Old Jan 25, 2016, 11:58 AM
arcticflyer is offline
Find More Posts by arcticflyer
arcticflyer's Avatar
Canada, SK, Prince Albert
Joined Jan 2006
Nice install ED...looking forward to seeing it fly!
arcticflyer is offline Find More Posts by arcticflyer
Old Feb 03, 2016, 10:33 PM
Edhs is offline
Find More Posts by Edhs
Edhs's Avatar
the seventh planet
Joined Dec 2010
I suspect that every Sunracer owner has been at this point.
I hate the pod.
Cant get to cg even after adding a heatsink!
Edhs is offline Find More Posts by Edhs
Old Feb 04, 2016, 02:33 PM
Edhs is offline
Edhs's Avatar
the seventh planet
Joined Dec 2010
After getting some sleep and re organizing the esc further forward allowing the battery to move forward im at 47mm CG. I think a little adjustment and ill be on the recommended 45mm mark without weight. 23oz all up with 7oz 3s 2200mA battery for initial flights. Plan is to use 4s 1800's that do fit and hopefully will still be able to get into CG range.
Still hopeful that I will be able to plug in nosecone and fly without wing removal each flight. Its tight back there!
Old Feb 19, 2016, 02:55 PM
Edhs is offline
Edhs's Avatar
the seventh planet
Joined Dec 2010
Just two flights in really loving this bird. Second flight today was very enjoyable. Fast, stable and very smooth at speed. Only issue is the prop was windmilling. Have to check the settings.
Question SunRacer II Questions/build pics TaSaJaRa High Performance 481 Jun 20, 2014 01:39 AM
New Product New Sunracer V3 n-2-stuff High Performance 6 Aug 19, 2010 10:58 PM
Poll Build Off III: What to build??? W@CC0 Scale Kit/Scratch Built 17 Sep 11, 2008 07:51 AM
Sunracer Build Questions nrthwing High Performance 8 Nov 27, 2005 06:56 AM
Sunracer build questions jimlang High Performance 4 Oct 21, 2005 02:22 PM
