Old Nov 22, 2014, 07:14 AM
Ocala Fl
Joined Jul 2006
Originally Posted by Bart83 View Post
Hi all ,
Uploaded a video of my Empire flyingboat straight from the Mobius. The advantage is that if you use the Google chrome browser you can enjoy the video in super smooth 720p/60fps.
Cheers,
Bart
http://youtu.be/qA9-T_cbUWI
Great video and some excellent flying!!!
sherman89 is offline Find More Posts by sherman89
Old Nov 22, 2014, 09:53 AM
GLM
AMA 209854
GLM's Avatar
Check Six!
Joined Oct 2003
Hi all ,
Cheers,
Bart
Beautiful Bart!!!
Upwind - downwind - she lands and takes off just right. Long flight times too.
I think I need to build new wing and cover it to shed some weight. I can't get over how well yours performs. And Frank's performance at the float fly just re-enforces that thought.
Just love watching you do that - mesmerizing. And what great weather for a change.
Cheers!
Gary
GLM is offline Find More Posts by GLM
Old Nov 22, 2014, 01:42 PM
71% of the world is runway . .
Bart83's Avatar
Nederland, ZH, Oostvoorne
Joined Jun 2009
Hi Gary ,
Thanks for the kind words ! This video was made on the 18th of September. It was the 2nd flight on that battery load.
Well Gary , if you go for covering why not try to build the lightest empire ever. Just keep focused to the Goose for now
-Some idea's
- Hand pick the all the balsa so you have the lightest sheets
- Open frame fuselage like my prototype
- Stickers for windows
- Lichtweight covering ( chrome look )
- real small bell type outrunner for slowflyers
- 10-15amp esc's in the nacelles
- 16awg wire throught the wing ( only a single set , power takeoff at nacelle)
- GWS slow fly props like mine
- fixed tail , use pull-pull wire's instead of control cable's
- only use 3x05mm cf strips on one side of the main spar
- Very light layer off glass only on the bottom forward of the step
- Use micro servo's for all surfaces
- rudder and elevator servo''s all up in the nose
- Be sparse with expoxy
- No paint except for the registration
- No lighting system
I believe that if you would build one this way you could get the weight down to about 2200-2300 gram (78ounces) the battery could be degraded to a 3s3300mah.
Empire flyingboat , low and slow (10 min 51 sec)
Cheers,
Bart
Bart83 is online now Find More Posts by Bart83
Old Nov 22, 2014, 08:46 PM
Wormboy's Avatar
Australia, WA, Madeley
Joined Jul 2011
Just a quick pic of the Sikorsky from yesterday's floatfly.
Unfortunately this will be one of the last for the season as our lake is drying up into a hard pan. Nevertheless, it was a great day to finish on. No wind, cool and crisp. I'm getting more and more confident with the sikorsky and she loves those kind of conditions. As usual, thanks Waz for being photographer.
And one for Bart.... I think I'm slowly getting my head around Rhino and am into my project for next year's float season. Anyone care to guess what it is?
Wormboy is offline Find More Posts by Wormboy
Old Nov 23, 2014, 12:36 AM
GLM
AMA 209854
GLM's Avatar
Check Six!
Joined Oct 2003
My guess is a Macchi m33. or some sort of Curtis. Not a Macchi ... hmmmm.
Cheers!
Gary
Old Nov 23, 2014, 01:09 AM
Joined Sep 2014
My on the cheap super cub that i just finished...
m4rK is offline Find More Posts by m4rK
Old Nov 23, 2014, 01:33 AM
Wormboy's Avatar
Joined Jul 2011
Cheers!
Gary
Keep guessing. Right era as the Macchi, just 5 years later in fact.
A clue may be that it is technically a sesquiplane.
Old Nov 23, 2014, 04:28 AM
United Kingdom, Scotland, Argyll and Bute
Joined Oct 2012
Very tidy job , a lot of effort's gone into that
Now--don't scratch it
drambuidhe is offline Find More Posts by drambuidhe
Old Nov 23, 2014, 05:19 AM
Ton v Munsteren's Avatar
Netherlands
Joined Nov 2001
Wormboy,
Great choice the seaplane is a Shavrov Sh-2
Ton
Ton v Munsteren is offline Find More Posts by Ton v Munsteren
Old Nov 23, 2014, 06:05 AM
Dresden, Germany, europe, planet earth
Joined Aug 2003
hi there,
some pictures from my actual project. Who knows what THIS is?
1,3m span, glassfibre-Sandwich-fuselage, wooden floats, 3kg flying weight, 115km/h.
Regards,
Kuni
Kuni is offline Find More Posts by Kuni
Old Nov 23, 2014, 06:44 AM
Wormboy's Avatar
Joined Jul 2011
Originally Posted by Ton v Munsteren View Post
Wormboy,
Ton
Thanks Ton,
Good pick, it is indeed the Shavrov Sh2.
I had 4 criteria:
- looks cool
- seaplane
- majority of the design is sheetable rather than needing strip planking
- not something that is readily available as an ARF or Kit.
My other contender was another Russian job, the MBR-2
Kuni, no clue what yours is but it's a beauty. (and heavy at 3kg!)
Looks like an early schneider trophy contender.
Old Nov 23, 2014, 06:55 AM
Joined Aug 2003
Yes, it is several hundred gramm overweight, due to I used the very first fuselage out of the mould. I experimented later with different glass tissue and saved around 50-70g there. As most of the fuse is BEHIND CG, you can imagine that I fly with some serious lead barrels within. But: it flies nicely! More like a sport trainer, and can be flown in windy conditions too.
Currently I am making a new fuselage, have a lighter (rib rather than styro/Abachi) wing already built and hope to come out at around 2,5-2,6kg...
Early Schneider contender is good! Nearly done, it was a 1921 french project. The landplane version held the world speed record then...
Regards,
Kuni
Old Nov 23, 2014, 10:09 AM
3D Sunset Flier
Buzzed's Avatar
PHX
Joined Jun 2008
Originally Posted by Kuni View Post
hi there,
Regards,
Kuni
Very nice!
Buzzed is offline Find More Posts by Buzzed
Old Nov 23, 2014, 03:27 PM
Parkcityflier
parkcityskier's Avatar
Park City, UT, USA
Joined Aug 2001
Bart,
Great ideas for Gary to make the lightest Empire yet. I thought along those lines but got seduced by the look of the windows and lights so mine will definitely not be the lightest. However, I am keeping total weight in mind by using almost exclusively CA glues, minimum wood, the lightest servos, and whatever else that I can think of so it will be interesting to see how it comes out.
Jim
parkcityskier is online now Find More Posts by parkcityskier
Gallery Pics of your builds!!!! Post your Pics!!!!! tc3wins Multirotor Talk 192 Sep 21, 2013 10:22 AM
