Old Mar 14, 2009, 04:35 PM
john in ny is offline
Find More Posts by john in ny
Joined May 2005
pipe dream II
hi guys i like to konw what u thing of this wing. it call PIPE DREAM II . this was design bye Bill Winter the wing span was 41 inches. i resized it to 32 inches. i have a eflite 400 on it with a 9x5 prop. i have a electrifly 1500
11.1v batt.
john in ny is offline Find More Posts by john in ny
Old May 11, 2009, 06:22 AM
Donato75 is offline
Find More Posts by Donato75
Joined Oct 2006
It looks quite a bit different in the nose section from the original, besides the central servos and linkage which is supposed to be inside the fuse.
Donato75 is offline Find More Posts by Donato75
Old May 11, 2009, 09:22 PM
Jimmi is offline
Find More Posts by Jimmi
Jimmi's Avatar
Los Angeles Area
Joined Dec 2005
I like it, how well does it fly? etc?
Jimmi is offline Find More Posts by Jimmi
Old May 12, 2009, 08:35 AM
wingnutt is offline
Find More Posts by wingnutt
Will work for foam
wingnutt's Avatar
United States, WI, Muskego
Joined Apr 2005
is that a KF airfoil? i too would like to know how it flies.
wingnutt is offline Find More Posts by wingnutt
Old May 12, 2009, 01:57 PM
Donato75 is offline
Joined Oct 2006
I am building a 120 cm span (47").
I totally redrew the plans over and scaled it up from 106cm (original).
I am cutting my pieces with my cnc router.
Everything is going to be according to plan, airfoil, folding propeller etc.
This is what the original looked like in the air.
and the second picture is the fuse parts that I am cutting out.
Old May 14, 2009, 07:42 AM
Donato75 is offline
Joined Oct 2006
Costruction is underway:
Old May 14, 2009, 12:06 PM
Joined May 2005
she flys very fast and turn on a dime. i know it a little different but ie was for ease of install.
Old May 14, 2009, 12:40 PM
Donato75 is offline
Joined Oct 2006
That is good, those are the traits that the author already described. Good to know that the results are repeatable. Is it stable with no dihedral?
I am gonna use it as a slope-thermal-power glider hybrid plane, so I will use some dihedral.
Old May 14, 2009, 02:58 PM
Joined May 2005
yes it is very stable with no dihedral and with the kf airfoil. im very happy it it. that sounds great good luck with it.
Old May 16, 2009, 12:47 PM
Donato75 is offline
Joined Oct 2006
Construction continues, I am 80% done on the fuse, then I will start cutting the foam core.
Here are a couple pictures.
Old May 16, 2009, 08:23 PM
Joined May 2005
wow nice work. you helper did i nice job. ha ha ha. it look great
Old May 17, 2009, 01:37 AM
Donato75 is offline
Joined Oct 2006
Thanks John,
For motor I was tempted to cut the firewall in order to mount a 1000kv 150gram outrunner, which is great for a 11x8 prop. at 32 amps on 3s, and if I wanted decent speed I would put a 10x10 and have 90MPH pitch speed and some 80oz static thrust (on a 33 oz plane ). Instead I looked in the old stuff bin and found a speed400 with a in-line mp-jet 3.33/1 gearbox which will be fine on the 11x8 folder but at less then half the power of the aforementioned brushless. In fact the amps on 3 s should be like 16 and we know that the efficiency of the speed 400 is sad, so I am looking at 52-53% efficiency. Still I fly mostly on a slope that's 5 minutes from my house, and for speed I have a couple pylon racers. This will be a soft flyer, to fly with the local falcons and hawks. I am pretty sure with its slick design that It will go much faster with the motor off then with the motor on. I will video the maiden when all is done.
Old May 18, 2009, 04:26 AM
Donato75 is offline
Joined Oct 2006
Here are the latest pictures, before sheeting the wing.
I will put just a little dihedral to make it more stable in thermals, at hight, when you can't really see the model, and it's just a speck in the sky.
I will round the nose perfectly, so it will look much more streamlined.
Here is an overview....
Old May 18, 2009, 04:23 PM
Joined May 2005
the wings came out nice what did u use to cut them out. she is looking good. i think i will have to make a nother one ha ha. but i think my wife will get mad if i start a nother plane and not finish the kitchen.
Old May 19, 2009, 02:04 AM
Donato75 is offline
Joined Oct 2006
I understand your pain, wives will be wives... I got one also, I am 33, but been married for 9 years already, she helps me keep my feet on the ground.... when I am flying in my head.
For the cores, I cut the hot wire templates out of aircraft grade 3mm ply, and hot wired it. The first one didn't come out too well, and that's the left core, but it's still usable, filling with some light speckling, and the right one came out much better with almost no visible grooves.
I guess , like all things, if you practice they get better and better. I should have cut a third half wing, but had no staerofoam left.
Now I will be skinning with 1mm balsa e fiberglassing the center.
Discussion Pipe Dream Ranfred Radius Scale Sailplanes 12 Apr 07, 2008 01:52 PM
Sold Byron Pipe Dream NO REASONABLE OFFER REFUSED! jhicks Aircraft - Fuel - Airplanes (FS/W) 16 May 23, 2006 08:28 PM
Sold Byron Pipe Dream Make offer Local pick-up jhicks Aircraft - Fuel - Airplanes (FS/W) 5 May 16, 2006 07:07 PM
For Sale Byron Original Pipe Dream Reduced to $200 jhicks Aircraft - Fuel - Airplanes (FS/W) 2 Apr 03, 2006 06:03 AM
Talking Tx: Pipe Dream? fumblethumbs Electric Plane Talk 13 Jan 18, 2003 07:07 PM
