contrera is offline
Find More Posts by gonzalo contrera
gonzalo contreras
gonzalo contrera's Avatar
caracas
Joined Feb 2007
Build Log
Ridge Rat.. ( modified )
Hi
I take one of the old models in box, to start a modified versión. The legendary Ridge Rat, created by Ed Sloblod, i want to change the fuse not with the "box" structure, other more rounded, in fiberglass,
I want to change the wings in foam, in balsa 1/16 skins... the new airfoil for best performance is changed by a HN-483.
Now the plans in PDF, and pics of the "old and classic" original versión.
Regards.
gonzalo contrera is offline Find More Posts by gonzalo contrera
Old May 07, 2015, 01:26 PM
B.Welwood is offline
Find More Posts by B.Welwood
Always in the Glue
B.Welwood's Avatar
Edmonton, Alberta
Joined Oct 2003
Looks like a fun project you have planned on this design.
There's a few Rats still around, I got one of mine out to the ridge about 6 months ago. Hope to do more flying with it this year.
Ridge Rat (10 min 4 sec)
B.Welwood is offline Find More Posts by B.Welwood
Old May 07, 2015, 06:04 PM
gonzalo contreras
caracas
Joined Feb 2007
the wings..
Hi
Thanks Mr. Welwood for your video and comments, today i start the wings and the skin balsa wood for it.
Now are ready to be joined and make the ailerons.
The pics of the wings, and the airfoil used.
Regards.
Old May 07, 2015, 07:05 PM
Blaise is offline
Find More Posts by Blaise
Blaise's Avatar
Joined Jan 2015
I built my ridge rat in the mid-1980's and am still flying it. It is a lot of fun.
Blaise is offline Find More Posts by Blaise
Old May 07, 2015, 07:33 PM
gonzalo contreras
caracas
Joined Feb 2007
the rat.
Shure Blaise,
It`s funny.. a lot of funny, and my intention is to make my own with more speed and light, tomorrow i put the pics of the plug fuse to make the molds...
The composite fuse is more strong and light.. I`m thinking to make a micro servo to move the rudder, but `m thinking this posibility.
Regards, ( nice cabin in your Rat... )
Old May 08, 2015, 12:28 AM
chip.greely is offline
Find More Posts by chip.greely
chip.greely's Avatar
Carlsbad, Ca
Joined Mar 2007
I love the Ridge Rat,...
....and recently acquired an original one that I've got scheduled for rehab.
I had previously kicked around the idea of cutting an EPP version with an updated airfoil, since the constant chord would make it short work for a Hot Wire. Maybe a MH30, HN-1038, S6062 or RG15 airfoil to help reduce the drag.
Your project may just re-ignite that EPP dream
Subscribed
chip.greely is offline Find More Posts by chip.greely
Old May 08, 2015, 10:12 AM
gonzalo contreras
caracas
Joined Feb 2007
Hi Chip, welcome to the thread, is very easy to make the wings... rectangular form with two airfoil pattern at same size.... I see your list of airfoil, about the RG-15 i think it`s the original configuration.
I have the wings and a piece of Wood to make my Ultron.. ( maybe you remember it. )... it`s the next Project after the Rat.
THE FUSE
I Begin the fuse with two sides in balsa, and build the 3 central sections to make the side of the fuse. I fill the interior of the box with isocianate ( two components ) The isocianate are 2 equal parts of chemical liquid and in few minutes it grow to have a strong foam. Its similar than a spary used in construction to fill unions of Wood in houses, Light Brown color.
Ather these step, i separate the two sides of the contour fuse in balsa, and use a lot of knife and sand with 80 grade sandpaper to obtain the base of the fuse, i cover the foam with 1/32 balsa Wood previously plenty of wáter in both sides to obtain the contour, and add a lot of White glue or Titebond glue.
Sand a lot, make the form of the fuse and use fiberglass tissue with poliéster resin to finish the plug.
In Pics the fuse plug before the sand and the bondo filler to obtain a good plug
Old May 10, 2015, 08:21 AM
gonzalo contreras
caracas
Joined Feb 2007
tail zone..
It`s time to start the tail zone, easy to do, the rudder and stab, glue and some kitchen weight to mantain in place...
Regards.
Old May 13, 2015, 07:38 AM
rondavel is offline
Find More Posts by rondavel
United Kingdom, England, Caterham
Joined Jan 2012
Keep going.....
rondavel is offline Find More Posts by rondavel
Old May 13, 2015, 11:16 AM
Carlsbad, Ca
Joined Mar 2007
Originally Posted by gonzalo contrera View Post
..... I see your list of airfoil, about the RG-15 i think it`s the original configuration.
The original looks thicker, much more E374-ish to me.....at least from the drwg
I do remember the Ultron,.....will look forward to see that build, as well
For Sale Ridge Rat bing10 Aircraft - Sailplanes (FS/W) 2 Jul 09, 2014 10:28 AM
Sold NIB Ridge Rat kit gavoss Aircraft - Sailplanes (FS/W) 2 Apr 15, 2014 10:57 AM
Discussion Ridge Rat Plans dmarsh4x4 Slope 2 Mar 04, 2014 01:16 AM
For Sale NIB Ridge Rat kit gavoss Aircraft - Sailplanes (FS/W) 4 Jan 06, 2014 10:42 AM
Sold Ridge Rat soar glider 70,s kit bandit71 Aircraft - Fuel - Airplanes (FS/W) 3 Nov 07, 2013 07:22 PM
