Old Jan 24, 2009, 01:30 PM
I can crash real good.
Shreveport, LA
Joined Dec 2008
HPFP Main gear question
Hello, just got though flying my first battery pack. finally realized to get it up off the ground!.. Anyway, amny crashes later, notice the main gear has a little wobble to it now, gonna check the collet as instructed by rudyhal, but if not, does anyone know if this "wobble" is normal or what could cause it? Glad to be here!
poboy62 is offline Find More Posts by poboy62
Old Jan 24, 2009, 01:51 PM
landru's Avatar
Vancouver, Canada
Joined Mar 2003
A little wobble is normal judging from my experience. But make sure that the gear isn't cracked, and that the shaft isn't bent.
landru is offline Find More Posts by landru
Old Jan 24, 2009, 02:59 PM
Shreveport, LA
Joined Dec 2008
I did thanks, took it all apart and as you and rudyhal said, probably normal. I just didn't remember feeling prior to all my crashing and I broke some stuff crashing..lol
Old Jan 24, 2009, 03:46 PM
Victim of C.D.O.
murdnunoc's Avatar
United States, TX, Lubbock
Joined Oct 2007
If it wobbles some in the up and down direction, it's no problem since the distance to the motor gear is still the same.
A significant wobble in the horizontal direction, though, can lead to problems since the gear mesh will be tight at one spot and loose at another. If you do have a little wobble in this plane, set the mesh at the tightest spot. As long as it's not too loose anywhere else, you'll be OK.
And check the main shaft, like Landru said. You can pull the shaft and chuck it in a drill to spot a wobble.
murdnunoc is offline Find More Posts by murdnunoc
Question Main Gear question? kdill2160 Micro Helis 8 Jul 20, 2006 09:53 PM
Discussion Trex Main Gear Question djdaveq Mini Helis 0 Jun 18, 2006 11:37 PM
Help! Main gear question on TRex SkyCaptian Mini Helis 11 Mar 19, 2006 11:01 AM
zoom main gear question jaylad Mini Helis 3 Aug 27, 2004 11:30 AM
Corona Crown & Main Gear Question Orion_V Electric Heli Talk 10 Aug 15, 2003 01:40 PM
