Old Aug 09, 2014, 07:37 AM
Joined Mar 2014
Wiring Question
Ok,
Crashed my penguin yesterday morning, badly. Time to build a new one though! With that there are some changes I want to make and I just want some input to make sure I am getting everything hooked up right and what not.
With this camera-
http://www.readymaderc.com/store/ind...roducts_id=582
I shouldn't need to do anything except plug it into the power supply for my FPV system correct? Of which I plan have contained all on its own using its own battery. Hopefully a 11.1v 3s 1100mah battery . It should be able to be directly plugged in off the battery right? Then I could also tie my FPV transmitter to the same battery by soldering a second plug off the power cable if I am thinking about this correctly?
While I am here I don't suppose anyone would be able to share their wiring diagram that they use would you? I am interested in keeping the FPV power supply separate from the main power supply.
Thanks guys
Frigid
FrigidFlight is offline Find More Posts by FrigidFlight
Discussion E300 performance wiring question WBFlyer DJI-Innovations 3 Feb 14, 2014 01:50 PM
Help! Discovery Pro/Naza V2 wiring question jwk72 Multirotor Electronics 0 Dec 29, 2013 07:08 PM
Discussion Noob Tricopter MultiWii Wiring Question dlabs Multirotor Electronics 1 Dec 29, 2013 10:31 AM
Discussion Wiring question (wiring diagram included) JaZzMaN251 FPV Talk 6 Nov 12, 2013 05:57 PM
Discussion Video TX Wiring Question zlehmann FPV Equipment 1 Nov 04, 2013 06:24 PM
