Old Jun 13, 2013, 03:23 AM
ChuckTseeker is offline
Find More Posts by ChuckTseeker
ChuckTseeker's Avatar
Adelaide Plains Australia
Joined Dec 2007
New Product
E-flite Beast 60e Aerobatic RC Plane, ARF
Now this looks very nice, not the foamy lots have been asking for, BUT! WOW!
Beast 60e ARF
Key Features
Lightweight laser-cut balsa and plywood construction
High power-to-weight ratio with 3D capability
Fast four-screw and four-pin field assembly
Two-piece, plug-in wings with carbon joiner tube
Ready-to-mount the recommended high-output E-flite® Power 60, 470Kv motor
Large magnetic nose hatch provides ample access to battery and electronics
Independent and simple direct-link servo installation
Steerable tailwheel and quality hardware package
Large control surfaces with double-beveled hinge lines
Genuine Hangar 9® UltraCote® covering
Pre-painted fiberglass cowling and wheel pants
Durable aluminum landing gear with painted finish
Overview
The E-flite® Beast 60e ARF biplane embodies everything you'd expect from a design created to deliver stunning feats of aerobatic artistry. The full-scale Beast is the brainchild of renowned aircraft restoration expert, Kevin Kimball, who actually collaborated with 3D champ Quique Somenzini on its design. Its dramatic ability to flip, roll and tumble with formidable precision inspired the 100cc Hangar 9® Beast that's widely recognized as a modern classic. For this inaugural 60-sized iteration, the E-flite development team worked closely with Quique to ensure the impressive performance and feel of a larger aircraft came through. Because it's been designed specifically with the modern electric pilot in mind, every design element takes full advantage of what potent electric power has to offer including engineered construction that's feather-light. As a result, the Beast 60e is a whole new breed of animal.
Assembly at the field takes just a few minutes and is as simple as installing four screws and four pins. Flight battery replacement is fast too from the magnetic slide-lick top hatch that provides instant access to vital electronics. The recommended E-flite power system was designed around popular and economical 6S Li-Po batteries to provide power you can trust and unlimited performance. So inspired by the agility and presence of the Beast 60e, E-flite engineers developed an even stronger version of the Power 60 brushless motor so that its fierce aerobatic ability could shine through.
Product Specifications
Wingspan: 57.0 in (145 cm)
Overall Length: 57.5 in (146 cm)
Wing Area: 1100 sq. in. (71.0 sq. dm.)
Flying Weight: 8.90-9.55 lb (4.05-4.35 kg)
Motor Size: 60-size brushless outrunner
Radio: 6+ channel radio system
Servos: (2) ultra torque standard, (4) ultra torque mini servos
Trim Scheme Colors: UltraCote Black (U874), True Red (U866), Gold (U879)
CG (center of gravity): 4-1/2 to 4-15/16 in (115-125mm) back from the center of top wing
Prop Size: 17 x 7e
Spinner Size: 3.0 inch P-51 style
Speed Control : 80-amp brushless
Recommended Battery: 22.2V 6S 4400-5000mAh LiPo
Flaps: No
Retracts: No
Control Throw (Ailerons): Low: 1-3/4 in (45mm) up/down, 10% expo; High: 2-15/16 in (75mm) up/down, 30% expo
Control Throw (Elevator): Low: 2-15/16 in (75mm) up/down, 10% expo; High: 5-1/8 in (130mm) up/down, 30% expo
Control Throw (Rudder): Low: 3-3/4 in (95mm) right/left, 10% expo; High: 4-1/2 in (115mm) right/left, 30% expo
Minimum Age Recommendation: 14 years
Experience Level: Intermediate
Recommended Environment: Outdoor
Assembly Time: 7-9 Hours
Is Assembly Required: Yes
ChuckTseeker is offline Find More Posts by ChuckTseeker
Old Jun 13, 2013, 04:13 AM
bwbkx125 is offline
Find More Posts by bwbkx125
Australia, NSW, Sydney
Joined Sep 2011
About time!
bwbkx125 is offline Find More Posts by bwbkx125
Reply With Quote  (Disabled)
Old Jun 13, 2013, 05:06 AM
lord chris is offline
Find More Posts by lord chris
RAFMAA
United Kingdom, Marham Airfield
Joined Jun 2005
Just saw my LHS post this up on FB! looks bloody amazing! shame Iv only just purchased a big pitts python The Beast was a fantastic Aircraft!
lord chris is offline Find More Posts by lord chris
Old Jun 13, 2013, 07:47 AM
Ducati Mechanic is online now
Find More Posts by Ducati Mechanic
Some.. call him Tim...
Ducati Mechanic's Avatar
United States, TX, Austin
Joined Oct 2008
Very cool! I can see quite a few torque 4016 T 500 KV motors sliding into these
Ducati Mechanic is online now Find More Posts by Ducati Mechanic
Old Jun 13, 2013, 08:13 AM
scrub monkey is offline
Find More Posts by scrub monkey
use the 4s luke, use the 4s...
scrub monkey's Avatar
Australia, QLD, Booyal
Joined Sep 2012
looks interesting. ill be following this
scrub monkey is offline Find More Posts by scrub monkey
Old Jun 13, 2013, 08:19 AM
hone1er is offline
Find More Posts by hone1er
Team Twisted!
hone1er's Avatar
United States, CA, Hercules
Joined Dec 2011
Looks great! The price isn't too bad either.
