Old Jul 14, 2015, 10:03 PM
Waikiwi is offline
Find More Posts by Waikiwi
New Zealand
Joined Jul 2007
Volvo 70
Hi
Has anyone built a Volvo 70 rc yacht? Interested in building one, and have the set of plans of Ericsson from the 2006 race. However, Im struggling to find someone who can print them out as they are too large. Is anyone able to help me transfer them off the pdf so I can print the bulkheads at the correct scale? Currently, there is a whole lot of white useless space on them.
Waikiwi is offline Find More Posts by Waikiwi
Old Jul 15, 2015, 12:57 PM
Ronin055 is offline
Find More Posts by Ronin055
Ah, so its THIS again. . .
Ronin055's Avatar
United States, NV, Sparks
Joined Jan 2013
you probably need someone with a plotter to print them. Here in the US we have a place called Kinkos, and some of them can print that large. Also an office supply chain of stores called Staples. If you have a place like that in NZ, you may be able to get the printing done there.
Also you can try places that print maps.
I hope that helps.
Ronin055 is offline Find More Posts by Ronin055
Old Jul 15, 2015, 11:42 PM
SirHarrisTweed is offline
Find More Posts by SirHarrisTweed
SirHarrisTweed's Avatar
Joined Sep 2014
I did exactly that at a Kinko's recently. They scanned a large set of plans into a PDF, then printed a couple copies in the same size. Cost all of five or ten dollars.
SirHarrisTweed is offline Find More Posts by SirHarrisTweed
Old Jul 16, 2015, 02:05 AM
JerryTodd is online now
Find More Posts by JerryTodd
SCALE Sailor
JerryTodd's Avatar
United States, MD, Severna Park
Joined Apr 2008
Now, is there a Kiwi version of Office Depot or Kinko's available?
JerryTodd is online now Find More Posts by JerryTodd
Old Jul 16, 2015, 03:49 AM
Rusty Nail is offline
Find More Posts by Rusty Nail
Rusty
Rusty Nail's Avatar
Auckland, New Zealand
Joined Feb 2006
I use a free program called PDF Exchange Editor.
This has many features not on the Adobe Reader the important one here being the ability to print off just whatever part of the plan you want. Get the bulkhead in monitor frame and print off current page only at 100%.
Rusty Nail is offline Find More Posts by Rusty Nail
Old Jul 16, 2015, 11:08 PM
Joined Sep 2014
That's a great point, Rusty Nail. When I printed out the plans to build, I just printed each station on a regular sheet of paper. Doing it at home let me mess with the scaling to get it exactly the right size.
Old Jul 17, 2015, 02:15 AM
Waikiwi is offline
New Zealand
Joined Jul 2007
Thanks guys.
How do I go about it then reducing it to 68.8% of the original?
Old Jul 17, 2015, 05:36 AM
Rusty
Rusty Nail's Avatar
Joined Feb 2006
PDF Exchange Editor has on the print page, options for scaling under custom zoom.
Can set to whole digits only so set to 69%.
Make sure to have a measured value to check against on the printed page in horizontal and vertical.
You would have to cut up your nice large printed plan to make bits so might as well print just those required to stick on the material to cut out.
However remember that large scaling can stuff up your displacement.
Surface area increases as the square of any linear scaling, and volume (displacement/mass) increases as the cube.
Much safer to choose a design that is close to your required size.
Old Jul 18, 2015, 10:45 AM
Joined Sep 2014
I printed out one of the images at 100%, measured a fixed distance (the distance between each station), then calculated what I needed it to be (in my case, 112%, I think). Then I printed again. In the section that allows you to choose Actual Size, Scaled to Fit, etc, I chose Scale and put in 112%. I had to mess around a bit to then get the correct part of the image in the view I was printing.
Another option would be printing one out full size, doing the same calculation, then photocopying it with reduce/enlarge.
Old Jul 18, 2015, 01:33 PM
Waikiwi is offline
New Zealand
Joined Jul 2007
Thanks.. Then how do ou measure how far apart the bulkheads should be when that part of the plan is too large to print in a4 paper? Thanks
Old Jul 21, 2015, 04:52 PM
Waikiwi is offline
New Zealand
Joined Jul 2007
Yippee! Got it working. Thanks so much for that link to the pdf program editor. Now the fun truly begins
Wanted I need an in-depth shop manual '98 Volvo S-70.. epoxyearl Non R/C Items (FS/W) 9 Jun 10, 2014 01:41 PM
Cool Volvo Ocean 65 gpzy Sailboats 14 Apr 02, 2014 12:39 PM
Discussion Hobby Engine 'Life at the Extreme' Volvo Open 70 Class Yacht Boomer1 Sailboats 62 Aug 29, 2011 09:10 AM
Discussion spinnaker for volvo open 70 neilpryde Sailboats 0 Jun 22, 2007 06:11 PM
Discussion building a volvo 70 spillinmyrum Sailboats 5 May 24, 2006 02:10 AM
