Old Feb 11, 2016, 05:26 PM
Hermani is offline
Find More Posts by Hermani
Quad and foam adept
Hermani's Avatar
The Netherlands, OV, Delden
Joined Apr 2014
Originally Posted by Cyberdactyl View Post
I'm not sure how all the paranoia began with CCW threads. Before. . oh . . maybe mid 2013, they were more or less unheard of.
Guess DJI started it when they released the first DJI Phantom. After I crashed mine I started building and after buying a couple of motors all with standard threads I found out for myself it doesn't make any difference. Sure, you can't use those fancy self-tightening props but - do you WANT to? I have seen those unscrew themselves after stopping the motors after landing
Nowadays I buy simple and plain props and screw them on using simple and plain nuts or prop adapters and just check every once in a while whether it is still securely fastened.
Hermani is offline Find More Posts by Hermani
Latest blog entry: Cellulose One tricopter
Old Feb 11, 2016, 05:50 PM
kenjancef is offline
Find More Posts by kenjancef
kenjancef's Avatar
United States, RI, East Providence
Joined Nov 2015
I have a Phantom 2, and I do have to say that I don't worry about the props falling off due to the threads and all that.
But I'm new to building, so the reverse threads are what I'm used to. The first time I got the props spinning on my scratch built, a nut flew across the room because it got loose. Since then I got lock nuts, but, and this is just me, I feel safer knowing that my props won't fall off.
I have plain old props on my build (HQ 11x4.5's), and I now secure them pretty tight. I also have the bullet nuts, and I slide an Allen wrench in the holes to tighten them.
I am still nervous when I fly my build, so I'm not going to get too crazy or go too high all at once, just because I have a Phantom. So that will give me time to see how the props are. And I'll keep the socket wrench handy as well to just check them periodically.
kenjancef is offline Find More Posts by kenjancef
Old Feb 11, 2016, 08:43 PM
kenjancef's Avatar
Joined Nov 2015
Made some changes to my Crossfire build this week. Change the legs to move them off the arms, makes it look a little funkier. I also HAD an ImmersionRC 600 for FPV, but wrecked the antenna connection, so I bought a RMRC Cricket 600mW Tx, works well so far. The FPV video was in black & white, which it was after I wrecked the Immersion, so I ordered a new camera. The Cricket is pretty solid, and very small.
I took it out for a test flight last week, and just as I was landing, it flipped. I thought I had a bad motor, so I ordered a new one. Motor sputtered like crazy, so I ordered a new ESC, WITHOUT checking solder connections. Come to find out 2 of the connectors on the motor side of the ESC went bad, so I resoldered and it works good now. Going to keep the new ESC as a spare.
Will hopefully be able to fly it next week, supposed to be in the teens or lower until Tuesday...
Link to the crash video, not too dramatic...
Old Feb 11, 2016, 10:11 PM
Cyberdactyl is online now
Find More Posts by Cyberdactyl
Misfit Multirotor Monkey
Cyberdactyl's Avatar
United States, NC, Garner
Joined Mar 2011
Those are some healthy motors you have there. 800kv?
You could do 4S and 1045's I would guess.
Cyberdactyl is online now Find More Posts by Cyberdactyl
Old Feb 11, 2016, 10:24 PM
kenjancef's Avatar
Joined Nov 2015
Those are some healthy motors you have there. What kv are they?
SunnySky 2216-12 800kV. They sound WAY different than the motors I'm used to on my Phantom... lol... They make the quad shake a little when they power up.
Old Feb 11, 2016, 10:27 PM
Joined Mar 2011
Ahh yes, I found your list a few pages back.
Old Feb 11, 2016, 10:38 PM
kenjancef's Avatar
Joined Nov 2015
No worries... having so much fun learning about how all this stuff works. And also reading this forum seeing all of the other builds. I think I'm finally at the end of the build, just tweaking some things, maybe trying to get my GoPro lower to get the props out of the video... but electronics-wise I think I'm all set...
Old Feb 12, 2016, 01:01 AM
Jasper Q is online now
Find More Posts by Jasper Q
event horizon
United States, FL, Lighthouse Point
Joined Oct 2014
After talking with frame designer he has added some upgrades to the design. The first frame was printed for 6 mm motors and all I had was 8.5's which is what it really needs anyway. I opened up the motor mount holes to 8.5 mm which removed the built in LG. The foam blocks work OK but the EPP takes a set pretty easy and they start falling out. The new design has better cooling and 360 protection at the bottom to protect those delicate motor leads.
http://www.thingiverse.com/thing:1328626
Jasper Q is online now Find More Posts by Jasper Q
Old Feb 12, 2016, 02:44 AM
newtoon is offline
Find More Posts by newtoon
Joined Nov 2013
Originally Posted by speedactyl View Post
Very funny. I was thinking of making a dragonquad as well.
I found your video some posts ago. Very cool, the opening mouth. Make it blow some powder and it would be perfect !
Btw, this is my Evinrude.
http://i.imgur.com/sfoObOM.jpg
Evinrude (0 min 4 sec)
newtoon is offline Find More Posts by newtoon
Discussion Show Us your US Navy Ship ! Chophop Life, The Universe, and Politics 89 Dec 29, 2015 02:33 AM
Discussion Show us your favorite hi-res FPV video compuatic FPV Talk 10 Jan 04, 2015 02:38 AM
Discussion Show us your workshop bazman The Builders Workshop 41 Jul 21, 2014 11:16 PM
Discussion Show us your RC orders! Lets see how much we spend :O Koo Electric Plane Talk 53 Jul 15, 2014 06:42 PM
Discussion Show Us Your Hoverthings FPV Frame scrape Multirotor Talk 2149 Apr 18, 2014 06:06 PM
