Old Oct 04, 2014, 11:14 AM
midelic's Avatar
Joined Apr 2012
I didn't tested it......test and feedback.
midelic is online now Find More Posts by midelic
Latest blog entry: DIY Multiprotocol TX Module
Old Oct 04, 2014, 11:38 AM
Hasi's Avatar
Austria, Stmk., Graz
Joined Sep 2011
Is it possible to flash the attiny with the TX module attached to it, or do I have to remove it?
Hasi is offline Find More Posts by Hasi
Old Oct 04, 2014, 11:41 AM
midelic's Avatar
Joined Apr 2012
Not sure ......,didn't tried like that....,you can try..as long as the voltage used is 3.3V.
Old Oct 04, 2014, 12:46 PM
Hasi's Avatar
Joined Sep 2011
It seems to work. I could flash it with the module still attached.
Did you also implement the binding thing I was talking about?
Old Oct 04, 2014, 12:57 PM
midelic's Avatar
Joined Apr 2012
What works ........the flashing or the rx?...I'm interested on the second.
No,.......... the transmitter id is always in eeprom not zero(from previous binding)...I can make it zero after a while,,,but that means rewriting eeprom unnecessary(not recommended).
Old Oct 04, 2014, 01:04 PM
Hasi's Avatar
Joined Sep 2011
RX also works.
The transmitter ID is not in the EEPROM if you just built the rx and it's brand new. It would be nice if the rx went into bind mode if the eeprom is clear (no transmitter id is saved yet). The other binding method should still be there, it you want to rebind the rx. Most people only bind their receivers once, when it's brand new.
Old Oct 04, 2014, 01:07 PM
midelic's Avatar
Joined Apr 2012
I get it now ..I can make it.
Old Oct 04, 2014, 01:14 PM
Hasi's Avatar
Joined Sep 2011
I have another question if you don't mind. How is the PPM stream generated? Does it have a fixed PPM Frame length, or does it adapt to how fast the TX sends data? Also if it's fixed how long is a PPM Frame?
Old Oct 04, 2014, 01:20 PM
midelic's Avatar
Joined Apr 2012
PPM stream is generated using your code(of course timer adapted to attiny85).Lol!
Old Oct 04, 2014, 01:36 PM
Hasi's Avatar
Joined Sep 2011
So what value did you use as PPM_FrLen?
Btw. if you use other people's opensource code, you should also make your code opensource.
Old Oct 04, 2014, 01:42 PM
midelic's Avatar
Joined Apr 2012
22500
Code is still in testing.
If you want the source I can send it to you...is not closed...my flysky Rx code is opensource..is posted .And on my flysky thread I mentioned your code as one of the sources used.
Old Oct 04, 2014, 01:53 PM
Hasi's Avatar
Joined Sep 2011
22500
I guess I wasn't searching for the source hard enough. Yeah, I would like to see it (maybe do some improvements )
Old Oct 21, 2014, 06:44 PM
midelic's Avatar
Joined Apr 2012
That mwii diagram on third post is wrong ......the 6050 sensor AD0 pin should be grounded.
AD0 pin connected to GND ,then 6050 respond on address 0x68...if AD0pin is connected to VCC the sensor changed to address 0x69...if leaved floating....it switches sometimes working on 0x68 and other to 0x69.
On mwii is not working properly.
Old Oct 22, 2014, 05:38 AM
Lithuania, Vilnius County, Vilnius
Joined Dec 2006
Yeah, You are right. Here is what I've found on some example:
Code:
// Using the GY-521 breakout board, I set ADO to 0 by grounding through a 4k7 resistor
// Seven-bit device address is 110100 for ADO = 0 and 110101 for ADO = 1
#define ADO 0
#if ADO
#define MPU6050_ADDRESS 0x69<<1  // Device address when ADO = 1
#else
#define MPU6050_ADDRESS 0x68<<1  // Device address when ADO = 0
#endif
montis is offline Find More Posts by montis
Old Oct 22, 2014, 11:41 AM
midelic's Avatar
Joined Apr 2012
I made one multiwii board based on that diagram...and when used alone the sensor working on 0x69...When I connect the rx the sensor switched aternatively to 0x68..and 0x69(I2c errors buildup)....so that pin AD0 should grounded or pullup...to VDD.
Mini-HowTo TH9X Turnigy FlySky IMax modify module to SMA and 1W booster DIY FPV rotaryboots Radios 3 Jun 08, 2013 03:32 PM
Sold iMAX/Turnigy/FlySky TX module & RX John Kim Aircraft - General - Radio Equipment (FS/W) 0 Jan 12, 2011 01:33 PM
For Sale iMAX/Turnigy/FlySky TX module & RX John Kim Aircraft - General - Radio Equipment (FS/W) 2 Dec 09, 2010 12:15 PM
For Sale Turnigy/iMAX/FlySky TX module & RX John Kim Aircraft - General - Radio Equipment (FS/W) 0 Oct 27, 2010 12:03 PM