I'm not much of a bipe guy but i love the looks of The Beast. May have to get one of these.
hone1er is offline Find More Posts by hone1er
Old Jun 13, 2013, 08:39 AM
dwazzer is offline
Find More Posts by dwazzer
United Kingdom, Cumb
Joined Jan 2012
What is the price on these???
dwazzer is offline Find More Posts by dwazzer
Old Jun 13, 2013, 08:41 AM
hone1er is offline
Team Twisted!
hone1er's Avatar
Joined Dec 2011
$349.99
Not bad for a 57'' bi-plane.
http://www.e-fliterc.com/Products/De...ProdID=EFL9000
Old Jun 13, 2013, 08:50 AM
Dave Eichstedt is offline
Find More Posts by Dave Eichstedt
Warbird & Jet Lover
Mahomet, Illinois
Joined Aug 2007
THIS is the airplane that drove us to release the new version of the Power 60 with a higher Kv.
Dave Eichstedt is offline Find More Posts by Dave Eichstedt
Old Jun 13, 2013, 08:52 AM
kalmon is offline
Find More Posts by kalmon
Parkzone junkie
kalmon's Avatar
United States, MI, Grand Traverse
Joined Oct 2008
I'm thinking about a Motrolfly 4315-380 on 8S as I have a few 4000mAh 4S packs and could just run them in series. Should make for some ballistic performance.
I am a little puzzled why Horizon spec'd 6S for this plane... You would think that they would want a 8S setup as the majority of their small planes in the parkzone line are only 3S 1800-2200 so those packs can't scale up, but their larger park offerings like the habu, the new p-51, and more are using larger 4S packs. This would mean that people will probably have a bunch of 4S packs and going 8S would be a logical next step. Also they already have the 1/4 scale PA-18 super cub that has an 8S motor calling for 2 4S packs in series, so they obviously have done it before.
edit:
HAH, while I was typing Dave answered my question before I asked it! makes a bit more sense now. I wonder they'll have a e-flite motor they recommend for 8S for those of us with lots of 4S packs.
-Brian
kalmon is offline Find More Posts by kalmon
Old Jun 13, 2013, 09:02 AM
VR Eyedoc is offline
Find More Posts by VR Eyedoc
Hardcore EP 3D Flyer
VR Eyedoc's Avatar
Canada, ON, Toronto
Joined Aug 2012
do you think it can 3D 4.05-4.35 kg biplanes?
VR Eyedoc is offline Find More Posts by VR Eyedoc
Old Jun 13, 2013, 09:09 AM
VR Eyedoc's Avatar
Canada, ON, Toronto
Joined Aug 2012
edit:
-Brian
I am thinking about 12S 2200 with custom wound low KV 5060 motor. so people who have 3S 2200 or 4S 2200 can all scale up. or use good quality 6S 3800mah that people are using for EF 60-in, for a light weight setup.
Old Jun 13, 2013, 09:21 AM
bhoov128 is offline
Find More Posts by bhoov128
Genesis 50:20
bhoov128's Avatar
United States, FL, Davenport
Joined May 2012
It might be a stupid question - No AS3X ?
Ben
bhoov128 is offline Find More Posts by bhoov128
Latest blog entry: Snice Slick
Old Jun 13, 2013, 09:25 AM
rcbirk21 is offline
Find More Posts by rcbirk21
Barefoot Birkinsomething
rcbirk21's Avatar
United States, CA, Hayward
Joined Aug 2004
im pretty psyched for this. i hope it flies decently. i think a motrolfly 4320-450 on 6s5000 packs with a 17x8-17x10 prop would be awesome in this
also looks like they took quite a few design tips from the sebart pitts python. magnetic top half cowling access for battery and motor, pin/dowell insertion for wing retention. could be a cool design. pretty close in size and price to the sebart as well, but updated design. i really hope this becomes a winner
rcbirk21 is offline Find More Posts by rcbirk21
Old Jun 13, 2013, 09:28 AM
hone1er is offline
Team Twisted!
hone1er's Avatar
Joined Dec 2011
That's the combo i was thinking of using. Can't wait for some flight video
I'll have to wait a while on this since i'm no baller but it looks like it'll be worth it.
Cool New E-flite Cessna 150 Aerobat ARF dee-grose Scale ARF/RTF 639 Sep 07, 2015 07:42 PM
Sold E-flite hawker hurricane rc airplane plane kit no electronics new $80 3drcparts Aircraft - Electric - Airplanes (FS/W) 8 Feb 21, 2013 01:35 PM
For Sale Misc Arf parts, Hangar 9, E-flite, 3dhs, Great Planes dakotanovass Non R/C Items (FS/W) 0 Jan 12, 2013 08:56 AM
Sold E-flite L4 Grasshopper ARF and Cessna 150 Aerobat ARF ton2di Aircraft - Electric - Airplanes (FS/W) 0 Nov 23, 2012 06:50 PM
Discussion e-flite cessna 150 aerobat 250 arf? rcguy1234 Electric Plane Talk 3 Aug 20, 2011 02:38 PM
