Old Apr 18, 2016, 09:55 AM
oneday is offline
Find More Posts by oneday
Dorset, UK
Joined Jun 2002
EDF powered flying wing.
Anyone know of a flying wing design powered by EDF?
Tony
oneday is offline Find More Posts by oneday
Old Apr 18, 2016, 10:30 PM
yorkiepap is offline
Find More Posts by yorkiepap
yorkiepap's Avatar
SW PA
Joined Aug 2010
There are (2)....one is the Neptune that I have, & the other is the same under a different name, the HK Sonic 64. They fly absolutely superbly & have a great glide ratio & love a breezy day. You need a Tx that has "ELEVON" wing type for proper control. There is a thread(attached below) with many ideas/mods/flights that will certainly enlighten you regarding this great wing. Also, there are some great vids on YouTube if you type in "Neptune RC" in the Search window. Here's a pic & a couple links.
Denny
http://www.motionrc.com/techone-nept...m-edf-jet-pnp/
http://www.hobbyking.com/hobbyking/s...arehouse_.html
http://www.rcgroups.com/forums/showthread.php?t=1691587
yorkiepap is offline Find More Posts by yorkiepap
Old Apr 19, 2016, 04:52 PM
wdac is offline
Find More Posts by wdac
The crazy Swede.....
wdac's Avatar
Sweden, Dalarna County, Falun
Joined Jul 2015
i tryed a small EDF 55mm with a inrunner motor on 4500KV on a small wing with a wingspan of 90cm that i did build in EPP, dident end well
wdac is offline Find More Posts by wdac
Old May 10, 2016, 12:44 PM
Charlie P (NY) is online now
Find More Posts by Charlie P (NY)
Gravity is weak but persistant
Charlie P (NY)'s Avatar
United States, NY, Port Crane
Joined Aug 2009
I have a Sonic 64 and I love it. I added servo arm guards to the underside bit otherwise just plugged in my components and it's been all smiles since. Fun, Fun, Fun.
Charlie P (NY) is online now Find More Posts by Charlie P (NY)
Old May 11, 2016, 10:38 AM
yorkiepap's Avatar
SW PA
Joined Aug 2010
Yes, I did the same & never had any issues with the servo rods getting damaged in any way with grass landings. Easy to make. I also highly recommend to move the ESC just in front of the EDF by simply cutting a bit of foam to seat it & remove the heatsink covering for much better cooling. My ESC never gets hot. Pics attached...
Denny
Old May 11, 2016, 11:15 AM
Joined Aug 2009
I didn't put my ESC outside but I did make a slight cut-out in the cockpit and opened up the canopy air vents a bit for better flow. (Exit hole should be larger than intake scoop). It gets warm but not alarmingly so.
Old May 17, 2016, 07:27 PM
FlyingPaul is offline
Find More Posts by FlyingPaul
Just Do It
FlyingPaul's Avatar
United States, NC, Warsaw
Joined Aug 2015
I've got the Neptune, but haven't built it yet. From what I'm told it's a great flying plane and I cant wait to fl it.
FlyingPaul is offline Find More Posts by FlyingPaul
Old May 17, 2016, 08:34 PM
Joined Aug 2009
You won't be sorry if it is anything like the Sonic. A real pleasure to fly.
Point it into the wind, kill the throttle and then feed in up elevator until it is full up. It settles down level and slow at about a 60 angle . . . at least where I have the C.G. on mine.
That means I can fly about anywhere.
Old May 17, 2016, 08:47 PM
ex-racr is online now
Find More Posts by ex-racr
AKA Terry Till
ex-racr's Avatar
Alexandria, VA
Joined Apr 2002
F-27 Stryker in T-38 Thunderbirds scheme
You can also convert an existing flying wing design too.
But, if you don't want to do that, there is another ready made version in addition to the one listed above:
http://www.rc-castle.com/index.php?r...roduct_id=3417
I modded an F-27 Stryker some years ago, and it's the most enjoyable plane (edf or otherwise) I've ever had.
Fully aerobatic at 1/2 throttle and pretty stress-free flying.
ex-racr is online now Find More Posts by ex-racr
Old May 23, 2016, 12:23 PM
Just Do It
FlyingPaul's Avatar
Joined Aug 2015
I've just finished the build and got the bind done, but gotta make some mods to it so I can fit the ESC , battery and receiver in the little compartment. I'm looking forward to the maiden. Thanks for sharing your pics looks awesome.
Old May 23, 2016, 10:12 PM
yorkiepap's Avatar
SW PA
Joined Aug 2010
Hey Paul,
You can really open the cockpit area for larger batts(I use 2200's) by recessing the Rx into the side of the cockpit wall & moving the ESC outside in front of the EDF for better cooling. Here's a pic of mine...
Denny
Old Jul 04, 2016, 08:35 PM
stevenvaldes112 is offline
Find More Posts by stevenvaldes112
Joined Jul 2016
buying all f-27 stryker
Need a styrker asap 2709457395 I pay good money
stevenvaldes112 is offline Find More Posts by stevenvaldes112
Build Log EDF flying wing vincent123 Balsa Builders 45 Jul 03, 2016 01:31 AM
Sold Neptune Flying Wing EDF bolarobric Aircraft - Electric - Airplanes (FS/W) 4 May 20, 2015 12:45 PM
Discussion EDF flying wing, here we go! jlcortex Flying Wings 17 May 15, 2015 11:33 AM
Question EDF Flying Wing plasoneal Flying Wings 9 Feb 20, 2014 12:39 PM
Sold Hobbyking Phazer KX EDF Jet Flying Wing 860mm EPO xrichierichx Aircraft - Electric - Jets (FS/W) 1 Dec 05, 2013 10:07 AM
