Old Nov 11, 2008, 04:01 AM
jameotron is offline
Find More Posts by jameotron
kids ate my heli budget
jameotron's Avatar
Auckland, New Zealand
Joined Feb 2005
Aeroflyte Aries help (or replacement plans?)
Hi all.
I have, sitting on the floor in front of me, the plans for the Aeroflyte Aries, a 1.6m balsa model, which I found amongst some stuff I got from my Grandfather. Unfortunately the plans don't show the wing sections or the fuse formers. I could probably just fudge it, but I would rather have the originals to work from. I'm wondering if it's even a good idea to build a kit this old for the odd afternoons fun sloping but since I literally have everything I need sitting in old boxes, I thought it might be fun.
If anyone has any suggestions on how to go about building this thing or suggestions of any plans I could download for a similar sort of glider then I would be really happy!
You can see a photo of the kit (Google found it for me): http://www.eganfamily.id.au/Family/G...AeroflyteAries
My camera has packed it in, otherwise I'd take a photo of the plans and post it - I'll see what I can come up with in the next few days.
jameotron is offline Find More Posts by jameotron
Old Nov 11, 2008, 04:37 AM
r/c junkie is offline
Find More Posts by r/c junkie
TEAM OZSKUNKWORX
r/c junkie's Avatar
KORUMBURRA IN THE BOONDOCS
Joined Jan 2006
Geez i remenber the aries that was my second glider after a capella.I reacon i must have been 10years old.I have fonder memories of my capella.Sorry just remanising.Cant help you with a plan.good luck finding one
Shane
r/c junkie is offline Find More Posts by r/c junkie
Old Nov 11, 2008, 05:00 AM
Swoopdown is online now
Find More Posts by Swoopdown
C'mon more Energy
Swoopdown's Avatar
Melbourne, Australia
Joined Mar 2005
Wow thats a blast from the past. I think the Capella, Brolga, Trident era of wing section were Clark Y sections Yes thats right flat bottoms. Im not sure about the Aries but it too was probably flat bottomed. If you want to build it use a modern floater section, if you want to perform like it was intended or if you want a faster slope/thermal job use a RG15 or similar.
Good luck and post pics of your build if you take the build on.
Swoopdown is online now Find More Posts by Swoopdown
Old Nov 11, 2008, 07:16 AM
atmosteve is offline
Find More Posts by atmosteve
Joined Nov 2007
Yeah, that is a timewarp! I had a few of the aeroflyte gliders as a young fella. By memory Swoopdown is right, they were a flat bottom. I have no idea what profile exactly, pretty basic though.
I'm wondering how something like an S7055 might take to the old aeroflyte wing plans, it might make for some relaxed sloping and field lift hunting if pottering around slowly as they used to, is desired.
Steve.
atmosteve is offline Find More Posts by atmosteve
Reply With Quote  (Disabled)
Old Nov 11, 2008, 12:22 PM
jameotron's Avatar
Joined Feb 2005
Thanks guys. Yes the plan shows that it has flat-bottomed wings (they're a hell of a lot easier to build)
Old Nov 11, 2008, 06:09 PM
flybaby2000 is offline
Find More Posts by flybaby2000
Closed Account
Joined Apr 2004
i started on one of these many years ago and if i was to build another id make sure i glassed the arse , as they had a bad tendency of breaking in this area......if your scratching make the fuse formers from lightply , tougher.
that sweep in the centre section always killed me , so i used to block her up and use a straight joiner . others just used the fuse and had a polyhedral wing .. bloody thing flew much better ..
also a great lectric conversion..
cheers
doug
flybaby2000 is offline Find More Posts by flybaby2000
Old Nov 11, 2008, 07:47 PM
steve wenban is offline
Find More Posts by steve wenban
Crikey never leave beer behind
steve wenban's Avatar
Mt Annan Sydney Australia
Joined Dec 2003
Already told you they where all Clark Y sections
SteveW
Opps sorry different thread same subject whats the odds
steve wenban is offline Find More Posts by steve wenban
Old Oct 11, 2010, 09:01 AM
dommack1 is offline
Find More Posts by dommack1
Canberra -Kambah
Joined Oct 2010
Aeroflyte Aries kit
Just found one of these kits in the op shop. attached some pic for reference.
There was NO complete plan, so if anyone has a copy of such, I would appreciate a linl to that resource. Dom.
PS: yes it does have a flat bottomed wing section.
dommack1 is offline Find More Posts by dommack1
Old Oct 11, 2010, 04:15 PM
jameotron's Avatar
Joined Feb 2005
I'll PM you about sending you a photocopy.
Old Oct 18, 2010, 11:14 PM
AUSELECTRIC is offline
Find More Posts by AUSELECTRIC
Joined Nov 2004
I have a plan somewhere, I recommend increasing the size of the rudder to assist you in turns.
AUSELECTRIC is offline Find More Posts by AUSELECTRIC
Old Oct 19, 2010, 05:38 AM
Circlip is offline
Find More Posts by Circlip
Bradford West Yorkshire, UK
Joined Apr 2010
Fuselage looks to be rectangular box, so cross sections are easy to extrapolate (work out).
For more control in turns, reduce dihedral, if you increase rudder size you're going to end up with an all pivoting rudder.
Regards Ian.
Circlip is offline Find More Posts by Circlip
Old Oct 21, 2010, 09:31 AM
Joined Nov 2004
A reduction in dihedral may result in more yaw but will also create less roll for the turn. Adding 10 - 20mm to the width of the rudder has worked on all the airies I have had.
The last one I built has not flown yet (rebuilt about 2 years ago) reduced dihedral and added alirons)
Old Oct 24, 2010, 08:19 PM
Joined Nov 2007
Might penetrate a little better into the wind with a bit less dihedral too.
Old Sep 27, 2011, 08:16 AM
lemuel is offline
Find More Posts by lemuel
Australia, QLD, Brighton
Joined Sep 2006
can I ask for a plan of the aires? I am happy to pay..
lemuel is offline Find More Posts by lemuel
Old Sep 27, 2011, 05:51 PM
Joined Nov 2004
I will have a look when I get home tonight
help needed printing plans AussieParkflyer Parkflyers 4 Jul 30, 2002 01:02 PM
Wanted-Global Cutlass 10 or the plans John Ella Aircraft - Electric - Airplanes (FS/W) 0 Jul 25, 2002 05:04 PM
Ercoupe or Aircoupe plans, kit, ARF? MTrobin Parkflyers 11 May 29, 2002 11:07 AM
Help choosing replacement esc.... WrongwayFeldman Power Systems 1 Apr 18, 2002 10:34 PM
b707 or similar plans needed BioHazard Electric Ducted Fan Jet Talk 9 Feb 16, 2002 01:54 PM
