This thread is privately moderated by skunkworks2006, who may elect to delete unwanted replies.
Old Mar 19, 2015, 12:38 PM
cheapskate extroardinairé
United States, CA, Marin
Joined Jul 2011
Originally Posted by Blueberry52 View Post
So I was trying to come up with a fvp platform and I think this will do nicely , going to have a 60inch WS , twin motors mounted high on wing ,fuse is 40in and made of foamboard wing will be foamboard also.wing in picture just a stand in for mock up. This is my first pure fvp and suggestions are welcome
love foamboard, a while ago I used it to make two 90" motorgliders that I used for fpv, and they flew beautifully. the first had individually operated ailerons and flaps for wing mixes and would thermal easily even carrying 4 2200mah 3s batts, and with a folding 13x6 prop on the dt750 motor it would fly for over four hours if you could catch a couple of thermals, or about an hour and a half in dead air. second was much lighter and floatier, but with more drag due to a thick symmetrical aerofoil. flew for an hour on two 2200s and was incredibly aerobatic, and flew like it was on rails. it died when I snapped a wing pulling out of a dive, but I still have the heavy model and fly it from time to time. I have a post about the two somewhere in this thread, probably a couple hundred pages back at this point.
I'd recommend doing the wing similarly to the experimentalairlines armin style, but make the spar the way flitetest do (two layers of foamboard, with the paper running vertically so it won't bend.)
also, make sure to brush minwax into the paper! if you don't then the first time you land on wet grass you'll screw up your fuse.
baconflyer is offline Find More Posts by baconflyer
Old Mar 20, 2015, 07:53 AM
Joined Mar 2015
I have made wing its armin type has a forward hardwood spare and rear cf spare, wing has flaps and alirons now I'm working on motor mounts
Blueberry52 is offline Find More Posts by Blueberry52
Old Mar 20, 2015, 09:25 AM
Adekamer's Avatar
Russia, Moscow, g. Moskva
Joined Mar 2005
Originally Posted by bikerboy_id View Post
That is a quadrifilar helical antenna
Yes! it QHA
http://jcoppens.com/ant/qfh/index.en.php
Adekamer is online now Find More Posts by Adekamer
Old Mar 20, 2015, 02:48 PM
United States, MS, Gulfport
Joined Jan 2013
A Quadrifilar antenna? How does it perform? I like to fly right above myself, and I'm usually right in the Fresnel zone under the antenna (Circular polarized 5.8 FatShark)
adamh1281 is offline Find More Posts by adamh1281
Old Mar 20, 2015, 07:44 PM
United States, CA, Marine Corps Base Camp Pendleton
Joined Jan 2013
Not sure for our purposes but I don't see why it wouldn't be great especially compared to stocks. Only thing I've seen these used in are weather balloon radio sonds (the little transmitter that the balloons are meant to carry)
Disp0sablehero is offline Find More Posts by Disp0sablehero
Old Mar 21, 2015, 08:36 AM
Have a nice day! Kristjan
kristjane's Avatar
Slovenia, Novo mesto, Šentjernej
Joined Jan 2006
Originally Posted by kristjane View Post
My FPV plane. 2180mm wingspan, 2250g rtf with 2700mAh 6S lipo, RVOSD V5.1, 3D blackbird FPV camera.
Here is short video from maiden flight
Queen Bee Maiden Flight (1 min 56 sec)
Next time it will be in FPV mode.
kristjane is online now Find More Posts by kristjane
Old Mar 21, 2015, 09:24 AM
RC Guy Having Fun!
Aeronut41's Avatar
Joined Apr 2010
Very stable and smooth! Should be an excellent FPV platform
Aeronut41 is offline Find More Posts by Aeronut41
Old Mar 21, 2015, 03:29 PM
kristjane's Avatar
Joined Jan 2006
That was my goal.
Old Mar 21, 2015, 04:31 PM
Canada, QC, Montreal
Joined Oct 2008
Hi gents
im looking for an EPP cutter pro or private in Canada or USA to realize some projects.
Before to show you the maiden flight, i show you the idea
thanks
mathieu974 is offline Find More Posts by mathieu974
Old Mar 22, 2015, 11:18 AM
Joined Sep 2014
Introducing the Gemini Version 2
SPECIFICATIONS:
WINGSPAN: 3200MM 126 INCHES
WING ASPECT RATIO: 10.77 / 1
​AIRFOIL: HIGH LIFT / NON CRITICAL TYPE MAX CO-EFFECIENT OF LIFT: 1.5
WING AREA: 96,000 CM SQ. OR 1488 INCHES SQ.
AIRFRAME STRUCTURE APPROX WEIGHT: 4 LBS, 9 OZ
EMPTY WEIGHT: 7 LBS
MINIMUM FLYING WEIGHT: 15 LBS / 6.8 KILOS
MAXIMUM GROSS WEIGHT RECOMMENDED: 20.75 LBS / 9.4 KILOS
WING LOADING: 23-32 OZ. -SQ. FT - 71-98 SQ. D.M.
FLIGHT DURATION : APPROX. 3 HRS WITH PAYLOAD
RANGE: AT LEAST 12 KM DISTANCE WITH L.R.S.
