Old Jan 10, 2015, 05:05 PM
Rather Be flying or Tinkering
jtravel's Avatar
Arizona
Joined Aug 2010
Lian Sheng LS-111
Received my Lian Sheng LS-111 from Gearbest that I ordered on Dec 17 yesterday. I ordered one from Dealmachine on Dec 1 and still have not received That one
The Lian Sheng LS-111 I received is a big disappointment after all the positive reviews I read for it. Right out of the box it wants to fly forward at a fast speed. after reading over the manual their is no Gyro/Accel Calibration process. The manual does detail a Remote calibration that I tried and the LS-111 just kept spinning in yaw after I tried that. Resetting the power and connection to the TX and I was back to having the fats forward drift. I used 6 clicks of backward trim to remove most of the forward movement and had it hovering pretty good. forward and back worked ok but as soon as I yawed a little it would want to take off quickly in another direction and is very hard to bring under control again. The Gyro/Accel seem really messed up and without a Calibration option their is not much I can do to make it controllable.
Is anyone else having issue with the LS-111 or did I just receive a Bad one?
Update: Flying stable after performing the Calibration process that is not documented in the manual
jtravel is offline Find More Posts by jtravel
Old Jan 11, 2015, 05:12 AM
BENJAS's Avatar
Mexico, GTO, León
Joined Jul 2011
I ordered one too gearbest, Because of good reviews, although I not receive, I hope To have better luck as you contact customer service?
BENJAS is offline Find More Posts by BENJAS
Old Jan 11, 2015, 05:22 AM
Durete's Avatar
Spain, Community of Madrid
Joined Mar 2008
The Plastic box it came in is nice but the Quad was loose inside the case and not locked in place when I received it. It does not seem to lock in place properly.
I can say without a doubt that this is the worst Nano Quad copter I have ever purchased The WLtoys V272 was my worst experience up till now but this LS-111 takes the worst position now.
Check my reply at this thread:
http://www.rcgroups.com/forums/showt...php?p=30440837
Good luck!
Durete is offline Find More Posts by Durete
Old Jan 11, 2015, 05:44 AM
jtravel's Avatar
Arizona
Joined Aug 2010
Good luck!
Thanks, I followed this process that you posted and it worked
"calibration process for the LS-111/LS-112.
Turn on Quad, turn on transmitter and bind as usual.
Before any throttle input, press left stick down left, and right stick up left.
The leds will start to blink in a dance . Recalibrated!"
Old Jan 11, 2015, 02:41 PM
Durete's Avatar
Joined Mar 2008
Glad it worked for you!
I'm waiting also on the slow boat a LS-111, hopefully works better than the LS-112 . IMHO the LS-112 sucks.
Old Jan 11, 2015, 07:42 PM
Joined Nov 2008
you can cancel the order and get the latest LS123 instead
Edmond
Edmond Y is online now Find More Posts by Edmond Y
Old Jan 11, 2015, 08:01 PM
USA, So.Cal.
Joined Jan 2009
Edmond
Looks like they paired the transmitter from the LS124 with the LS111 quad. Worth paying more for the full sized transmitter.
I got my LS111 from Dealsmachine, but it took a month. Like jtravel, I get a lot of forward drift as well. It's fast and has a incredible yaw rate, but the drift makes it hard to do tight turns. I really don't fly it very often. In fact, ever since I got the UDI U939, both the LS111 and CX-10 are bystanders when it comes to indoor fun flying.
MikeSRC is offline Find More Posts by MikeSRC
Discussion Lian Sheng LS-222 Problem anggawirap Coaxial Helicopters 3 Dec 29, 2014 04:14 PM
Discussion Lian Sheng LS-222 motor problem probably the_cic Coaxial Helicopters 2 Oct 08, 2014 02:30 AM
Help! Lian Sheng LS 222 Helicopter Nik0 Coaxial Helicopters 3 Jun 16, 2013 04:48 AM
