Old Jul 30, 2013, 10:40 PM
cate is offline
Find More Posts by cate
United States, TN, Kodak
Joined Jul 2013
Help!
hanger 9 taylor craft
I just built the hanger 9 taylor craft from horizon hobby I went electric I was waoundering if I could get some help on what some good starting points would be for setting up my spectrum dx6i I have always flew RTF planes so I have know idea where to start and the instructions don't say what the seetings should be if somebody will please help me out I would be greatly appriative thanks
cate is offline Find More Posts by cate
Old Jul 31, 2013, 02:23 PM
Nicolene is offline
Find More Posts by Nicolene
Joined Oct 2012
Hi
The only tweek I have made on my t-craft is -40% expo on the elevator and it flies very nice. Maybe it could use some aileron differential like any other high wing, but for the time being, I just coordinate my turns. My tx is a Hitec Aurora 9 by the way, but that shouldnt matter.
Br Nicolai
Nicolene is offline Find More Posts by Nicolene
Old Jul 31, 2013, 09:26 PM
cate is offline
Joined Jul 2013
thanks man so all I need to do is program 40% aleron expo is there anything else like throttle stuff or anything im cluless lol
Old Aug 01, 2013, 03:35 AM
Nicolene is offline
Joined Oct 2012
Not aileron expo... ELEVATOR expo... :-) and remember its -40% (minus not plus) but to be honest, the plane flies very well "out of the box". I have expo on the elevator on all my planes, because i think it makes it easier to do those smooth landings.. so its much more my personal preference than a nessecity.
If I were you I would just make sure that cg is correct... the plane flies very gentle and predictable...
Whats your motor setup?
Old Aug 01, 2013, 08:20 AM
cate is offline
Joined Jul 2013
ok cool thanks and I have the e flight 110 with e flight 80 amp esc with 2 4s 5000 mah 30c e flight batterys
Old Aug 01, 2013, 09:33 AM
Nicolene is offline
Joined Oct 2012
Alright.
Propsize?
Sounds like a good setup albeit a bit tailheavy. Did you add lead to the front?
Old Aug 01, 2013, 09:51 AM
cate is offline
Joined Jul 2013
its a 18 x 8 and I just got the batterys yesterday having to modify the gas tank compartment to make them go in there so I haven't check cg yet
Old Aug 01, 2013, 09:53 AM
cate is offline
Joined Jul 2013
and again thanks a lot man you have helped me out a ton
Old Aug 02, 2013, 05:01 PM
Lardog is offline
Find More Posts by Lardog
ex-noob
Lardog's Avatar
Sammamish, WA, USA
Joined Jan 2010
With Spektrum, you want exactly the opposite. To desensitize the center, you add " + " expo. Adding " - " expo will make it more twitchy.
Lardog is offline Find More Posts by Lardog
Old Aug 02, 2013, 08:25 PM
cate is offline
Joined Jul 2013
ok thanks
Old Aug 03, 2013, 04:17 AM
Nicolene is offline
Joined Oct 2012
Glad you were awake there, lardog, so we didnt make a mistake . Thx!
Old Aug 04, 2013, 12:03 PM
cate is offline
Joined Jul 2013
thanks to both of u its really helped alot
Old Aug 07, 2013, 05:36 PM
WI53072 is offline
Find More Posts by WI53072
United States, WI, Pewaukee
Joined May 2006
It is always a good idea to follow the manufacturer's recommendations when you are setting up your planes control surface throws. Like Nic said, expo is a personal preference. I have found smaller aircraft to be "twitchy". I can't imagine needing -40 or +40 expo on such a large airframe. But again it is a personal preference. Being very familiar with this plane I set mine up per the instructions using nearly 50% aileron differential. This helps the plane track through its turns without adverse yaw. Have you programmed in any aileron differential?
WI53072 is offline Find More Posts by WI53072
Old Aug 09, 2013, 12:20 AM
jseese is offline
Find More Posts by jseese
jseese's Avatar
United States, WI, Delavan
Joined Aug 2012
I am running 20 expo on my Taylorcraft (Spektrum DX8)
jseese is offline Find More Posts by jseese
Old Aug 12, 2013, 06:05 PM
cate is offline
Joined Jul 2013
no I don't know what differential is lol
Discussion Hanger 9 Taylor Craft 26 cc BNF Bigplumbs Scale Fuel Planes 10 Jun 13, 2013 12:18 PM
Sold Hanger 9 Taylor craft 26cc gasser xtremetoyz Aircraft - Fuel - Airplanes (FS/W) 4 Nov 30, 2012 10:51 PM
For Sale Hanger 9 TAYLOR CRAFT FUSELAGE NIB!!! ON E-BAY jodini Aircraft - Fuel - Airplanes (FS/W) 0 Aug 28, 2006 10:48 PM
Hanger 9 Taylor Craft Conversion Dugman Scale Kit/Scratch Built 1 Sep 10, 2005 10:00 PM
Hanger 9 Taylor Craft RTF GeeBeeMan21 Aircraft - Fuel - Airplanes (FS/W) 5 Mar 12, 2004 05:56 PM
