Old Nov 03, 2015, 02:38 PM
bogbeagle is offline
Find More Posts by bogbeagle
Joined Mar 2007
Making some lightweight floats.
I have a vintage model which I've a mind to put on the water.
It has a glow engine, but I'll swap that out for electric ... 'cos of the noise-sensitive site from which I intend to fly.
But, I need to make some floats.
I fancy using some blue foam, with a couple of wooden hardpoints let in, to facilitate the mounting. However, I'd like to apply a finish to the foam, such that it can be painted.
How do you chaps approach the problem of covering or sealing blue foam? Looking for simple and light of weight.
bogbeagle is offline Find More Posts by bogbeagle
Old Nov 03, 2015, 03:09 PM
scale_only is offline
Find More Posts by scale_only
# Scale is a way of life
scale_only's Avatar
United States, OH, Avon Lake
Joined Apr 2010
Light cloth and water based polyurethane or epoxy.
look here for how I made these if you like
http://www.rcuniverse.com/forum/seap...er-set-up.html
scale_only is offline Find More Posts by scale_only
Old Nov 03, 2015, 03:22 PM
Joined Mar 2007
The polyurethane stuff didn't seem to work too well.
I could get some thin epoxy ... I have loads of cloth, somewhere.
That old-fashioned float design is exactly what I'm aiming to use on my own model.
Old Nov 04, 2015, 05:09 AM
scale_only's Avatar
Joined Apr 2010
That post in the thread is misleading,, It worked OK,, just not with the latex paint over it, if I had given it more time to full cure, then the latex paint probably would have bonded correctly. Epoxy dries/cures faster for sure.
good luck
Old Nov 22, 2015, 06:17 PM
jonesymj is online now
Find More Posts by jonesymj
Slopeosapien
jonesymj's Avatar
Joined Jun 2006
Bogbeagle: scale_only is right... Water based polyurethane over glass cloth works wonderfully. It doesn't cure quite as hard as Epoxy, but very close. And it cleans up with water, and the fumes don't p!$$ off the wife lol. I have the same thing on the float/hulls of all my waterplanes... Food for thought
jonesymj is online now Find More Posts by jonesymj
Discussion Which Drone for footage over the sea? Expensive vs. cheap? And how to make it float? Ashantiashanti Multirotor Talk 8 May 13, 2015 11:28 PM
Discussion Making lightweight pull-pull systems? compressor man Foamies (Scratchbuilt) 19 Jun 23, 2014 07:00 PM
Sold Lightweight 230mm carbon fiber quad frame and some poorman carbonfiber frame plates 318wagner Aircraft - Electric - Multirotor (FS/W) 4 Apr 29, 2014 10:27 AM
For Sale Sony DSC-WX50 16.2MP Camera, Very Lightweight, Make an offer wattflyer6161 Non R/C Items (FS/W) 0 Jan 17, 2014 05:54 PM
Discussion Can anyone make me a micro 5mm counter rotating motor? Brushed ?? Lightweight lw_hughes Electric Motor Design and Construction 1 Jan 04, 2014 11:21 PM
