Old Dec 03, 2014, 03:27 AM
be2kz is offline
Find More Posts by be2kz
Joined May 2014
Question
Wing Spar Length
Hi, what is the typical length of wing spar vs. wingspan? I am going to build twin boom made of 5mm depron, and I am trying to save as much weight as possible. The wingspan will be 1.5m and I will be flying it casual mild acrobatic.
Sorry if my question had been asked before, I tried to find the answer but none so far.
Thanks.
Martin.
be2kz is offline Find More Posts by be2kz
Old Dec 03, 2014, 03:54 AM
nuteman is online now
Find More Posts by nuteman
Joined Apr 2013
A lot depends on the wing planform, wing loading and spar type.
And you inevitably push the limits and end up pulling 6 Gs or more.
If the spar is CF tube, they are so light it doesn't pay to skimp, and I'd go with at least 3/4 of span.
For a tapered wing there's going to be less stress outboard, so the spar can be shorter (like 2/3 of span).
You can even get away with 1/2 of span if you don't mind a bit of "floppy" control feel and are careful not to pull hard Gs.
If you've got extremely light wing loading you can get away with very little spar (or even none).
Having said all that, I just finished a 65 inch (1.65 meters) span rectangular wing with spar of about 60 inches. It's very nice to see that wing not flex at all at any speed/G.
nuteman is online now Find More Posts by nuteman
Old Dec 03, 2014, 11:46 PM
rockin' roller is offline
Find More Posts by rockin' roller
United States, TX, Dallas
When using flat sheet wings, I prefer to run the spar full span, or as close to it as possible while positioning the spar on the projected cg. It seems like the wingtips always get bent over time if the spar ends short. Stress from "rough" landings gets concentrated at the point where the spar ends.
rockin' roller is offline Find More Posts by rockin' roller
Old Dec 05, 2014, 06:40 PM
be2kz is offline
Joined May 2014
Thanks for the inputs, guys. The spar is 2 x 8mm OD cf tube. I will try 3/4 and see how it goes.
Thanks again.
Martin
For Sale 2 glass spar wing kits NIB balsa usa bandit71 Aircraft - Fuel - Airplanes (FS/W) 1 Nov 12, 2014 06:23 AM
Discussion Wing Spar Design SNice Foamies (Scratchbuilt) 15 Nov 04, 2014 04:29 PM
Discussion Foam Core Allegro wing spar wingloada Thermal 2 Oct 07, 2014 08:42 PM
Question Wing Spar.... SayCheeze Beginner Training Area (Fuel) 4 Oct 02, 2014 07:53 PM
Help! radian pkz4700 wing spar length choco711 Electric Sailplanes 1 Jan 13, 2010 06:44 AM