DISTANCE: APPROX 120 KM LINEAR WITH PAYLOAD
CRUISING SPEED: 40-70 KM PER HR
STALL SPEED AT MAX GROSS WEIGHT: 22 MPH / 35.4 KM PER HR
CIELING: UNKNOWN, BUT VERY HIGH. 20,000FT +
BEST LOITER SPEED: 42 KM PER HR
BATTERY CAPACITY 50,000MAH 3 CELL LITHIUM POLYMER
AMP DRAW AT 42 KM PER HR: 13 -17 AMPS DEPENDING ON PAYLOAD/BATT.
RECOMMENDED POWER: 2X E-FLITE POWER 15 BRUSHLESS ELECTRIC
RECOMMENDED PROPS: 13.5 X 8 APC THIN ELECTRIC 2 BLADE
RECOMMENDED PROP CONFIGURATION: COUNTER/ROTATING INWARDS
RECOMMENDED SPEED CONTROLLERS: PHOENIX EDGE 50 AMP +
RECOMMENDED SERVOS: HS 225 METAL GEAR TYPE FROM HITEC
FLAPS: DUE TO HIGH LIFT AIRFOIL, NONE ARE NEEDED
FEATURES:
~2 SWAPPABLE PAYLOAD BAYS, 1 LARGE(FOR 2 COMPACT DSLR'S) 1 SMALL FOR CANDY DROP/ OBSERVER CAM/ETC. (BOTH HAVE UNOBSTRUCTED DOWNWARD VIEW OF THE GROUND FOR MAPPING MISSIONS)
~MODULAR 6 PIECE DESIGN - FITS IN THE TRUNK OF A SMALL CAR
~CAN BE ASSEMBLED IN THE FIELD IN ABOUT 10 MINUTES
~EASY TO FLY AND STABLE (EASIER TO FLY THAN MOST TRAINERS)
~LOW PILOT / AUTOPILOT WORK-LOAD DUE TO STABLE DESIGN
~EASY TO BUILD AND REPAIR WITH COMMON HOBBY MATERIALS
~ ROBUST DESIGN IDEAL FOR COMMERCIAL APPLICATIONS
~CAN USE HOBBY GRADE ELECTRONICS
~DESIGN IS SIMPLE, AND LENDS ITSELF TO MODIFICATIONS, AND MULTI-MISSION CONFIGURABLE PAYLOADS
~HARD POINTS ON THE WINGS ALLOW FOR UP TO 4 DIFFERENT PAYLOADS TO BE CARRIED AT THE SAME TIME
~OVERALL LAYOUT IS IDEAL FOR KEEPING SENSITIVE RECIEVERS FAR AWAY FROM THE NOISE PRODUCED BY VIDEO TRANSMITTERS.
~THE COMBINATION OF LOW COST, SIMPLE CONSTRUCTION, LONG RANGE, ENDURANCE, AND WEIGHT LIFTING POTENTIAL ARE UNBEATABLE IN THE WORLD OF SMALL UAV'S!
LASER CUT KITS NOW AVAILABLE!
SEND AN EMAIL TO MY GOOD FRIEND WAYNE FOR PRICES, AND AVAILABILITY OF WING, AND FUSELAGE KITS!
flyingsquirrelmodels@gmail.com
How to get Started Building Your Very Own Gemini Version 2 : easy as 123...
1: Order the Gemini Version 2 PLANS PACKAGE at bearospaceindustries.com (arrives within 24 hrs) Have the appropriate PDF plans printed at your local office supply store in original size. (Plans for the Scratch build version, and kit version are included in the package, depending which you choose to build, along with parts placement diagrams, Tips for setup, and flying, and step-by-step build instructions).
2: Send an EMAIL to Wayne about Pricing and Availability of his LASER CUT KITS: flyingsquirrelmodels@gmail.com
3: Source the remaining hardware online, or from your local Hobby Store! ​
Spike Webb is offline Find More Posts by Spike Webb
Old Mar 25, 2015, 06:14 PM
Artful Owl's Avatar
New Zealand, Canterbury, Christchurch
Joined Dec 2011
Cool design looks to have a low wing loading. Are there flaps? kind of looks like it the photo.
Artful Owl is offline Find More Posts by Artful Owl
Old Mar 29, 2015, 10:23 AM
Certified Power Juicer
Jack_LaLanne's Avatar
Germany, Berlin
Joined Feb 2009
..was airborne before but had no FPV, telemetry
Jack_LaLanne is online now Find More Posts by Jack_LaLanne
Old Mar 29, 2015, 05:22 PM
Joined Mar 2015
Yes she has flap just waiting on more parts to come.......I'll have to order smaller props they r 10-5 I'm thinking 9-5 also gotta make skid of some type to keep props little higher for those belly landings
Old Mar 29, 2015, 10:23 PM
Joined Oct 2011
Home made WW-11 Glider, back from grave after a deadly crash, just to share PG2 Waco WW-II is back again, tuning up for a LR flight soon, I hope.
FPV PG2 WACO Frankie Back Again (3 min 53 sec)
gtlavin56 is offline Find More Posts by gtlavin56
Discussion Show Us your US Navy Ship ! Chophop Life, The Universe, and Politics 80 Feb 23, 2015 12:40 PM
Gallery Show us your plane! (Part 2) skunkworks2006 FPV Aircraft 2585 Dec 09, 2010 11:04 AM
Discussion Show us your fleet. lovegroove FPV Talk 3 Sep 28, 2010 01:42 PM
Gallery Show us your workshop or man cave! TopSecretBoats Racing Boats - Internal Combustion 10 Sep 25, 2010 12:08 PM
Discussion Show Us Your Clumpy Grass Chophop Electric Plane Talk 11 Sep 24, 2010 10:15 PM
