Old Aug 13, 2014, 08:26 AM
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
Fms p-40
Just got mine from Motion RC; guessing it is the same airframe as previously sold by others, i.e.: HK, Nitro, etc.
Wondering if my Plush ESC programming card would be compatible with its ESC:
FMS 60A ESC with 3A SBEC
FMS 3648-600Kv Motor
Didnt find the manual on the web; guess Im not surprised Assembly page attached here.
Other comments/hints/suggestions, please.
TIA,
Jim
jrb is offline Find More Posts by jrb
Old Aug 13, 2014, 09:05 AM
taz101's Avatar
Australia, QLD, Oxenford
Joined Oct 2010
http://www.rcgroups.com/forums/showthread.php?t=1192560
taz101 is online now Find More Posts by taz101
Old Aug 17, 2014, 08:05 AM
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
Mine from Motion RC has this mess -- Ugh!
Prop adapter is not Hex as is the spinner, and too much gap between the spinner and cowl.
A mod to the spinner's back plate is a significant effort.
Old Aug 17, 2014, 10:15 AM
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
Lump material removed from back and hew bored out.
Still 6mm gap and 2mm off un-threaded prop shaft now exposed .
Old Aug 20, 2014, 06:41 AM
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
Nice reply from Motion; though follow-up has not occurred as of yet.
-----Original Message-----
Sent: Monday, August 18, 2014 2:11 PM
To: Jim Blanner
Subject: [#820292] Motor spinner issue
Hi James,
Thank you for contacting us. We are happy to investigate this for you; for future
reference, please contact us before modifying parts. I am escalating your case to our team
to compare with the other P-40s we have in stock. Please allow us one business day to
identify the best way forward.
Thank you,
Alpha Enos
Motion RC
www.motionrc.com
Used a Fender Washer and drilled out the 1st few threads for added clearance of a 6mm Coupling Nut much longer/thicker than standard nut.
Runs up nice and smooth.
Old Aug 20, 2014, 12:44 PM
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
From Motion RC:
Hi Jim,
We were able to confirm the source of the issue and would like to send you a free motor shaft and free spinner.
We have confirmed that these are a perfect fit.
Old Aug 24, 2014, 04:28 PM
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
Got the parts from Motion -- exact same spinner; but a different prop adapter.
The prop adapter fit the Hex of the spinner, and has a very nice washer!
Photos show how much space there is between the spinner and cowl -- 16mm -- UGH .
Will use the new adapter.
Old Aug 26, 2014, 06:52 AM
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
Disappointing -- nothing told me that I'd need to cut the carbon tube to fit the wings to the fuselage. The aileron extensions are extremely short. And, the 25mm screws as called for are too short for the rudder;; and 40 too long.
Did do Split Flaps:
Old Aug 26, 2014, 10:36 PM
Ldm
Ldm's Avatar
United States, PA, Conestoga
Joined Jun 2006
NIce job on the flaps !!!
Ldm is offline Find More Posts by Ldm
Old Aug 27, 2014, 07:52 AM
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
Thanks, they were fun to do.
FMS is no ParkZone with respect to fit and quality.
The wing panel pocket are 11.125 deep when measured with a 1/6 CF rod.
But the CF tube (27.25") gets stuck a bit shallower: RT 10.75 & LF = 10.5.
Im thinking it would be best to cut the tube down by 1.25 ~ 27.25 5 (fuse) -10.75 10.5 = 1
Old Aug 28, 2014, 08:06 AM
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
There's a screw out near the aileron servo that seems to have caused the issue w/the CF tube.
Backed them out a turn or two and was able to get the tube to fully seat. Then re-tightened them.
Ready for maiden now.
Old Aug 28, 2014, 12:46 PM
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
Motion told me that the ugly spinner gap was created when FMS upgraded the motor which is longer than the original.
I wonder why they didnt change the motor/firewall mount?
From a scale standpoint the supplied spinner is shaped more like a Mustang's spinner (curved/round); rather than the conical spinner on the P-40.
Old Aug 28, 2014, 04:04 PM
Carnet's Avatar
United States, SC, Greenville
Joined Jul 2013
On the quality of FMS models I wouldn't use this p40 as a basis for comparison at all. This specific model is one of their oldest. It is in sore need of an update.
I have been very happy with both of my FMS models.
Carnet is offline Find More Posts by Carnet
Sold FMS P-40 1400mm PnP LPU albert92078 Aircraft - Electric - Airplanes (FS/W) 0 Jul 13, 2014 01:15 AM
Sold fms p-40 warhawk v2 800mm brand new.... pnp.....lpu san diego warhawk crazy Aircraft - Electric - Airplanes (FS/W) 3 Jul 02, 2014 11:01 AM
Wanted Airfield/FMS 800 mm v1 p-51 & p-40 parts WNCflyer Aircraft - General - Miscellaneous (FS/W) 0 Jun 17, 2014 03:42 PM
Wanted FMS/Airfield 800 mm p-51/p-40 V1 parts WNCflyer Aircraft - General - Miscellaneous (FS/W) 5 Dec 17, 2013 10:51 PM
Discussion FMS 1400mm P-40 Warhawk MAMBA2200 Electric Warbirds 2 Nov 08, 2013 09:51 AM
