Old May 24, 2015, 05:05 AM
chambo88 is offline
Find More Posts by chambo88
1 can never have 2 many planes
chambo88's Avatar
Australia, QLD, Surfers Paradise
Joined Sep 2011
Help!
home-made edf scratchbuilt jet
hey guys, im new to the whole edf gig and am looking for some words of wisdom to possibly improve thrust and flight performance of a micro edf i have built.
the airframe is based on a eurfighter and weighs 61g auw, the edf system is a home made 26mm 8blade producing about 50-55g thrust at 5a wot.
when im flying the plane it seems to be drastically under-powered and requires a relatively high aoa to stay in the air at max power. I know the cg is right... here is a pic to give an idea.
chambo88 is offline Find More Posts by chambo88
Old May 24, 2015, 01:52 PM
SNice is offline
Find More Posts by SNice
SNice's Avatar
Philadelphia, PA
Joined Aug 2009
Hello! Nice little euro!
I think you answered your own question! You either need more power or a lighter airframe. The power requirements are very different for EDF's. At minimum - I prefer around 1.5:1 thrust to weight for my EDF projects. This will give you some 'pullout' power. Otherwise, once you slow her down, she will sit in high alpha and it will be impossible to get her out of it. I've been there before! . With your current setup you need speed to keep her in the air. A bungee launch may get you there but if you slow down or loose speed changing direction you will end up in WOT high alpha again.
Also, the addition of a thrust cone may improve your performance some but I believe you main issue is lack of power. Check out the scratch built EDF forum - there is a lot of great info on EDF over there.
Good Luck! Happy building & Flying!!!
SNice is offline Find More Posts by SNice
Old May 24, 2015, 06:10 PM
djacob7 is offline
Find More Posts by djacob7
Knife cuts foam like its steel
United States, CA, Fremont
Joined Jan 2009
Seems to me you need to move the CG a bit forward. High AOA means high drag which you don't want. Move the CG a little at a time and see what it does. Looks like you can move the battery a bit forward.
If you can lighten the plane, all the better.
djacob7 is offline Find More Posts by djacob7
Old May 24, 2015, 07:26 PM
kcolraw is online now
Find More Posts by kcolraw
Kcolraw
United States, NC, Asheville
Joined Feb 2015
Perhaps do to the edf being mounted above centerline, thus forcing the nose down? here is a pic of my flying wing I designed with an edf. If the thrust estimate is correct it should be about .9 to one thrust ratio, more than enough o fly.
kcolraw is online now Find More Posts by kcolraw
Old May 25, 2015, 12:20 AM
Rusty-Gunn is offline
Find More Posts by Rusty-Gunn
My plans are in my blog
Rusty-Gunn's Avatar
Kotzebue, Alaska
Joined May 2006
Lighter flies better.
Rusty-Gunn is offline Find More Posts by Rusty-Gunn
Old May 25, 2015, 11:41 PM
djacob7 is offline
Joined Jan 2009
What did you mean by the EDF system is home made?
Old May 26, 2015, 05:36 AM
chambo88 is offline
chambo88's Avatar
Joined Sep 2011
home made as in I designed it and made it at home.. using a 3d modelling program and a 3d printer.
Old May 26, 2015, 06:49 AM
birdofplay is offline
Find More Posts by birdofplay
birdofplay's Avatar
United States, IN, Indianapolis
Joined Dec 2005
Ouch !
Very creative and Innovative , but !!!
Is it going to hold up to the High speeds of EDF use.
The centrifugal forces get pretty taxing for rapidprototyping models IMHO.
Just be careful when testing.
birdofplay is offline Find More Posts by birdofplay
Old May 27, 2015, 01:50 AM
chambo88 is offline
chambo88's Avatar
Joined Sep 2011
Originally Posted by birdofplay View Post
Ouch !
thanks birdofplay
With regards to 3d printed props and such i always spin them up to 200% of max intended rpm..
and the housing has been tested in heavy landings during operation. So it all seems to be strong enough for the moment. As for long term durability, will have to be observed over time.
Trying to be careful
88
Old May 27, 2015, 06:13 AM
birdofplay's Avatar
Joined Dec 2005
That is good to hear and I am amazed.
When I retired 10+ yrs ago all the Rapid Prototype machines made Brittle, unusable
parts for show only. Paint em up and pass em around ( but they were dummies )
Glad to hear things have dramatically changed.
I might even have to get myself a 3D printer set up.
What are you using Printer and Material wise ?
OMG I just looked at your uploads -wow !
How did the 20 blade work out for you ?
Old May 27, 2015, 06:42 AM
chambo88 is offline
chambo88's Avatar
Joined Sep 2011
I am using a flashforge creator dual.. the housing is abs because its stronger and the impeller is pla because its more rigid.. however if it were to come into contact with something at operating speed, well lets just say there would be much left.. the trick with printing impellers, housings and props is the design, is it structurally sound?.. build approach, will the layers assist the strength and balance of the object. Its a project ive been workin on for quite a while and its starting to work out for me. The 20blade does work however the one in the pic was the first version. Needs a slight design mod to balance properly.. also with micro edfs it seems that every gram of thrust is essential. The 20 blade impeller might be better suited to 55mm or larger edfs where a trade of less thrust for increased cool factor is acceptable.
Atm 8 blade is producing the best thrust but this weekend ill have time to tinker with it some more..
You can check the progress out here or on my fb page @ 3d aeroworks
88
Old May 27, 2015, 03:06 PM
TANGOSIERRAROM is offline
Find More Posts by TANGOSIERRAROM
James L
TANGOSIERRAROM's Avatar
Beck Row Mildenhall
Joined Mar 2009
With an edf you need the efflux speed to be relatively high any idea on the efflux speed of your design?
TANGOSIERRAROM is offline Find More Posts by TANGOSIERRAROM
Discussion What foamy edf jet you want made?!? Phantom 463 Foamy EDFs 160 Apr 17, 2015 07:51 PM
Gallery EDF Jet Scratchbuilt | 36.5" Span | Full Fuselage preelude Scratchbuilt EDFs 6 Feb 03, 2014 11:13 PM
Discussion Home made EDF - Twin EDF for airliner NicholasC Power Systems 14 May 06, 2010 09:30 AM
Discussion Home made EDF - Twin EDF for airliner NicholasC Power Systems 3 May 04, 2010 11:46 AM
