Old May 18, 2015, 07:37 PM
wheelbarrowjack is offline
Find More Posts by wheelbarrowjack
Jarhead
wheelbarrowjack's Avatar
Joined Aug 2011
Originally Posted by dacaur View Post
Yes, you can fly the funcub as a RET. It turns fine with just the rudder (and elevator), though I admit I have never tried an entire flight without touching the ailerons....
I've flown like that just to see. It does fly fine, but there isn't a lot of dihedral, so turns aren't as tight as you might want. I promptly went back to ailerons and flaps.
wheelbarrowjack is offline Find More Posts by wheelbarrowjack
Latest blog entry: Got my 32" Sabre today!
Old May 18, 2015, 09:18 PM
Ken Smith is online now
Find More Posts by Ken Smith
United States, TX, Johnson City
Joined Mar 2005
Good looking plane Globetrottin Sorry you are unhappy with its flying.
Ken
Ken Smith is online now Find More Posts by Ken Smith
Old May 19, 2015, 06:51 AM
Marked is online now
Find More Posts by Marked
Marked's Avatar
United States, FL, Titusville
Joined Jan 2001
Originally Posted by Raften View Post
I think I have seen here that the FC can be flown RE, just want to confirm that. I know,I know but right now it will be a case of 'run what you brung' till I get better stuff.
Get a Flyzone super cub. (Think thats the right company ) 3 channel,great flier on and off water. I have 3 of them,floats,taildragger,nite flier.
Marked is online now Find More Posts by Marked
Old May 19, 2015, 08:45 PM
jhan1 is offline
Find More Posts by jhan1
jhan1's Avatar
Joined Jul 2014
Beefed up my landing gear by copying some others ideas. Used a piece of 3/32 brass rod and attached it by wrapping with wire and then soldering. Finished it off with some shrink wrap. Did 3 quick landings tonight and it seems much nicer
jhan1 is offline Find More Posts by jhan1
Old May 20, 2015, 10:00 AM
wmetcalf is offline
Find More Posts by wmetcalf
wmetcalf's Avatar
United States, NM, Santa Fe
Joined Nov 2009
You may discover that one of the real weak points in this gear is that plastic base. If your landings are not very good, get ready to replace it with wood.
wmetcalf is offline Find More Posts by wmetcalf
Old May 20, 2015, 12:40 PM
jhan1 is offline
jhan1's Avatar
Joined Jul 2014
I'll keep an eye on it and if it looks like shes getting loose I'll replace it. Thanks
Old Yesterday, 07:51 PM
BCSaltchucker is offline
Find More Posts by BCSaltchucker
fly by night
BCSaltchucker's Avatar
Joined Sep 2011
Fun Cub going to war soon. Installed the New Generation Hobbies Laser Combat system for FPV airplanes. http://www.nghobbies.com/cart/index....3#.VWEghE94pHy
OK completed the installation. It was kind of a BIG job. The manuals are cryptic and incomplete.
So far it seems to work, but I can't test the hits and effects, as my buddies are installing their systems still. They are using a Parkzone Sport Cub and a Hobbyzone Supercub.
This is the LED for the pilot - flashes when you fire your gun, and flashes a different way when someone hits you. The effects board then makes your ailerons waggle momentarily so you know you've been hit.
IR sensor is mounted up on a mast. There is a big light array on the tail so opponents and spectators can see when you are firing and when you are hit.
This is the pair of control boards. Need access to the pots for making adjustments to the effects (your ailerons waggle when you get hit). Guns on channel 6, switch to turn off effect on channel 7
The IR 'gun' mounted under the wing.
beefed up the Cub's gear too with hose clamps and gear wire
BCSaltchucker is offline Find More Posts by BCSaltchucker
Discussion Fun Cub sinowace Hitec/Multiplex USA 14 Oct 09, 2011 04:43 PM
Discussion Multiplex Fun Jet at the lake bah7566 FPV Talk 31 Jan 03, 2010 09:19 AM
For Sale Multiplex Fun Jet -- PRICE DROP Toby W Aircraft - Electric - Airplanes (FS/W) 2 Dec 28, 2009 09:51 AM
Video Multiplex Fun Jet FPV set up test bah7566 Electric Plane Talk 0 Dec 25, 2009 10:05 PM
Wanted multiplex fun-jet or trade! heli123 Aircraft - Electric - Jets (FS/W) 0 Nov 14, 2009 11:02 AM
