Old Sep 26, 2014, 06:53 AM
Themadartist
Australia, QLD, Narangba
Joined Nov 2012
A question about getting from CAD to CNC ...
A noob question to the RC Groups CAD "Brains Trust" ...
I am considering having a Rhino model made for a 2m composite glider wing. The wings need to be 2-piece, as the fuse has 'shoulders' to which the wings mount.
I am confident the mould can be drawn, but I am totally ignorant of the practicalities of having it machined on a CNC. Here's why ...
I would like the wing moulds to allow the root section to be moulded, as well as having a 'channel' in the mould to facilitate the placement and alignment of the joiner boxes. I hope that's making sense. The attached pic of one of AvB's Angry Bird moulds is an example.
So I'm wondering if a CNC can actually cut the root 'face' - you know, get into the corner, so to speak.
I suspect cutting a plug, to then mould, would work, but I'm unsure if the mould itself would be too 'tight' to do.
Any advice / experience would be very welcome.
Thanks, Steve
Guy97 is online now Find More Posts by Guy97
Old Sep 26, 2014, 08:43 AM
Ward Hagaman's Avatar
San Diego
Joined Mar 2003
Steve, to make a sharp inside corner with a CNC it is common practice to make a pocket (think trough) at the root and then insert a second piece which makes it square at the bottom. Not a huge deal, but a little more work.
Ward Hagaman is online now Find More Posts by Ward Hagaman
Old Sep 26, 2014, 09:27 AM
Themadartist
Joined Nov 2012
Thanks for the reply Ward - I think I get it.
I was thinking that it could be overcut enough for the corner to be formed, then back-filled with a splooge or corian mix.
Cheers, Steve
Old Sep 26, 2014, 11:41 PM
Denver, CO
Joined Dec 2005
Another option it to hand scrape, to remove the radius.
Roto Rob is online now Find More Posts by Roto Rob
Old Sep 27, 2014, 01:25 AM
Themadartist
Joined Nov 2012
I did wonder about that Rob, it just seemed so counter-intuitive to go to the precision of a CNC, and then finish it "by hand".
Appreciate the reply.
Old Sep 30, 2014, 03:45 AM
United States, ID
Joined Sep 2011
You can't cut a square hole with a round tool.
You can "dog-bone", "T-bone", or cut past your corner.
I suggest going back with a smaller bit to clean out the corner. The radius will become insignificant and/or the overcut will become insignificant.
jakestew is offline Find More Posts by jakestew
Old Sep 30, 2014, 09:42 AM
Fool on a Hill
Joined Apr 2014
I know some professional woodworkers who routinely use CNC machines to cut their projects, and they all do some hand finishing at times.
I know it's common for people to think of CNC machining as a "push a button and it's done" operation, but when dealing with custom shapes, that is far from the truth.
Only in high production operations is it worth the time and trouble and extra tooling to cut parts that are ready to go (or sell), and even then, there is often a QC line that looks over each part and might call for some hand finishing.
What I would do in the case of the OP is to cut to the main dimensions and shapes and then just use a wood chisel to sharpen the corners and things.
Depot is offline Find More Posts by Depot
Old Sep 30, 2014, 03:14 PM
United States, ID
Joined Sep 2011
Just use a 1/8" or 1/16" bit and dog-bone the corner. The tiny, tiny extra bit of material that will be removed won't matter.
Corners are often where things don't fit. If you machine the parts perfectly you'll have to use a little force to fit them together. If you don't do a little allowance for the corners then they will be at risk of breaking off.
When you dog-bone the corner you get the corner fitting exactly against the corner point, but with a little allowance for the first tiny bit of the corner material.
This way you get a fit that will slightly round off the corner of the inserted part if the fit is too tight, but you won't get a 45 degree break off of the corner.
Old Sep 30, 2014, 05:24 PM
supreme being of leisure
ZAGNUT's Avatar
Tel Aviv, Israel
Joined Jul 2004
if you're going to be painting in the mold then Ward's suggestion is the best. polish the mold before setting the fence in.
another way is to end the mold at the root and then add a block to the end of the mold milled to hold your spar piece. more work but if made removable then it can help reduce damage to the sharp root corner by popping it of before demolding the wing.
ZAGNUT is online now Find More Posts by ZAGNUT
Old Oct 01, 2014, 02:14 AM
Themadartist
Joined Nov 2012
Many thanks ...
Thanks ZAGNUT, jakestew, Depot, RotoRob and Ward,
I appreciate you all taking the time to help out a newbie to the CNC world.
Best regards, Steve.
Discussion Ready to get into FPV with questions about pan tilt shadowx79 FPV Equipment 1 Aug 26, 2014 12:50 PM
Discussion Noob question about which battery to get. Babibab Batteries and Chargers 13 Jun 16, 2014 12:46 PM
For Sale 4 Axis 20x24 CNC Router/Engrave/Milling w/ CAD/CAM SW -Turn-key ngr1 Non R/C Items (FS/W) 2 Apr 17, 2014 05:50 PM
For Sale 4 Axis 40x48 CNC Router/Milling Machine w/ CAD/CAM SW -Turn-key ngr1 Non R/C Items (FS/W) 1 Apr 03, 2014 04:31 PM
Question Questions about Transmitters from a total beginner Slamonfish Beginner Training Area (Heli-Electric) 3 Dec 21, 2013 06:58 PM
