Old Jul 04, 2004, 06:42 AM
Libertyville, IL
Joined Oct 2003
How to charge a TX MH battery
Can someone tell me what amp to charge my 1650 MH battery on a Triton charger? Or at least the formula used to charge MH batts?
Bach
bach939 is offline Find More Posts by bach939
Old Jul 04, 2004, 07:38 AM
one game away...
PerfectStranger's Avatar
Willoughby, Ohio
Joined Apr 2004
I have two of those 1650 nimh TX packs and a Triton. I usually charge at .3-.4 amps with a peak sensitivity of 5mV per cell. Takes anywhere from 2-5 hours for a good, slow charge which won't damage the cells at all. I have charged one of them at 1 amp once. Was in the field and wasn't feeling good about my TX voltage going below 9V. Charged for about 1 hour, no ill effects.
matt
PerfectStranger is offline Find More Posts by PerfectStranger
Old Jul 04, 2004, 07:41 AM
Libertyville, IL
Joined Oct 2003
Thanks Matt for the quick reply.
bach
Old Jul 04, 2004, 07:43 AM
Libertyville, IL
Joined Oct 2003
One more question Matt . .
When you cycle the batts, what discharge rate do you use?
Bach
Old Jul 04, 2004, 10:54 AM
Kansas
Joined Sep 2003
normally I hook them on the Triton at 1.6 amp charge 2.5 amp discharge and set it to the "disc to Chg" for 3 cycles usually the first cycle is pretty low but the next two are over 1700mah. Done
Brian
RC Toys USA is offline Find More Posts by RC Toys USA
Old Jul 07, 2004, 07:47 AM
Libertyville, IL
Joined Oct 2003
Thanks Brian!
bach
How long should I charge my transmitter battery for the first time?? KZZ Batteries and Chargers 14 May 04, 2008 01:16 PM
How should I charge a fresh pack battery? xadmin Electric Plane Talk 23 May 03, 2008 05:02 PM
Zagi N-500A Battery - How to charge? Helicool Batteries and Chargers 4 Mar 14, 2003 10:31 PM
When to charge Tx battery?? duganderson Batteries and Chargers 1 Jan 30, 2003 09:43 AM
To fast charge a tx battery . . . Ben C Electric Plane Talk 6 Jun 10, 2001 03:17 PM
