Old Feb 09, 2016, 06:30 PM
ko4nrbs is online now
Find More Posts by ko4nrbs
Joined Dec 2014
7.4 volt 2S4P Pack
Can someone recommend a good 7.4 volt 2S4P Pack 3000maH or more capacity and where to purchase them? We need some for a new project.
Bill
ko4nrbs is online now Find More Posts by ko4nrbs
Old Feb 09, 2016, 07:35 PM
Dave H. is online now
Find More Posts by Dave H.
Joined Feb 2008
It actually has to be 4P?? Without that spec, then it can be any old lipo. I'm just wondering if you got that suggestion from some old manual that predates big lipo cells.
Dave H. is online now Find More Posts by Dave H.
Old Feb 09, 2016, 11:28 PM
kamcoman is offline
Find More Posts by kamcoman
Douglasville, GA
Joined Sep 2004
Are you looking for a 7.4 volt 12000 mAh pack or a 7.4 volt 3000 mAh pack?
kamcoman is offline Find More Posts by kamcoman
Old Feb 10, 2016, 01:44 AM
Ira NZ is offline
Find More Posts by Ira NZ
Bombs away! Err...landing
Ira NZ's Avatar
Upper Hutt, New Zealand
Joined Apr 2006
Bill
Why 4p? Extra cost and complexity running so many in parallel when 3000mah cells are pretty common.
Ira NZ is offline Find More Posts by Ira NZ
Old Feb 10, 2016, 09:47 AM
Joined Dec 2014
A 12000 would last a lot longer in the field. We are going to use them to power slave flashes for Game Cameras.
Bill
Old Feb 10, 2016, 09:48 AM
Joined Dec 2014
We are trying to get as long a life as we can while they are out in the field.
Bill
Old Feb 10, 2016, 11:42 AM
phil_g is online now
Find More Posts by phil_g
Who let the dogs out?
phil_g's Avatar
Pontefract, Yorkshire, UK
Joined Jul 2007
What people are trying to tell you Bill is that the question doesnt make sense.
If you want a 3000mAh 2S pack, these are readily available, as two 3000mAh cells in series.
You specifically state that you want a 4P pack.
No-one to my knowledge will make combined cells from four parallelled 750mAh cells these days, because 3000's are readily available.
As for long life, do you mean long-term cycle life or discharge time?
Neither "1P 3000" cells or "4P 750" cells will have any advantage over the other.
Cheers
Phil
Edit: cross posted. I see you actually want a 12000, not a 3000:
Choose a pair of any of these and parallel them.
phil_g is online now Find More Posts by phil_g
Old Feb 10, 2016, 01:30 PM
Joined Dec 2014
Cheers
Phil
Well I'm new to this so my ignorance is confusing me.
Thanks for the link.
Bill
Old Feb 10, 2016, 10:30 PM
ggcrandall1 is online now
Find More Posts by ggcrandall1
ggcrandall1's Avatar
USA, GA, Marietta
Joined Aug 2005
Bill
Perhaps this will help explain some things. http://www.tjinguytech.com/charging-how-tos
Glen
ggcrandall1 is online now Find More Posts by ggcrandall1
Sold FS: Battery Packs, 7 Cell 8.4 Volt NiMH jzimm9mm Aircraft - Electric - Helis (FS/W) 0 Oct 04, 2005 12:07 AM
Question Will the e-tech 7.4 VOLT 1200 MAH HIGH PERFORMANCE LIPO PACK work in an SS? Picoflyer Parkflyers 3 Nov 08, 2004 04:19 PM
4460 mah 7.4 volt Reciever pack Li-ION jrplane Aircraft - Fuel - Airplanes (FS/W) 0 Mar 16, 2004 08:47 AM
15 Packs-7 CELL 8.4 Volt GP 370 MAH austinelse Aircraft - Electric - Airplanes (FS/W) 1 Dec 14, 2002 04:45 PM
Wanted, 8.4 Volt 7 Cell Battery Packs ROCKKZ Aircraft - Electric - Airplanes (FS/W) 1 Aug 02, 2001 01:33 AM
