Old May 18, 2014, 01:32 PM
InceCreations
vincent123's Avatar
Joined Jul 2009
3D printing ribs
Bumped into these, looks promissing.
The xyz printer will be at only 500$, prices dropping fast.
Within 2 years some or a lot of us will be printing ribs...?
For airframes, the ABS weight is still a lot higher than balsa or plywood....
Vincent
vincent123 is offline Find More Posts by vincent123
Latest blog entry: FZ5: design phase
Old May 18, 2014, 02:01 PM
iron eagle's Avatar
United States, MA, Middleboro
Joined Jul 2007
Looks cool but like you said the down side is the weight. I think your far better off with balsa that is laser cut or cnc shaped.
iron eagle is offline Find More Posts by iron eagle
Latest blog entry: The third time is a charm!
Old May 18, 2014, 02:06 PM
InceCreations
vincent123's Avatar
Joined Jul 2009
The density of the plastic is higher than plywood or for sure balsa. But part of this extra weight can be eliminated by lighting holes, just as the pictures shows...cause the material is stronger and needs less meat for the same strength? i don t know.
Old May 18, 2014, 02:52 PM
iron eagle's Avatar
Joined Jul 2007
True. It would be interesting to do a set of balsa/plywood and a set of plastic and see how the actual weights came out.
Old May 18, 2014, 04:04 PM
I don't like your altitude
Stupot46's Avatar
Joined Sep 2011
https://www.inventables.com/technolo...ment-laywoo-d3
Give it time,the tech will evolve.
Stupot46 is offline Find More Posts by Stupot46
Old May 18, 2014, 06:57 PM
iron eagle's Avatar
Joined Jul 2007
Originally Posted by Stupot46 View Post
That is pretty wild.
Looks like the replicator on Trek wasn't all that far fetched after all.
Old May 19, 2014, 09:46 AM
Vertical approach specialist
potshot's Avatar
Northeastern Illinois
Joined Mar 2009
Spot on. As 3D printing becomes more widely accessible, people will figure out how to print the same rib shapes with internal structure that is appropriate for the material. And as Stupot points out the technology is evolving rapidly. We're only seeing the very early stages. Its going to be fun to see what happens next.
potshot is offline Find More Posts by potshot
Old May 19, 2014, 10:29 AM
Stupot46's Avatar
Joined Sep 2011
http://www.rcgroups.com/forums/showthread.php?t=1470157
Why stop at the ribs.......
Old May 19, 2014, 11:03 AM
Canada
Joined Nov 2000
Google "Peachy Printer"
Newer technolgy 3d printer using a laser in Light activate resin.
A wee bit more sophisticated than squeezing out ABS spaghetti noodles..
$100 kickstarter price. But mk1 version is 'small', albeit scalable
That said IMO a 3d router is infinitely more suited to Toy airframe production.
Why make a myriad individual parts when one can carve out a complete airframe.. using a far less expensive machine ?
Bare is offline Find More Posts by Bare
Build Log Micro EDF Hawker Hunter - CAD, 3D Scanning, 3D Printing etc meerkat13 CAD/CAM 1 Mar 14, 2014 08:02 AM
Discussion 3D printed GoPro Anti Jello Wire Rope Isolator Mount for my 3D H-Quad NuttyBar Scratchbuilt Multirotors 1 Dec 23, 2013 10:36 AM
Build Log 9D- the 3D printed 3D plane sqrt18 3D Flying 17 Oct 20, 2013 01:04 AM
Question 3D Printing / 2D Metal cutting Jesterbaze Multirotor Talk 1 Sep 19, 2013 08:32 PM
Discussion Laser cutting wing ribs, bulkheads, etc - O/Timer from printed plans... JonB Vintage & Old-Timer Designs 5 Feb 22, 2011 08:26 AM
