Old Jun 15, 2010, 02:35 PM
The props of tomorrow
Varna , Bulgaria
Joined Feb 2007
New GM Prop
After the GM prop for 5/7 degrees , we decided to build a prop for the +6KW setups.
We used the old GM as a base to develop the new prop.The old prop showed great performance but due to bad design at the root don't survive +4,5kW powers.The latest props for SUSA are reinforced with kevlar and they are strong enough.
The first props let out the mold today.I didn't have enough time to test it today but I hope to test them tomorrow.
The new prop is made to fit the Pils system , as there isn't single problem with these props since one year at powers up to 6 kW.
It will be available with 33 , 36 and 38 mm spinners.It will be sold by Eflight and probably SUSA.Also in private.
The prop is 18x21". It has smaller bend at the root even from the Pils prop.
Pictures attached.
GeorgiMirov is online now Find More Posts by GeorgiMirov
Old Jun 15, 2010, 03:25 PM
Needs to do 52 legs !!
jjmouris's Avatar
Verenigd Koninkrijk, Fareham
Joined Aug 2008
Now you are talking Georgi.
Nice work.
Joe
jjmouris is offline Find More Posts by jjmouris
Old Jun 16, 2010, 09:11 AM
hubbse's Avatar
Stuttgart Germany
Joined Jun 2006
Good and fast job Georgi,
interested in testing results.
Stay in contact
Best
Hubert
hubbse is offline Find More Posts by hubbse
Old Jun 16, 2010, 01:37 PM
la528it's Avatar
United States, WA, Redmond
Joined Dec 2007
GM, what do I need to look out for using your 17x19 prop... does it show any problems at the root prior to failure? I am using on rfm +5, so far I like it a lot, but your statements above make it sound a little unsafe?
la528it is offline Find More Posts by la528it
Old Jun 16, 2010, 03:23 PM
making my own planes...
decones's Avatar
Curitiba - Brazil
Joined Oct 2007
Update us about results when done
decones is offline Find More Posts by decones
Old Jun 16, 2010, 11:29 PM
Boom goes the dynamite!
verticalflight's Avatar
Palo Alto, CA
Joined Dec 2003
Lucky for us Georgi makes better props than his countrymen play soccer
verticalflight is offline Find More Posts by verticalflight
Old Jun 17, 2010, 01:52 AM
hubbse's Avatar
Stuttgart Germany
Joined Jun 2006
Hy Georgi,
which diameter has the pivot/pin for the blade...3mm or 3,12mm?
BR
Hubert
Old Jun 17, 2010, 06:08 AM
Varna , Bulgaria
Joined Feb 2007
Yesterday the weather stopped me to fly the new prop but I made a static tests.
Props was turned at 6kW 3 times.It stayed on the hub
Pictures of how it folds to the Enigma fuse + power / voltage graph.
@ Hubbse - same as the pils prop.
@ la528it - I was using this prop in powers in the range of 4,7kW over 10 flights without problems.I know also other flyers using it without a problem.
Since now I have only 2 totally broken props and one cracked from this type.
GM 16x18 is also not advised to use over 5 kW.
Old Jun 17, 2010, 06:23 AM
jjmouris's Avatar
Joined Aug 2008
Looks good Georgi.
Would you consider making hubs with the collet to fit original Sergey blades?
So we could have a Georgi Hub / Sergey Banana prop.
Joe
Old Jun 17, 2010, 06:33 AM
Varna , Bulgaria
Joined Feb 2007
No Joe ,
You can have Georgi hub / Georgi prop
I see no sense of what you're asking.Neither Sergey sells props only.
Old Jun 17, 2010, 09:04 AM
JWS
More power !!!!
JWS's Avatar
Zwolle, Netherlands
Joined Aug 2002
Hi Georgi,
How can i order one by you?
Jw
JWS is offline Find More Posts by JWS
Old Jun 17, 2010, 09:09 AM
Varna , Bulgaria
Joined Feb 2007
@ georgimirov@abv.bg
Old Jun 18, 2010, 03:55 AM
JWS
More power !!!!
JWS's Avatar
Zwolle, Netherlands
Joined Aug 2002
Hi Georgi,
You've got mail.
Janwillem
Old Sep 26, 2010, 12:28 AM
Australia
Joined Dec 2004
I have been flying this 18x21 prop since returning from Muncie. Had to trim it 1/4" to fit Surprise 16. Setup Neu 1512/1.5D, CC180, 6s 3300 Hyperion. 6400w peak power, still pulling 4500w at switch off. I am impressed, but now I have to get used to even shorter motor run times.
mikehi is offline Find More Posts by mikehi
Old Sep 26, 2010, 12:58 AM
la528it's Avatar
Joined Dec 2007
had you tried the 17.5x17.5 pils before? Any comment on the difference?
Discussion New GM prop GeorgiMirov High Performance 53 Jan 25, 2010 12:00 PM
Discussion 1.7 gm Digital Servo, 100 gm thrust on 1 lipo! scharlach Scratchbuilt Indoor and Micro Models 2 Jan 14, 2010 04:00 PM
For Sale Brushless, Light 16 inch EPP Goliath kit W/ 19 gm CD Rom and Prop Choice ----ON SALE sylair Aircraft - Electric - Airplanes (FS/W) 3 Dec 20, 2009 12:08 PM
For Sale 22 inch EPP wing Kit w/3000kv, 24 gm brushless motor, APC Prop, can be FAST, ON SALE sylair Aircraft - Electric - Airplanes (FS/W) 2 Nov 27, 2009 04:14 PM
For Sale Frenzee 27 in. Flying Wing Kit, EPP Cores, 24 gm Brushless Motor, mount, prop sylair Aircraft - Electric - Airplanes (FS/W) 4 Nov 11, 2009 02:40 PM
