Old Jan 05, 2015, 07:59 PM
Canada, BC, Terrace
Joined Mar 2014
Sports Cub S SAFE Receiver installed in another UMX 4 channel plane
Has anyone taken the SAFE receiver out of a Sports Cub S and installed it in one of the 4 channel UMX planes?
There have been many postings of the SAFE receivers being taken out of the larger planes and re-installed in other planes. A few incidents of some channels needing to be reversed but for the most part new planes are now flying with the SAFE receivers.
Have not heard of instances of people pulling the SAFE receivers out of the small Sports Cub S and installed in other UMX planes?
DonRhone is offline Find More Posts by DonRhone
Old Jan 05, 2015, 08:41 PM
Fly, be free! (splat)
United States, CA, Danville
That should work fine (famous last words) as long as the receiver board can be mounted in the same axis as it is in the cub. There isn't a lot of room inside the P40 so the board is mounted vertically instead of horizontally as it is in most other UM planes. I'm guessing the cub has a horizontal board and that may cause trouble here.
jdwolters is online now Find More Posts by jdwolters
Old Jan 06, 2015, 06:50 AM
Joined Sep 2014
Originally Posted by jdwolters View Post
That is absolutely the best 1S conversion you can do - you need the gearbox. With direct drive you just don't get that performance until you go to 2S, then it goes crazy. We've been waiting a long time for a 1S conversion that works this well and doesn't require custom gear. (ahhhh)
I just wanted to mention that I've played a lot with the AP03 (4000 and 7000Kv) and the AP05 (3000 and 5000Kv) and while there are some interesting combinations, the AP05 3000Kv always comes out way ahead on thrust per watt. That's important with these micro batteries because they can't handle much current for long.
In the P-40, the AP03 4000Kv works well because the stock propeller has such a low pitch. Combine an AP03 4000 with the UMX corsair prop and it works pretty good. (nothing like Valiant's inrunner/gearbox result though)
The AP03 7000Kv is awesome with a big battery but it kills a tiny battery with its large power draw.
thanks for bothering to write such a complete explanation of the subject! Il hve to get hold of the stuff for the inrunner-gearbox mod too! im mainly doing this upgrade to research the equipment i will use for scratchbuilds, so the p40 will be my flying test bed. Again, many thanks for your help!
Buck
darealbuckrogers is offline Find More Posts by darealbuckrogers
Old Jan 07, 2015, 06:48 AM
Dir. of Innovation at Alert 5
Demon 6's Avatar
United States, FL, Fort Lauderdale
Joined Jul 2011
I ordered a GB setup (4:1) from Ebay with a motor rated at 50k rpm (no load) and a micro coreless inrunner (also rated at 50k rpm)... Both ratings at 1S, Lets see what happens
Demon 6 is offline Find More Posts by Demon 6
Old Jan 08, 2015, 06:16 AM
Joined Sep 2014
good luck demon 6. il be interested to see how that works!
Old Jan 08, 2015, 07:40 AM
United States, NC, Charlotte
Joined Jan 2007
Sellers listing?
Tim
w4yn is offline Find More Posts by w4yn
Old Jan 09, 2015, 07:28 PM
Demon 6's Avatar
Joined Jul 2011
Originally Posted by w4yn View Post
Sellers listing?
Tim
http://www.ebay.com/itm/191461125231...%3AMEBIDX%3AIT
http://www.ebay.com/itm/390998158791...%3AMEBIDX%3AIT
Old Jan 10, 2015, 07:47 AM
Joined Jan 2007
OK ordered those now how abt ESC for brushless?
Tim
Old Jan 10, 2015, 04:16 PM
Demon 6's Avatar
Joined Jul 2011
Tim
Those two setups are brushed, so the brick should work just fine inho
Old Jan 10, 2015, 06:38 PM
Joined Jan 2007
OK see that now
Is best setup to use the coreless motor with the gearbox from eBay?
Tim
Old Jan 10, 2015, 07:23 PM
Demon 6's Avatar
Joined Jul 2011
OK see that now
Tim
Not sure... I'm in full experi-"mental" mode....
Old Jan 24, 2015, 07:16 AM
Germany, SH, Lägerdorf
Joined Sep 2014
Flew my P-40 with a Li-Polar mCPX booster. With a single 150mAh battery I can fly it for 2 minutes with the stock motor and the 4 bladed spitfire prop. With a 300mAh battery it flies 3 minutes. With 2 150s in series capped at 4,2V I flew 4 minutes. With the 2 150mAh batteries and additional 2,5g weight of the booster it really climbs good. But I'm still afraid of the hard power off. It can' t carry my 2S 250mAh GPMM0810 batteries. I have serious servo flutter even before activating the AS3X with throttle. I don't like these linear servos. Time for some deoxit when the motor is worn out.
Schugy is offline Find More Posts by Schugy
Old Jan 24, 2015, 08:33 AM
COPENHAGEN DENMARK
Joined Aug 2007
What is a Li-Polar mCPX booster, please.
Forget it i know now, sorry
John
johnkielsen is online now Find More Posts by johnkielsen
E-Flite P-40 Warhawk 300 for Parkzone T-28 Trojan or sell. TheBeastTamer Non R/C Items (FS/W) 4 Jan 03, 2013 12:46 AM
Discussion Ultra Micro Spitfire MK IX with AS3X masonjee Electric Warbirds 8 Oct 22, 2012 05:49 PM
Discussion Great Planes P-40 Warhawk micro servos SohoR1 Fuel Plane Talk 6 Sep 17, 2012 10:10 PM
Sold Parkzone Ultra Micro p-51 RTF $65.00 Shipped -S- Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 2 Apr 11, 2012 12:53 PM
Discussion SBACH342 eflite ultra micro WITH AS3x??? mattijs321 3D Foamies 4 Feb 24, 2012 04:08 PM
