Old Jan 20, 2014, 01:37 PM
United States, MA, Tyngsborough
Joined Jan 2013
MultiWii v2.5
I wanted to start a dialog about the MW v2.5 since it's so new. Please start sharing your pictures of wiring and also how you got components to work
kenpappas is offline Find More Posts by kenpappas
Old Jan 21, 2014, 11:03 AM
Joined Jan 2013
Here are some pics of the new MW v2.5 components
Features:
• Small size,35x35mm mounting holes
• 6 PWM input channels for standard receiver or PPM SUM receiver
• Up to 8-axis motor output
• Supported 2-axis gimbal and auto trigger controll
• FTDI/UART port for upload firmware, debug, Bluetooth module or LCD display
• I2C port for extend sensor, I2C LCD/OLED display or I2C-GPS NAV board for GPS and Sonar
• Ultra low noise 3.3V LDO voltage regulator
• ATMega 328P Microcontroller
• MPU6050C 6 axis gyro/accel with Motion Processing Unit
• HMC5883L 3-axis digital magnetometer
• BMP085 digital pressure sensor
• PCA9306DP1 logic level converter
Other
• Dimension: 40mmX40mm
• Height: 11.6mm
• Weight: 9.3g
• Fixing hole spacing: 35mm (It can be changed to 45mm by CRIUS Distribution Board)
• Hole diameter: 3.1mm
Visit Multiwii Website for more detail.
http://www.multiwii.com
CN -06 GPS receiver
◆Features:
•Standalone GPS receiver
•U-blox NEO-6M GPS module
•Build in 18X18mm active GPS antenna
•UART TTL socket
•Rechargeable battery for Backup
◆Other
•Dimension: 22mmX30mm
•Height: 13mm
•Weight:12g/14.4g(include cable)
•Hole diameter: 3mm
I2C-GPS NAV Module
◆Features:
·All GPS data available via the I2C bus to connect to 328P Multiwii FC
·A LED on board show GPS 3D Fix status
·ATMega 328P Microcontroller
·2 Molex 1.25mm 4Pin socket for GPS receiver and FC
·2 port for ISP and FTDI
◆Other
·Dimension: 20mmX30mm
·Height: 5mm
·Weight:2.4g/5g(include cable)
·Hole diameter: 3mm
MWC Multiwii Bluetooth parameter debug module / Bluetooth adapter
◆Features:
·For Multiwii FC Configuration use with Android MultiWiiConfiguration
·UART TTL socket
◆MultiWiiConfiguration function
·Read and Write PID
·Setting switch for AUX1 and AUX2
·Monitor receiver signal and FC output signal
·Monitor All sensors and GPS signal
·Cablibration Magnetometer and Accelerometer
·Save and read profile
◆Default parameter
·Baudrate : 115200
·Module name : CRIUS_BT
·Pair code : 0000
◆Other
·Dimension: 15mmX37.5mm
·Height: 5mm
·Weight:2.2g/3.9g(include cable)
·Hole diameter: 3mm
CRIUS CO-16 OLED Display Module
Features:
- High brightness, self-emission, high contrast ratio
- monochrome 128×64 dot
- 5V I2C interface
- Used for telemetry and debug MultiWii FC.
- Dimension: 27mmX27mm
- Height: 6.5mm
- Weight:3.7g/4.9g(include cable)
FTDI USB-TTL
This is a basic breakout board for the FTDI FT232RL USB to serial IC. The pinout of this board matches the FTDI cable to work with official Arduino and cloned 5V Arduino boards. It can also be used for general serial applications. The major difference with this board is that it brings out the DTR pin as opposed to the RTS pin of the FTDI cable. The DTR pin allows an Arduino target to auto-reset when a new Sketch is downloaded. This is a really nice feature to have and allows a sketch to be downloaded without having to hit the reset button. This board will auto reset any Arduino board that has the reset pin brought out to a 6-pin connector.
Download the manual: MWC Combo Manual
Package Included:
100% Brand New and Full Packing
1x MWC V2.5 SE Flight Control board
1x I2C-GPS NAV Module
1x CN -06 GPS receiver
1x CO-16 OLED Display Module
1x Bluetooth module
1x FTDI USB-TTL
Old Jan 23, 2014, 12:10 PM
Joined Mar 2011
hi,
thats aweome ... MW 2.5 already ??
is it on the git ??
thanks
CH
crazyhorse21 is online now Find More Posts by crazyhorse21
Joined Mar 2011
oh oh you are talkin about the board i guess
Old Jan 23, 2014, 12:20 PM
Joined Jan 2013
I am speaking about the new board and the software you will need to get it working here.
