Old Jan 02, 2015, 11:45 AM
HuskyDude's Avatar
Canada, BC, Kamloops
Joined Jan 2011
RocHobby Critical Mass on Floats
Thought I'd take my FMS Critical Mass and stick some floats on her. I was going for the Macchi M67
or Supermarine S6B look.
Bought some EPO foam floats from my LHS and adjusted them to the proper length.
I thought the wing area on the C/Mass was a bit small for the weight of the floats. So I added about 2 1/2" to each wing tip and lengthen the wing foil about 1" up front.
Did some initial flight trials. Found her very tail heavy. Will do some weight distribution and report back.
Short vid
Critical Mass on Floats (2 min 32 sec)
HuskyDude is offline Find More Posts by HuskyDude
Old Jan 03, 2015, 06:40 PM
HuskyDude's Avatar
Joined Jan 2011
When I first made the floats to the proper length, I had the steps 1/4"- 3/8" behind the C/G of the OEM wing.
Then I decided to make the wing area bigger. I didn't change the float steps, thought I would get her flying and figure that out later.
Wasn't real happy adding so much lead to the front of the floats, this was the only way to get her to fly properly. Later that night I had a epiphany (a smart-sounding word for realizing you've been practically retarded for quite some time.)
I decided to move the contact points of the floats back, which in turn moved the steps forward closer to the new C/G. The whole float now sat about 3/4" forward from where I had them in the beginning . Now it took less lead up front to balance her. (always a good thing)
Went for another test flight..
Ya!!! Fly's like it's on rails. Just have to wait till spring to try her off of water.
Short vid from today.
Critical Mass on Floats 2 (2 min 37 sec)
Old Jan 05, 2015, 07:15 AM
Addicted and loving it
United States, FL, Orlando
Joined Apr 2007
Very nice. I need to set my Corsair up like that.
billman is offline Find More Posts by billman
Old Jan 05, 2015, 07:42 AM
# Scale is a way of life
scale_only's Avatar
United States, OH, Avon Lake
Joined Apr 2010
looks like fun,, hope it works as well on faster moving water
scale_only is online now Find More Posts by scale_only
Old Jan 05, 2015, 07:21 PM
TripleW's Avatar
Prescott, Arizona
Joined Feb 2010
Nice
Do you have a water rudder?
TripleW is offline Find More Posts by TripleW
Old Jan 05, 2015, 07:42 PM
HuskyDude's Avatar
Joined Jan 2011
Originally Posted by TripleW View Post
Nice
I plan on it... but really not needed or desired off of snow. I'll make some up and post more when I finish off everything. I have more bracing and not sure I'm satisfied with how I have the the floats mounted to the struts. They bend easily.
Old Jan 07, 2015, 10:18 PM
Joined Sep 2014
That is awesome! Great work. Like a modern version of the Macchi M67.
m4rK is offline Find More Posts by m4rK
Old Mar 23, 2015, 12:03 PM
71% of the world is runway . .
Bart83's Avatar
Nederland, ZH, Oostvoorne
Joined Jun 2009
Nice ! looks fast just sitting there
Brt
Bart83 is online now Find More Posts by Bart83
New Product RocHobby/FMS Critical Mass Sea Fury! 1100mm merlinfan Electric Warbirds 2528 Mar 08, 2015 12:17 PM
Discussion Next plane - PZ T-28 or RocHobby Critical Mass? Piilot Beginner Training Area (Aircraft-Electric) 19 Oct 22, 2014 06:29 PM
Discussion Critical Mass/Sea Fury by ROCHobby easyrider604 Parkflyers 26 Apr 03, 2013 02:06 PM
Sold RocHobby Critical Mass Parts $65 dbc Aircraft - Electric - Airplanes (FS/W) 3 Feb 11, 2013 11:17 PM
Discussion Rochobby Critical Mass 2013 otherhalf2 Electric Warbirds 3 Dec 19, 2012 10:05 AM
