Old Apr 07, 2016, 07:11 PM
Paul Kenney is offline
Find More Posts by Paul Kenney
Paul Kenney's Avatar
Joined Jul 2015
Build Log
Sterling Albatros DIIA
I got started on this a little while ago. One of the old Sterling kits that I had up on my shelf for a long time. It should make a nice electric conversion. I am planning on aileron, rudder and elevator with a 12 amp speed control and 18g brushless outrunner.
Paul Kenney is offline Find More Posts by Paul Kenney
Old Apr 07, 2016, 07:23 PM
Joined Jul 2015
Getting started
These old kits were typically die smashed, but I must have gotten one from an early run when the dies were nice and sharp. I still like to trim the parts with an x-acto #11 before trying to remove from the sheets.
Old Apr 08, 2016, 12:03 AM
HanksGB is online now
Find More Posts by HanksGB
confused poet
HanksGB's Avatar
USA, CA, Orange
Joined Feb 2004
Cool build. I have a set of plans for this kit from a friend.
Good luck
Hank
HanksGB is online now Find More Posts by HanksGB
Old Apr 10, 2016, 08:15 AM
Joined Jul 2015
normal build stuff
More shots of wing and fuselage.
Old Apr 10, 2016, 08:10 PM
lawn darte is offline
Find More Posts by lawn darte
Scale nut!
lawn darte's Avatar
United States, GA, Covington
Joined Apr 2014
Following along. Have a few old sterling kits I've been contemplating doing this to.
lawn darte is offline Find More Posts by lawn darte
Old Apr 11, 2016, 09:26 PM
moscow580 is offline
Find More Posts by moscow580
Is it suppose to do that?
moscow580's Avatar
USA, CT, Waterbury
Joined Sep 2006
Following
Sean
moscow580 is offline Find More Posts by moscow580
Old Apr 12, 2016, 08:16 PM
Joined Jul 2015
aileron controls
I got the idea for the aileron controls from another build. Starting with a couple sketches and fabricating the control horns from stiff paper board then fiber-glassed. The cables will route through the bottom wing passing through guides below the control surface, The servo connects to a control horn for pull pull actuation.
Old Apr 12, 2016, 08:40 PM
WWI_Flying_Ace is offline
Find More Posts by WWI_Flying_Ace
Round engines & two wings...
WWI_Flying_Ace's Avatar
United States, CT, Southbury
Joined Mar 2013
Most Excellent! I also have one of these kits (unopened) on my to do shelf. I will be watching closely and I like what I have seen so far! Are you going to sheet the fuselage? That is one of the things that scares me away from doing an Albatros. Just like painting lozenges has kept me away from a Fokker D VI for 15 years ! (And yes there is a post on the WWI page of my purgatory).
Regards, Brad
WWI_Flying_Ace is offline Find More Posts by WWI_Flying_Ace
Old Apr 13, 2016, 01:57 AM
AntiArf is online now
Find More Posts by AntiArf
AntiArf's Avatar
Joined Feb 2013
Good to see one of these being built, as we don't see them often. Built a number of Sterling kits in recent times. I had this one on the want list forever, but ended up building the Comet DVa, as it's never converted (for some good reasons) but flies well. The proportions make the Albatros D models nice flyers. I used similar gear, with a 12A ESC and 18 gram outrunner. Managed to balance with a sheeted fuse at 11.5oz AUW with forward mounted tail servos with no ballast, using a TP 3s-480.
AntiArf is online now Find More Posts by AntiArf
Old Apr 13, 2016, 09:10 AM
moscow580's Avatar
USA, CT, Waterbury
Joined Sep 2006
Beautiful work on the control horns.
Sean
Old Apr 13, 2016, 08:53 PM
Joined Jul 2015
I am sheeting the forward section with 1/64" ply veneer and balsa stringers to just aft of the cockpit opening. I was concerned that sheeting the whole fuselage it would add too much weight aft of the balance point. Also I am hoping to do a camo paint scheme, no lozenges.
Old Apr 13, 2016, 09:12 PM
Joined Jul 2015
Kit plastic parts
Here are a couple shots of the plastic parts pieces. I cut aluminum tubing for axles and cemented in place inside the wheel halves joined together and sanded smooth. The dummy motor needs a few more details added for radiator hoses and cap, maybe some wiring and spark plugs.
Old Apr 17, 2016, 05:58 AM
Joined Jul 2015
More work on controls
Got controls in place with micro push rods for elev and rud, aileron will be pull cables attached to a bellcrank.
Old Apr 17, 2016, 08:16 AM
Bf109G is offline
Find More Posts by Bf109G
Over-engineered
Bf109G's Avatar
Ridgecrest, CA
Joined Nov 1998
Paul,
Looking good, you're making quick progress! (quicker than me, at least, my build thread is HERE.) I've picked the same scheme for the same reason for my D.II build (Max Böhme, D.910/16, if you need the serial number). Most of the original black & white photos are around online, as well as more color profiles; if you have any trouble finding them, I can dig through some old links. There are a few different interpretations of it out there; no doubt you'll beat me to the paint booth, so it will be interesting to see which interpretation you go with.
Bf109G is offline Find More Posts by Bf109G
Old Apr 17, 2016, 09:21 AM
Lnagel is offline
Find More Posts by Lnagel
Senile Member
Lnagel's Avatar
Moab, Utah, USA
Joined Apr 2003
Very nice indeed, Paul. Following the build with interest.
Larry
Lnagel is offline Find More Posts by Lnagel
Found PZ Albatros or E-flite Albatros 55gmcx2 Aircraft - Electric - Airplanes (FS/W) 1 Nov 30, 2015 02:59 PM
Sold Dynam Albatros krazyman Aircraft - Electric - Airplanes (FS/W) 4 May 05, 2015 03:24 PM
Build Log I am looking for DWG or DXF format plan for L-39 Albatros EDF pajlotmato Scratchbuilt EDFs 1 Apr 30, 2015 03:01 AM
Discussion Sterling Albatros DII-A barmonkey Scale Kit/Scratch Built 6 May 12, 2008 11:44 PM
For Sale Will trade: Sterling USS missouri for Sterling waterbuoy Boats (FS/W) 2 Jun 26, 2006 04:47 AM
