LI, New York, USA
Joined Mar 2003
Tim,
Congratulations on your advancing position in the Big Sky contest. Looking good! There is not going to be much selection for a glass fuse full house electric glider ARF under $200. That is foam and wood country. But we will look around. Fiberglass fuse. Must be glass? Why not wood? Why not carbon or kevlar or plastic? Will you modify a pure glider to make it electric? Consider Spirit Elite http://www3.towerhobbies.com/cgi-bin...?&I=LXAVR0&P=7 Why not foam? Not pushing it, just trying to understand your interests. Radian Pro? Horizon hobby Definately not a kit? That should give you some things to think about. Look for terms like thermal, F5J, LMR, limited motor run, Altitude Limited Electric Soaring or ALES as part of the description. There are all thermal soaring type glider descriptions for electric gliders. Those not containing at least one of these terms might be hotliners or slope gliders. here are some to consider, though perhaps more than you budgeted http://icare-rc.com/avia.htm http://icare-rc.com/magellan_e.htm http://www.soaringusa.com/products/p...ategory_id=267 http://www.soaringusa.com/products/p...ategory_id=267 |
This might fit the bill. It's only 1.9 meters but overall weight and wing loading look good and the price is within your range.
http://www.espritmodel.com/index.asp...D&ProdID=13899 Wayne |
United States, MA, Waltham
Joined Dec 2001
There are other factors besides the wing loading. After all, a Stemme S-10 has a min. sink which must be comparable to many models with 1/12 or 1/15th the wing loading. I realize that's an extreme case. However, all else being equal, the lighter model will probably thermal better, at least on calm days.
I take it Art Hobby stuff is too much work? |
Latest blog entry: pics from Winthrop, MA indoor flying...
Joined Dec 2001
Tim,
Although I haven't made one myself, I know a couple of people who have the Art Hobby JK Thermik and like it. I bet they have an electric equivalent. With today's electric gear, you could probably set up to be light and then use ballast or a heavier battery on windy days. Winds in the teens are pretty heavy. A desirable wing loading depends on more than how windy it is. If the you don't have the ability to reflex the airfoil, the airfoil is an older one, or the glider is larger, or the rest of the glider isn't quite as aerodynamically "clean", you'll want more ballast. If it's smaller or it's "cleaner" and has a thin airfoil, say one of the Drela sections, you won't need or want as much ballast. Because larger gliders can handle more ballast without having a nasty sink rate, they may be a bit easier in the wind. I'd say a desirable range might be 6 to 10 oz. per square foot, but even heavier might be good on a really windy day with a large glider. 10 oz. I had that loading on my old Sagitta 600 (2 meter span), and it was ok even on days when the lift was weak, but if I bobbled it I lost a lot more altitude than a lighter glider might have. You might figure out the loading of your existing glider, consider it as having an "older" airfoil, and use that as a bit of a guide. |
LIncoln - Thanks for your advise - so much to learn!
I did check out the Arthobby site - they have a nice 2M electric. http://www.arthobby.com/index.php?pa...ry=39&item=289 |
Joined Dec 2001
If it was me, I'd be thinking about just a little more span. But that of course depends on the budget. It would cost $60 more.
Holland, Michigan
Joined Dec 2006
ICARE Magellan
I have an Omega 2.5 meter, which was sold in the USA but now only available as the Magellan (same glider) from ICare. It is one of my favorites. I never have a problem thermalling this glider. The carbon kevlar fuselage is quite light, very strong and plenty roomy for gear. This fuselage is far superior to a glass fuselage in my opinion.
I have not flown the 2 meter version. When I first looked at it I thought from the picture it did not have flaps like mine but I believe it actually does. Truthfully, you would be happier moving to a 2.5 meter or larger. Most importantly, they are easier to see. If you take the time to set up the throws and balance according to the instructions it (at least my 2.5) it is very well manored. One wouldn't think so with the almost straight wing but mine is. It flies faster than a rudder elevator only glider, with very small sink. There are in fact two of us in our club with Omegas and both of them climb out on the smallest lift...almost ridiculously easy. They have a 1.8 or 1.5 meter without flap that is okay but not much for floating in lift. By the way these are really good guys at ICARE and if you ask them for recommendations and tell them where you are with experience I expect they will be able to guide you. In fact most of these dealers are pretty helpful. They want you back. Don't be shy about asking them for recomendations ![]() Regards, Larry |
| Thread Tools | |
| Discussion 2M Fiberglass recommendation | gatorlynch | Electric Sailplanes | 7 | Apr 21, 2011 09:38 PM |
| Discussion Another Chrysalis 2M Electric Build | hog2soar | Sailplane Talk | 3 | Mar 31, 2011 08:15 AM |
| Question Recommendation for Electric Motor | ulogix | Glow to Electric Conversions | 7 | Mar 22, 2011 04:26 AM |
| Discussion 2m recommendation | georgeg | Thermal | 11 | Apr 25, 2008 03:35 PM |
