Old Feb 05, 2006, 10:47 AM
erich is offline
Find More Posts by erich
erich's Avatar
Holden , Massachusettes
Joined Feb 2004
Build Log
Sagitta XC Build
Am hoping to document and complete a Sagitta XC glider. Purchased a rib set from DreamCatcher before it was sold. So...except for the ribs, all the parts need to be handmade...... oh boy lucky me. This is one Big plane. Span is about 14' with a root chord of 13". Fuselage is 4" longer than my workbench, which is about 52". The whole plane will be built using only wood. Well maybe a little kevlar around joiner area. Have plan only, no manual or directions, except what's on the 3 page plans. So if anyone wants to wade in with advice, am more than willing to listen.
Will probably make a few minor changes over what the plans show. Intend to make fuselage 1/4" longer. Will be making a full height rudder (no balance) which will be 1/2" higher than plans show. Spar will be kevlar wrapped in area of joiner. Joiner tube will be 5" in each wing as opposed to 3" shown on plans. TE will be 1/2" carbon strip laminated between 1/16" balsa sheets, as opposed to the spruce TE, on plans. The tip / main panel, joiners, are shown as 5/16" steel joiner rod, will probably use carbon rod here, although, will still use a steel one for wing / fuselage mating.
Have redone my work bench to accommodate a 13" chord wing. Pinnable work area was only 12" wide. Purchased some great lumber from a place called, National Balsa Co., (which just happens to be 30 miles from my house) so am pretty much ready to go.
Will start, by building the main panel spar. This is built in total with no break in the ply webs from root to wing tip. That's 48" of a 1 1/4" x 3/8" spar. It has 1/16'" ply shears on front and back of spar, which go the full 48". The spar caps are 1/8" spruce which is doubled for 24" on top cap, and doubled for, 18" on bottom cap. Between caps are 3/8" balsa shears.
Have glued the doubled spar caps for both wings, Used Titebond then let sit under weight for a day or two, to make sure glue doesn't warp the wood.
erich
erich is offline Find More Posts by erich
Old Feb 05, 2006, 10:55 AM
oracle_9 is offline
Find More Posts by oracle_9
No drugs to fly high
oracle_9's Avatar
Toronto, Canada
Joined Jan 2004
This will be an interesting build..looking forward to it.
oracle_9 is offline Find More Posts by oracle_9
Old Feb 05, 2006, 04:55 PM
tw126a is offline
Find More Posts by tw126a
Thunder Bay, Canada
Joined Aug 2004
This is great Erich, love following your build threads especially since I have so many of these sailplanes in my hangar. Great reference for when its time to build my Gentle Lady, Olympic II and Mirage. I might not have a Sagitta XC but I'm sure my Sagitta 900 will benefit from this. Your ideas and methods, such as scalloped trailing edges, look like they could be used in many applications. Thanks.
Tom
tw126a is offline Find More Posts by tw126a
Old Feb 05, 2006, 06:20 PM
tw126a is offline
Thunder Bay, Canada
Joined Aug 2004
double post
Old Feb 05, 2006, 06:45 PM
terry.cx is offline
Find More Posts by terry.cx
terry.cx's Avatar
Delaware
Joined Aug 2004
I was just about ready to start mine, when I relized my pinable area wasn't wide enough for the wing cord! Back to Home Depot I go ;^)
Terry
terry.cx is offline Find More Posts by terry.cx
Old Feb 05, 2006, 07:54 PM
erich is offline
erich's Avatar
Joined Feb 2004
Yea, had to cut a 3" wide strip and tape it alongside my "not wide enough 12" wide" ceiling tile area. Had some left over from when I first put down the ceiling tiles. Have built 6 planes on the same tiles. The whole building board is getting pretty ratty looking. Well one more plane, then it'll be time for a new board. Are you building a Sagitta XC or another Windsong? Either one sounds cool to me (can you tell I'm from the sixties).
Made some reductions (40%) of the plans.
erich
Old Feb 05, 2006, 09:26 PM
erich is offline
erich's Avatar
Joined Feb 2004
Making parts
While waiting for spar caps to fully dry, worked on making some of the parts for fuselage. Had full size copies made of the plans at a Kinkos. Also made a 40% copy of fuselage and wing sheets. The smaller size makes it MUCH more convenient to check out plans. On the full size copy, cut out the fuselage side view. Cut this in half, where break is between front 1/8" birch ply and rear 1/8" lite ply, sides. Taped paper template to ply sheet using one of the straight sides to line up with edge of ply sheet (less cutting that way). Cut out with a small scroll saw. Taped & temporarily glued the two forward fuselage halves together. Planed and sanded till sides were as close as possible to plan, and identical to each other. Drilled out holes for front and rear joiner tubes (while sides were taped together). Using ply root rib as template for the holes.
As to photo 3....please don't ask what that big hole just in front of forward joiner hole, is!!
erich
Old Feb 05, 2006, 09:32 PM
balsaaddict is offline
Find More Posts by balsaaddict
Manassas, VA
Joined Dec 2005
Looking forward to the build. Are these plans available commercially?
