Old Jan 25, 2015, 10:32 PM
Spain
Joined Mar 2014
artificial horizon OSD
Hi guys, there is any artificial horizon osd little and light to run into a zmr 250 quad?
i've flip32 on and effio sony cam.
Thanks for advance guys !
Frame75 is offline Find More Posts by Frame75
Old Jan 26, 2015, 03:12 AM
flying ninja!
ican3d's Avatar
Joined Jun 2011
If you get this MinimOSD + Mini APM you'll get AH indicator plus some customization on OSD since its run on open source arduino. Those FC set should fit inside 250 easily.
ican3d is offline Find More Posts by ican3d
Old Jan 26, 2015, 03:15 AM
flying ninja!
ican3d's Avatar
Joined Jun 2011
Else just get MinimOSD and integrated with your flip32 then flash it with KVOSD: http://fpvlab.com/forums/showthread.php?24144-KV-OSD
Old Jan 26, 2015, 05:55 PM
Spain
Joined Mar 2014
Thanks guys so i can just buy a MInimOSD and flash it with a KVOSD !!
Did u know about modification of interface? I mean i dont need so much data in that 250 so i would preferd bigger and detailed AH for example.
More like this
http://api.ning.com/files/qBjysj9can...5Yg__/osd1.jpg
Or like this
http://mikrokopter.altigator.com/ima...t-OSD-view.jpg
Old Jan 26, 2015, 07:50 PM
flying ninja!
ican3d's Avatar
Joined Jun 2011
You can leave it unmodified after flash with KVOSD. Mine running all stock with AH feature default.
Old Jan 26, 2015, 07:57 PM
Spain
Joined Mar 2014
KVSOD AH looks so "tiny" thats why i'am asking about if there is anyway to make it more than those pictures :P
Old Jan 26, 2015, 11:48 PM
flying ninja!
ican3d's Avatar
Joined Jun 2011
You meant the OSD reading is tiny?
Old Jan 27, 2015, 06:27 AM
Spain
Joined Mar 2014
The AH showed in the OSD, is tiny and poor detailed imo, check the picks that i posted as example. i like more them that KVSOD stock AH, thats why im asking about if there is a way to modify it with a detailed and "bigger" AH levers 4 example. Really i just need Speed, alt (if that is possible), voltage and AH mostly.
Thanks!
Old Jan 28, 2015, 03:50 PM
Spain
Joined Mar 2014
i need a FT232RL USB to flash the minimOSD ?????????
Old Jan 28, 2015, 07:52 PM
flying ninja!
ican3d's Avatar
Joined Jun 2011
Here you go, i bought mine here: FT232RL FTDI USB To TTL Serial Converter Adapter Module For Arduino/minimosd
Btw here stock view of MinimOSD. I didn't flash mine. AH looks big enough for me.
Videos:
FPV in the dark - Q450 multirotor (10 min 4 sec)
Old Jan 28, 2015, 08:08 PM
Spain
Joined Mar 2014
Videos:
http://www.youtube.com/watch?v=oiixwGF9z-E
woo LOOKs so nice that AH i though the stock were different...So i'am wrong ! btw that camera is worse than a sony effio 800tvl right? so at night i will see like that or better? or he has some IR leds or something?
Really really THANKS !!!!
Old Jan 28, 2015, 09:06 PM
flying ninja!
ican3d's Avatar
Joined Jun 2011
Its a cheap SONY basic 520TVL CCD from hobby king. Doesn't have IR install.
Sold Dragon Osd + V2 Artificial Horizon, GPS, Current Sensor Johnnymeg FPV Equipment (FS/W) 1 Oct 20, 2013 03:15 AM
Discussion Artificial horizon OSD babanan Aerial Photography 3 Mar 14, 2012 07:19 AM
Discussion dragon osd artificial horizon M4d_D FPV Talk 13 Oct 13, 2011 02:27 AM
Discussion Artificial Horizon input to OSD Mikro Eagle Tree Systems 1 Oct 09, 2011 08:30 AM
Discussion OSD whit level lines? (artificial Horizon) osvaldoljunior FPV Talk 2 Nov 07, 2008 09:35 AM
