Old Oct 20, 2014, 05:49 AM
Joined May 2014
Frsky telemetry send alarm
I work on a project around arduino and i want to send an alarm through the telemetry to the taranis transmitter and see or hear this alarm !
this is my actual code:
Code:
#ifdef FRSKYSPORT
// Frsky Sensor-ID to use.
#define SENSOR_ID_RPM           0xE4
// Frsky-specific
#define START_STOP              0x7e
#define DATA_FRAME              0x10
//Frsky DATA ID's
#define FR_ID_RPM_FIRST         0x0500
#define FR_ID_RPM_LAST          0x050F
//Frsky pin-telemetry
#define PIN_SPORT               1//ne pas utiliser la pin TX(1)
//Baud Rate speed
#define _FrSkySPort_BAUD        57600
/*<SoftSerial> identique a la librairie <SoftwareSerial> , mais utilise la librairie <TinyPinChange>
qui autorise le choix de la pin qui recoit les interruptions.*/
#include <SoftSerial.h>
SoftSerial _FrSkySPort_Serial(PIN_SPORT, PIN_SPORT,true); // RX, TX
short crc;// used for crc calc of frsky-packet
boolean waitingForSensorId = false;
uint8_t nextDefault = 0;
void FrSkySPort_Init(void)  {
  _FrSkySPort_Serial.begin(_FrSkySPort_BAUD);
void FrSkySPort_Update(void) {
  uint8_t data = 0;
  while ( _FrSkySPort_Serial.available())
    data =  _FrSkySPort_Serial.read();
    if(data == START_STOP)
      waitingForSensorId = true;
      continue;
    if(!waitingForSensorId)
      continue;
    FrSkySPort_ProcessSensorRequest(data);
void FrSkySPort_ProcessSensorRequest(uint8_t sensorId)
  switch(sensorId)
  case SENSOR_ID_RPM:
    FrSkySPort_SendPackage(FR_ID_RPM_FIRST,vitesse1 * nbPales );//  * 2 if number of blades on Taranis is set to 2
    FrSkySPort_SendPackage(FR_ID_RPM_LAST,vitesse2 * nbPales);//  * 2 if number of blades on Taranis is set to 2
    break;
void FrSkySPort_SendByte(uint8_t byte) {
  _FrSkySPort_Serial.write(byte);
  // CRC update
  crc += byte;         //0-1FF
  crc += crc >> 8;   //0-100
  crc &= 0x00ff;
  crc += crc >> 8;   //0-0FF
  crc &= 0x00ff;
void FrSkySPort_SendCrc() {
  _FrSkySPort_Serial.write(0xFF-crc);
  crc = 0;          // CRC reset
void FrSkySPort_SendPackage(uint16_t id, uint32_t value) {
 // _FrSkySPort_C3 |= 32;      //  Transmit direction, to S.Port
  FrSkySPort_SendByte(DATA_FRAME);
  uint8_t *bytes = (uint8_t*)&id;
  FrSkySPort_SendByte(bytes[0]);
  FrSkySPort_SendByte(bytes[1]);
  bytes = (uint8_t*)&value;
  FrSkySPort_SendByte(bytes[2]);
  FrSkySPort_SendByte(bytes[3]);
  FrSkySPort_SendCrc();
  _FrSkySPort_Serial.flush();
 // _FrSkySPort_C3 ^= 32;      // Transmit direction, from S.Port
void sendAlarmToFrskySport()
//code to add here ...
#endif
This code send the speeds of two glow motors (in rpm) .
I want an alarm when one motor is off !!!
Is it possible to do that with the Frsky Sport telemetry ?
Thanks for your help !
Pierre
pierrotm777 is online now Find More Posts by pierrotm777
Sold Turnigy 9XR, FrSky XJT Telemetry module, and FrSky LCD Telemetry display jimstreet Aircraft - General - Radio Equipment (FS/W) 1 Apr 06, 2014 02:26 PM
Discussion Lost Plane Alarm - Recommend One that doesn't send SOS? jcowgar FPV Equipment 0 Nov 08, 2013 04:01 PM
Discussion Frsky Telemetry voltage alarms Chris True Radios 6 Oct 25, 2012 01:30 AM
Discussion Connectng FrSky telemetry to FrSky module?? ZSimon Radios 5 Aug 16, 2012 04:19 PM
Sold FrSky Futaba Telemetry Module and Telemetry Receiver Dan777 Aircraft - General - Radio Equipment (FS/W) 1 Jul 08, 2012 09:46 PM