Enjoyed your Challenger build too. Its a great looking airplane with interesting construction methods. Im from the sixties too, but actually started life in the fifties...
balsaaddict is offline Find More Posts by balsaaddict
Old Feb 05, 2006, 09:38 PM
Ollie is offline
Find More Posts by Ollie
Punta Gorda, FL
Joined Apr 2002
The stock fuselage is very short! You should increase the tail boom by 6".
See:
http://www.qualityfiberglass.net/
"Quality Fiberglass offers an excellent line of both r/c sailplane kits, and r/c power kits."
I'll bet that they have the better fuselage length with the molding tooling XL Sagitta. Ask them to build a better epoxy-glassfabric fuselage from their old tooling.
Check the small tail moment arm and tail areas. This comes from Dr. Mark Drela.
"Ch = (A_hori/A_wing) * (tail_arm/avg_wing_chord)
Cv = (A_vert/A_wing) * (tail_arm/avg_wing_span )
A well-sized tail will be in the range...
Ch = 0.35 - 0.50
Cv = 0.02 - 0.035
If the Ch and/or Cv are below the minimum values, the handling will suffer."
The Sagittas all have problems with the stab mount to the fin. The problem of small music wire jointer rods have high bearing stress in the fin. Eventually the stabs wobble in the fin mounting. The solution is bigger 1/8" diameter and brass tubing nesting (5/32, 3/16, 7/32, 1/4" brass K&S tubing in epoxy) up to 1/4" diameter brass tubing in the fin mounting. Another way is to change the 1/8" music wire with a 3/16" diameter carbon rod jointer.
Ollie is offline Find More Posts by Ollie
Old Feb 05, 2006, 10:03 PM
erich is offline
erich's Avatar
Joined Feb 2004
Ollie
Thanks for the help. And the link to "quality fiberglass" But as to using a fiberglass fuselage...................
One of the main reasons I am building this plane is the wood fuselage. It's my favorite part. Will only work on all fiberglass fuselages if forced to. Have increased the fuselage by a small amount, but not 6 inches. Hey my trunk is only so big. Will be using a bigger dia. stab pivot wire, also longer. May also make stab a little bit thicker. Had a Sagitta 900 which had the wobble in the stabs. Am planning on making fin and rudder 1/2" taller, with a NONE balanced rudder. Appreciate you giving me the proper numbers, but those kinda things just make my head hurt. It's probably wrong most of the time, but I go with the TLAR method. I do however listen to what others have to say. So Ollie, if I do anything too weird, please let me know.
Just measured it, the fuselage is going to be 58" overall (not counting rudder). Please let me know if that's within acceptable limits.
erich
Old Feb 05, 2006, 10:05 PM
erich is offline
erich's Avatar
Joined Feb 2004
balsaddict
I got the plans and ribs from DreamCatcher, which went out of business awhile back. RCM or Flying Models might have plans.
Just checked them both, no plans. Sorry
erich
Old Feb 06, 2006, 01:18 AM
oracle_9 is offline
oracle_9's Avatar
Toronto, Canada
Joined Jan 2004
Just a remember of the Dreamcatcher line of kits to those just in case do not know, but "Aerosphere" company took over, and they will be reproducing the kits. As to when? No one knows, but they will....especially paying $$$ for the rights... so, if you wait a while, then maybe you can get the plans...and kit too.
Old Feb 06, 2006, 03:11 AM
terry.cx is offline
terry.cx's Avatar
Delaware
Joined Aug 2004
erich
Building a Sagitta XC this time.
It's interesting that the Airtronics building instructions for the Cumic Plus noted the thicker stab in this plane as an improvement over the Sagitta stab. I guess I'll have to do that also.
Quality Fiberglass does make a longer f/g fuse for $125.
Terry
Old Feb 06, 2006, 04:55 AM
Ollie is offline
Punta Gorda, FL
Joined Apr 2002
erich,
There is another way. If you don't want to stretch the fuselage 6", you could increase the tail area about 20%. If you do with a stock design, with small tail areas, it fly but it will handle poorly. With a longer fuselage and more tail area, it will fly groovy and, in gusty thermals, it will return to trim quicker.
Without enough tail moment arm and tail area, in the gusty conditions, the porpoising flight is not groovy. It is hard to control the flight smoothly at long range. It increases the pilot's work load on long flights.
Old Feb 06, 2006, 06:32 AM
erich is offline
erich's Avatar
Joined Feb 2004
Ollie
Thanks a bunch. I will increase tail area. Am assuming you mean BOTH H. stab and V.stab + rudder. To re-cap: I need to figure area of H.stab, then increase that by 20% PLUS do the same for the rudder & fin area? Is that what you mean?
erich
Sagitta XC Short Kit $50.00 Delivered Adam Neat Aircraft - Sailplanes (FS/W) 2 Feb 22, 2003 08:41 PM
FS: Sagitta XC Glass Fuse jcstalls Aircraft - Sailplanes (FS/W) 0 Dec 31, 2002 09:59 PM
FS: Sagitta XC kit jcstalls Aircraft - Sailplanes (FS/W) 0 Dec 31, 2002 09:54 PM
Sagitta XC Electric ! 174"! Adam Neat Electric Sailplanes 12 Apr 28, 2002 10:28 AM
