Old Mar 08, 2014, 04:49 PM
Australia, SA, Riverton
Joined Nov 2012
Evan D. You say that you have CROW on throttle. I presume you mean throttle switch (back left of t/x). It may just be an alarm that comes on to say that the switch is activated and that CROW is in operating mode. I think that you maybe able to switch it off in the mixing edit window.
RobMill is online now Find More Posts by RobMill
Old Mar 08, 2014, 05:21 PM
Evan D's Avatar
Charlotte, NC
Joined Jan 2004
Sorry Rob, it's on the throttle stick not switch... By mix editing window you mean the individual mixes, not the main overall menu. Correct?
Evan D is offline Find More Posts by Evan D
Old Mar 08, 2014, 05:29 PM
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
Make sure that all your "Beep on centre" settings are off.
Any that are on will cause a beep every time you move that stick/pot to neutral.
pmackenzie is online now Find More Posts by pmackenzie
Old Mar 08, 2014, 06:00 PM
Joined Nov 2012
That's correct. I set up a model with flap up/flap down by using 3 pos switch. 0 = up flap, 1 = neutral, 3 = down flap. Maybe that is a bit simplistic for advanced glider flying, but I was only using a Bixler powered glider.
Old Mar 08, 2014, 06:59 PM
Evan D's Avatar
Charlotte, NC
Joined Jan 2004
Found it in one of the mixes, thanks!
Old Mar 09, 2014, 04:06 PM
KF5LDN FPV Junkie!!!
Wizzard033's Avatar
United States, TX, Lubbock
Joined Nov 2009
I've had bad luck with the 9XR. Is there a known issue with the sticks on this radio? Mine seem to be no linear! Any help appreciated.
Wizzard033 is offline Find More Posts by Wizzard033
Old Mar 09, 2014, 09:51 PM
Flying a Chipmunk in Portugal
jhsa's Avatar
NRW, Germany
Joined Sep 2010
Try to calibrate them. Press long the left key to enter the general settings menu, and then keep pressing the right key till you find the calibration menu. Follow the instructions.
jhsa is online now Find More Posts by jhsa
Old Mar 09, 2014, 11:01 PM
Wizzard033's Avatar
Joined Nov 2009
I'll try that thank you!
Old Mar 10, 2014, 04:04 AM
Me a long time ago
Flypoppa's Avatar
London N.E. UK
Joined Jan 2007
Question. Throttle curve. Oh knowledgable ones. Can any one tell me how should I set up the throttle curve for a quad?
At present the throttle is too 'sharp' and I am having difficulty getting a setting where I can keep the quad at a constant height.
It becomes so unstable that the quad is like a Yo Yo.
I want to have a setting where I have a wider range at approx off - mid throttle.
What % should the curve be set at starting from off to 50% of throttle?
Flypoppa is offline Find More Posts by Flypoppa
Old Mar 10, 2014, 04:20 AM
Tassie Electric, Heli, Glider
ChrisJ800's Avatar
Hobart, Australia
Joined Oct 2002
You need to look at phisicaly where is the throttle stick when the quad is hovering. In my last case it was just over half stick say 60% throttle. So I just set a 5 point curve, 0/50/60/70/100 as a starting point. You need to then ensure the throttle mix uses that curve.
ChrisJ800 is online now Find More Posts by ChrisJ800
Old Mar 10, 2014, 04:35 AM
Me a long time ago
Flypoppa's Avatar
London N.E. UK
Joined Jan 2007
Thanks Chris for a quick answer. The hover starts at about 1/3 stick.
I will try your suggestions. But now once more confused as what or how is the mix for the throttle and the curve?
Old Mar 10, 2014, 05:48 AM
ChrisJ800's Avatar
Hobart, Australia
Joined Oct 2002
Well it may be different in er9x but on OpenTx that I use you design the curve then add the curve in the mix menu to the throttle mix. Simple one step.
Old Mar 10, 2014, 06:15 AM
Me a long time ago
Flypoppa's Avatar
London N.E. UK
Joined Jan 2007
I have the 9XR V 1.6++.
After having a DX6i I must confess that the 9XR is confusing. I am cracking some of the features, as I 'play' with it.
It's more trial and error. I will just keep on until I crack it.
Thanks.
Old Mar 11, 2014, 01:43 AM
Mark Harrison
USA, CA, Piedmont
Joined Jun 2010
Thanks.
Here's some tutorials that may help. Once you've got mixing figured out, the rest is a piece of cake.
http://www.rcgroups.com/forums/showthread.php?t=1820823
marhar is offline Find More Posts by marhar
Old Mar 11, 2014, 04:06 AM
Me a long time ago
Flypoppa's Avatar
London N.E. UK
Joined Jan 2007
Thanks but I have those saved. Problem is, the 'mixing' one, the video is not very sharp and it is difficult to see what screen it is. I keep watching it and try to sus it out.
An Oops! Having come out of hospital last Friday, (hernia repair) my brain is still not functioning.
The 1.6++ is my KK2. The OS of the 9XR is ER9X.
Discussion Gens Ace, Turnigy, Turnigy Nano-Tech Sky lipo, etc. What's Your Preference? jlloyd1995 Batteries and Chargers 125 Jan 19, 2014 01:09 PM
Sold 2 turnigy motors 2 turnigy esc's crashnburn69 Aircraft - Electric - Power Systems (FS/W) 4 Oct 13, 2012 11:05 AM
For Sale Turnigy 2x 3s 1000 mah and 2s 1000 mah and Turnigy 2s/3s Lipo charger. Falconpunch Aircraft - Electric - Batteries & Chargers (FS/W) 1 Mar 18, 2012 09:47 PM
Discussion Turnigy or Turnigy Nanotech lawguy14 Batteries and Chargers 4 Mar 15, 2012 08:48 AM
