Old Mar 12, 2014, 10:56 AM
nsarjien is offline
Find More Posts by nsarjien
nsarjien's Avatar
Turkey, Istanbul
Joined Feb 2014
Alert
Boscam RC832 + TS832 Video Out Problem
Hi Everyone,
I recently purchased Boscam RC832 + TS832 combo and couldnt manage to get it working with my Gopro 2.
I tested video out cable directly on lcd and i got video feed perfectly. I made a DIY transmitter lead for gopro and tried to hook it up with vtx/vrx but it didnt work.
I am not very experienced with FPV equipment but i never powered them on without antennas. It should display static or bluescreen but there is no signal warning on LCD.
Do you guys have any idea or suggestions ?
Thanks in advance!
nsarjien is offline Find More Posts by nsarjien
Old Mar 12, 2014, 11:26 AM
joop1987 is offline
Find More Posts by joop1987
United States, NJ, Trenton
Joined Sep 2006
Did you use the resistor on your home made cable?
http://flitetest.com/articles/GoPro3...ideo_Cable_DIY
joop1987 is offline Find More Posts by joop1987
Old Mar 12, 2014, 11:29 AM
nsarjien is offline
nsarjien's Avatar
Turkey, Istanbul
Joined Feb 2014
Thanks for the answer. Mine is Gopro Hero 2 and i am using 2.5mm av output, not the usb one.
I dont think that i need a resistor for that one.
Old Jul 08, 2015, 04:10 PM
tpsmith is offline
Find More Posts by tpsmith
tpsmith's Avatar
Joined Apr 2013
RC832 and video out
I don't know if this has any bearing on your issue, but I have discovered that the video output from my RC832 video receiver will work fine on my goggles (Hobbyking Quanum) but do not work for some reason on both my LCD TV's composite in and my computer monitor with composite in.
Can you test to see if you get signal with a different display in case it is a similar problem? I don't yet know why this would be the case, however, so don't have a solution for you.
Tom
tpsmith is offline Find More Posts by tpsmith
Old Feb 10, 2016, 07:25 AM
Hijinx is offline
Find More Posts by Hijinx
HiJinx
Joined Oct 2015
Help no signal
Hi all
just set up my boscam rc832 reciever and ts832. When powered up it displays frequently and channel on each unit and can be changed to match each other but "no signal " and horizontal snow is displayed on quantum goggle monitor no matter what i try. Connections all seem good. What the heck?
Hijinx is offline Find More Posts by Hijinx
Sold Boscam RC832 5.8g 32chnl Vrx greedyg76 FPV Equipment (FS/W) 3 Mar 10, 2014 06:58 PM
Found Boscam TS832 Vrx mrfliboy FPV Equipment (FS/W) 2 Dec 28, 2013 08:14 PM
Discussion US vs China Diffrences Boscam 5.8g 600mw 32CH FPV AV Tx & Rx Set TS832 and RC832 Fidy$Trainer FPV Equipment 2 Dec 18, 2013 12:54 PM
Sold nib Boscam FPV 5.8 GHz 32CH RC832 Receiver ohsnap FPV Equipment (FS/W) 5 Nov 14, 2013 06:20 PM
Discussion NEW FPV 5.8G TS832 + RC832 32 Channel Wireless Audio/Video System gavenchen FPV Talk 0 Oct 28, 2013 08:36 AM
