Old May 16, 2014, 12:12 PM
Look, Listen, Learn
United States, TX, Arlington
Joined Sep 2013
Have now drain 6 batteries worth of flights and yes I also am surprise how this thing can still fly. Most defently needs a cf rod from end to end, most of the flex is coming at the servo/wing mount.This is the dt foam(very flexable). And yes to the 1/8 holes, I did not pay attention and put the cheap bamboo rod closer to the center, my mistake. I did laminate the wings with packing tape, so that is probly what is saving them from colapsing. When I get to putting your kit together I will correct those mistakes. Learn as I go.
Timbo383 is offline Find More Posts by Timbo383
Old May 16, 2014, 12:46 PM
CNC Cutter
birdofplay's Avatar
United States, IN, Indianapolis
Joined Dec 2005
Packing tape is wonder stuff on Foamys.
I'd use the CF that is a Blade not a rod or tube.
Vertically aligned in the wings they are like and "I" beam.
6mm depth would still "hide" well. Thickness will depend on your level of paranoia
and budget. Seems like thicker is more expensive.
But HK has some 750 mm long stuff that is economical.
Keep up the good work and take pix as you go.
Best
Bob
Hoosier Cutout Service
Possibly you could also insert some in the Bottom fuse plate to firm up the servo
from getting twisted as well.
birdofplay is offline Find More Posts by birdofplay
Old May 16, 2014, 12:48 PM
Pusher jets rule!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
I keep a stock of 6mm flat CF stick just for things like this. The good thing about flat is that it will conform to a curve unlike rod or tube. I also use it on the bottom of foam for a skid and to protect the foam.
Pat
crxmanpat is offline Find More Posts by crxmanpat
Old May 16, 2014, 12:54 PM
CNC Cutter
birdofplay's Avatar
Joined Dec 2005
Good point Pat ! .
I used that idea on my Harpy with a long curved spar from tip to tip !
I too have several stacks of the stuff for builds myself.
Now that my shop is finally done and ready to use I have accumulated about
two yrs of things that I have been wanting to do .
Must prioritize that list !
L8r
Bob
Old May 16, 2014, 01:40 PM
Pusher jets rule!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
Yeah, I went with a curved wing spar on my latest Berkut mod that is going to get the 6mm flat spar. I still need to get that put together. The other versions flew very well, this one has a few improvements in the design.
Pat
Old May 16, 2014, 05:18 PM
Look, Listen, Learn
Joined Sep 2013
Ok, here's the test flight http://youtu.be/kotkG0iEFXE, Ignore the head bob from the hat cam, transmitter battery was low and was checking it. Also ignore the date and time stamp, I'm too lazy to change it on the camera.
Old May 18, 2014, 02:13 PM
Look, Listen, Learn
Joined Sep 2013
Well, after 15 plus flights, one of the servos decided to do the jitterbug. Had to cut out a small hole to take out the servo screw, use two screwdrivers to pry the wing up off the servo arm and pull out. Cut out a section in the nacelles, pull out the servo and repair a loose solder joint in it and shoved it all back together again. Minimum cosmetic damage. One advantage to two servos vs one. And decided to pull the other wing out and brace them up better, much stiffer now. Forgot to mention before, weight 12.6 oz , 15.3 with battery.
Old Jun 11, 2014, 09:37 PM
Canada, ON, Toronto
Joined May 2013
So my friend built a modified version of this design, and it turned out amazing
And yeaaa I got to fly it!!!
RC F-14 Tomcat (3 min 30 sec)
acebonse is offline Find More Posts by acebonse
Old Jun 12, 2014, 07:15 AM
CNC Cutter
birdofplay's Avatar
Joined Dec 2005
Great job on both the plane and the vid.
Looks like it's flying nicely.
What mods did you do ?
Old Jun 15, 2014, 07:00 PM
Look, Listen, Learn
Joined Sep 2013
looked like rudders were one of the mods.
Old Jun 21, 2014, 11:08 AM
Joined May 2014
id love to have a kit of that :3
svu1376 is offline Find More Posts by svu1376
Old Jun 21, 2014, 01:14 PM
CNC Cutter
birdofplay's Avatar
Joined Dec 2005
Bing or google Hoosier Cutout Service
I sell the foam parts all cut out for you plus the ply Motor mount horns and servo extension.
Build info is all over HERE in this thread.
Best
Bob
Old Jul 22, 2014, 12:34 PM
United States, NC, Mooresville
Joined Feb 2006
Hey Guys,
Here is mine! I chose not to do the prop in slot deal. Battery sits right at the forward part of the hatch.
Rooster433 is offline Find More Posts by Rooster433
Old Jul 22, 2014, 08:15 PM
CNC Cutter
birdofplay's Avatar
Joined Dec 2005
Nice shots
Glad you got 'er done as it hasn't been long since shipment.
What kind of weight did you end up with ?
Best
Bob
Old Jul 23, 2014, 08:50 AM
Joined Feb 2006
I'm at 12.75 oz without a battery. I built it really light with basswood main wing spars and nothing else. Moving the motor rearward didn't' cost me anything in weight maybe the equivalent to two rudders. The pieces in the back are hollow underneath. I can share the DXF's for the parts I added if anyone needs them.
Update for F-14 EDF plan buyers. bipeflyer Electric Ducted Fan Jet Talk 6 Feb 11, 2005 01:10 AM
F-14 Scale EDF Whos kit is it ??? F900 Electric Ducted Fan Jet Talk 6 Dec 07, 2001 08:26 AM
F-14 Tomcat EDF,pictures and questions bipeflyer Electric Ducted Fan Jet Talk 13 Jul 14, 2001 06:10 PM
Great Plane F-14 and Learjet conversions sbarrow Sport Planes 1 Jun 24, 2001 08:00 PM
f-14 center of gravity verus center of lift tony houk Power Systems 5 May 14, 2001 01:48 PM