Old Feb 05, 2014, 04:33 PM
Joined Nov 2013
Help
I've got one of these guys that I cant seem to get working. I've set up other multiwii boards in the past with no problems. This guy however, the senors dont seem to be working. I upload the firmware ( have tried all versions ) and when I look at the live data, there is either no data being read from the sensors or its confused and reading all sorts of rubbish. Anyone have any luck with this board? what did you define for it in the code?
codinglife is offline Find More Posts by codinglife
Old Feb 08, 2014, 01:19 PM
Joined Jan 2014
HI guys,
I have this set up and have loaded version 2.1, 2.2 and 2.3 and they have all worked after a bit of playing!
currently using multiwii 2.1 SE 2.0 cant even remember where I had it from!
its a smaller file than recent versions because I kept running out of room. its configured for hex6x with gps, gimbal and screen. I have also tried quad x.
i can provide the config.h files if you want
only thing is to init the screen its pitch up and throttle down and yaw left.
migginsthecat is offline Find More Posts by migginsthecat
Old Feb 21, 2014, 03:41 PM
get to the chopper now !
tsooi's Avatar
The Netherlands, NB, Drunen
Joined Sep 2013
Hello kenpapas is it possible to connect all at the same time ?
  • I2C-GPS NAV Module
  • CN -06 GPS receiver
  • CO-16 OLED Display Module
  • Bluetooth module
Is there a possibility to use a separate BEC not from the ESC ?
Can you put up a link to MWC Combo Manual ?
Bent u het bouwen van een multi rotor met deze opstelling ?
proost Joost
tsooi is online now Find More Posts by tsooi
Latest blog entry: Blackout Mini H
Old Apr 07, 2014, 08:13 PM
It can be fixed!
Yazz's Avatar
United States, NH, Nashua
Joined Mar 2014
I have the board but want to get the GPS board to set up return to home and possible way-points etc. Seams like a cheep alternative to Naza V2 if it was simple to use with little tweaking. I do know I couldn't get my pc on 8.1 to see the FTDI USB interface. I read the board will not work because there isn't 8.1 drivers so I loaded multiwii software on my window 7 machine and it all works. GPS and Bluetooth is another story all together.. Any experts out there???
Yazz is offline Find More Posts by Yazz
Old Apr 09, 2014, 12:37 PM
Joined Jan 2013
Can you connect all at the sametime??
  • Bluetooth module
proost Joost
If you are using the I2C you should disconnect the Bluetooth and vis versa.. Everything else you can leave connected.
Joined Jan 2013
I heard the software will not work with Win8.
Old Apr 09, 2014, 12:38 PM
Joined Jan 2013
Which version of MW software works with MW 2.5
Originally Posted by migginsthecat View Post
HI guys,
I am using the new MW 2.3 software and everything works fine.
Old Apr 11, 2014, 07:40 AM
Joined Apr 2014
HI guys,
Could you please provide the config.h file for the 2.3 version?
mfortu2 is offline Find More Posts by mfortu2
Old Apr 27, 2014, 02:55 AM
Australia, QLD, Cleveland
Joined Nov 2013
Hi Guys,
I'm new to multirotor & just received my X525 kit with Multiwii SE V2.5 controller (clone of Crius).
I downloaded PC Config V2.3 and can see live data from controller. Configurator shows board running V2.2.
My question is how do you change the values shown in green boxes (PID etc)? If I click on one of these values I cannot change it. I can calibrate the ACC & Mag sensors though.
Do I need to be running same version of PC config as board is running i.e. V2.2?
Another query re battery monitoring. I see that battery monitoring can be set in Configurator. Which input would I use on board to achieve this? I'm assuming a voltage divider would be required on analog input as 328 has 5V limit.
Cheers..B
brewski850 is offline Find More Posts by brewski850
Old Apr 30, 2014, 11:35 PM
Joined Nov 2013
Ok I worked out how to do battery monitoring by reading V2.3 sketch.
A3 is the voltage monitoring input . On my Crius SE v2.3 clone there are no pins for A3 but there is a pad marked A3 next to A2.
I connected a wire from this pad and ran to power distribution board. Here you solder a 33K resistor to negative & other end solder to 51K. The other end of 51K goes to positive on dist board. at the junction of these resistors connect to wire going to A3. Run some heatshrink over join and resistors to prevent any shorts.
Now go into sketch & uncomment #define VBAT as well as #define BUZZER.
When you run GUI you will now see live battery voltage displayed so you will have no excuse running your battery too low!
I haven't tried it yet but low voltage alarms are active by default. Try connecting a 5V piezo buzzer to D8 & try it. You can also flash a led on low voltage alarm but will require a 220ohm resistor to limit current.
I'm learning lots just by getting into the Arduino MWC2.3 sketch code. There is tons of stuff you can do just by reading comments & uncommenting some code or even adding your own code.
Cheers...B
Discussion Crius V2 MultiWii issues teohcheesoon Multirotor Electronics 3 Dec 22, 2013 09:52 AM
Sold Multiwii Pro v2 + GPS + BT ++ TheQuestor Aircraft - Electric - Multirotor (FS/W) 2 Nov 21, 2013 05:32 AM
Help! Unusual MultiWii setup questions (5,7V to MultiWii???) jokubas Multirotor Electronics 2 Apr 14, 2013 12:17 AM
Discussion Need help with HK multiwii SE v2.0 with v2.1 firmware rahul1991 Multirotor Talk 4 Apr 02, 2013 07:31 AM
Wanted Multiwii V2 or Crius AIOP V2 FTA_FTW Aircraft - Electric - Multirotor (FS/W) 0 Feb 24, 2013 12:50 PM
