Old Aug 06, 2014, 03:15 PM
United States, MN, St Cloud
Joined Jan 2012
Thank You
richkphoto is online now Find More Posts by richkphoto
Old Aug 19, 2014, 07:44 AM
Brazil, AL, Maceió
Joined Mar 2012
Hi Lebret, thank you for all the valuable information from your post below. Are you using it with no issues?
Originally Posted by mlebret View Post
Wifi Modem Reset
As a new user of the YS-X6, I messed up the settings of the wifi modem and was no more able to access it. Unfortunately ZeroUAV was of no help with that issue.
Digging the net I found the web site of the Wifi module maker and some valuable documentation.
There is a reset procedure involving the opening of the case and shorting LED_NET pin to Ground for 3 sec during startup. When done you have to redo the settings according to YS-X6 documentation and save them, from the USR-WIFIMOD factory state.
In factory state(initial configuration), USR-WIFIMOD-II behaves as below:
􀂄 It’s NET&SERIAL LED Blink in every 2seconds.
􀂄 It will work in adhoc mode,whose ssid is “wifimodII@192.168.1.254”
􀂄 It holds a staticIP address “192.168.1.254”
􀂄 It works in Udp2Serial mode, and serial access port is 55555.
You have to set your PC TCP/IP properties with
IP static address: 192.168.1.105 (Exemple)
Subnet Mask 255.255.255.0
Default gateway: 192.168.1.254
No Wifi protection,
then access the Setup Web page 192.168.1.254 ( admin/admin as UserName/Password)
It may help.
Marc
alsoares is offline Find More Posts by alsoares
Old Aug 19, 2014, 10:36 AM
mlebret's Avatar
France, Bretagne, Combrit
Joined Mar 2005
Hello,
I had issue with serial part of the modem (maybe bad wire between ZeroUAV unit and modem), so I ordered a new one (new generation) from ZeroUAV 2 years ago (oct 2012).
I still have the old unit in my box, but I have to verify if it is OK. Could be useful.
Marc
mlebret is offline Find More Posts by mlebret
Discussion Zero UAV YS-X6 Owners Thread and Discussion fajar Multirotor Electronics 2406 Yesterday 08:51 PM
New Product DJI WooKong-M Autopilot System for multirotors **Owners Thread** DJI INNOVATIONS Multirotor Electronics 19973 Aug 28, 2014 03:48 PM
New Product Test video of YS-X6 Autopilot system pzhang Multirotor Talk 141 Jun 07, 2012 06:50 AM
Discussion Groupbuy for YS-X6 system fajar Australia 14 May 15, 2012 04:35 AM
