Old Aug 27, 2013, 06:12 PM
United States, FL, Miami
Joined Jun 2013
Genesis cat build
Just want to share my genesis upgrade build will be using the stock genesis motor on my sons miss geico 24 which has a 3650 castle motor in it just received a leopard 3674 1900kv for the genesis quality looks amazing i should be receiving my ose 3/16 drive parts to convert my 4mm shaft on the genesis and a octura x440 props. I will also be reinforcing motor mounts with fiber.... Any suggestions are welcomed. Enjoy
nemz305 is offline Find More Posts by nemz305
Old Aug 28, 2013, 12:41 PM
Australia, VIC, Blackburn North
Joined Feb 2011
I honestly don't believe that cooling coil on the Geico is sufficient enough.
Others may not agree with me, but, I like things to run cool.
Get a full jacket for it to save your motor overheating.
Also, if you plan on running that Leopard in your Genesis, you may want to reconsider that also.
Here's mine running on a Leopard 4082 1600kv on 6S spinning an Octura X440/3.
First run of Genesis after rebuild (0 min 0 sec)
mozzyrocks is offline Find More Posts by mozzyrocks
Old Aug 28, 2013, 03:15 PM
Joined Jun 2013
thanks mozzy u think that motors not sufficient im only goin 4s
Old Aug 28, 2013, 06:48 PM
Joined Jun 2013
When i was taking off the strut noticed the the stuffing tube was loose and it slid right out is this normal or should i use some epoxy to keep it in place? Or is it supposed to slide in and out of the hull???
Old Aug 28, 2013, 08:27 PM
cyberhoops's Avatar
Seattle
Joined Feb 2006
I don't think a movable stuffing tube is a good thing.
cyberhoops is offline Find More Posts by cyberhoops
Old Aug 28, 2013, 09:06 PM
Joined Jun 2013
cyberhoop u recommend i use marine epoxy to hold it in place? MOZZY i took your advice and returned the 3674 and ordered the 4082 i didnt even notice the size when i ordered the 3674 looks thinner than the stock one. thanks guy all advice is appreciated
Old Aug 29, 2013, 11:59 AM
Boaters are nice people.
Sneek, Netherlands.
Joined May 2004
Hi nemz305,
If I see it correctly, you have a fluxring from a brushed motor around the can of the brushless motor and put the coil around the fluxring...
Why on earth would you add an extra layer between the can and the coil?
(Most likely to make the coil fit, is my guess.)
The coil is now mainly ornamental.
Please take a camera with you when your son runs the Geico and promise him you'll replace the motor later...
Regards, Jan.
pompebled is offline Find More Posts by pompebled
Old Aug 29, 2013, 08:45 PM
Joined Jun 2013
Some other view of shaft fitted on
Old Aug 29, 2013, 08:54 PM
Joined May 2013
hey nemz305 nice boat , nice mods!
PUGSLY DJI is offline Find More Posts by PUGSLY DJI
Old Aug 29, 2013, 08:58 PM
Joined May 2013
http://www.rctigermotor.com/show.php?contentid=210
Old Aug 29, 2013, 09:00 PM
Joined Jun 2013
Thanks pugsly dji are u into boating? Maybe we can mod
Old Aug 29, 2013, 09:01 PM
Joined May 2013
sure I do boat! and quads I currently have a traxxas Spartan runnin 6s
Old Aug 29, 2013, 09:02 PM
Joined May 2013
Check it out!
Old Aug 29, 2013, 09:03 PM
Joined Jun 2013
Cool man i got a quad.. Is your spartan fast?
Discussion c & g of a genesis cat vernon7026 Racing Boats - Electric 15 Oct 04, 2014 07:40 PM
Cool Genesis Cat... HYDROJERRY Racing Boats - Electric 82 Jul 26, 2011 11:55 AM
Yippee! Genesis Cat & Saga Cat Vids F1 madness Racing Boats - Electric 50 Mar 02, 2011 12:57 PM
Discussion Genesis cat or Apparition now future project fighter cat Shannon87 Racing Boats - Electric 47 Feb 21, 2011 11:57 PM
Discussion Genesis Cat questions mitsudriver274 Racing Boats - Electric 14 May 22, 2010 03:03 AM
