Electrolyte 40mm Composite EDF Micro Jet
100MPH Micro Jet!
One of the Fastest Micro Jets Around
HobbyKing has released an ARF version of the famous micro jet developed by DR. Bret Becker whose prototype was the first micro jet to fly faster than 100MPH. That airplane is currently on display at the AMA Museum so you know it is something special. Now you can own one. Dr. Becker worked closely with the design team on both the airframe as well as the power plant to make sure this is one adrenaline filled aircraft.
The Electrolyte has a fiberglass pre-painted fuse and balsa construction for the wings and tail section. There are actually two different vertical fins included so you can choose the look or style you like best. It also comes with an 8 blade impeller and aluminum fan housing along with a Dr. MadThrust 40mm 8000kv EDF motor to give you those mind boggling speeds. They do recommend a bungee launch to get the plane into the air and even included a mini bungee kit in the box, awesome! This is an ARF kit so a lot of the assembly work is already done, but you will need some modeling skills, radio gear, supplies, ESC, battery and tools to finish it off.
The Electrolyte ARF is available right now at HobbyKing's East Warehouse for around $100.
Specifications:
  • Wingspan: 508mm
  • Length: 533mm
  • Weight: 210g (w/o electronics)
  • EDF Unit: Dr. MadThrust 40mm EDF w/8000kv Motor
Old Feb 12, 2015, 09:37 AM
HaventFlownSince2014 is offline
Find More Posts by HaventFlownSince2014
DFC~ We Do Flyin' Right
HaventFlownSince2014's Avatar
USA, GA, Atlanta
Joined Nov 2008
That is probably the most appealing micro arf I have seen, very tempting!
...price has been bumped since you posted and is now $102
HaventFlownSince2014 is offline Find More Posts by HaventFlownSince2014
Latest blog entry: Giant 66% Cub
Old Feb 12, 2015, 09:50 AM
Eskimo2k is offline
Find More Posts by Eskimo2k
Joined Nov 2002
A 20" wingspan plane that goes 100mph? Better figure out a way to FPV this thing because it's going to be out of sight in less than a second.
Eskimo2k is offline Find More Posts by Eskimo2k
Old Feb 12, 2015, 11:02 AM
edge_pilot is offline
Find More Posts by edge_pilot
From a Different Planet!
edge_pilot's Avatar
Lagrange, Ohio
Joined Jun 2005
It was to tempting, mine is ordered. If you hesitate long enough on the page you will get it for $95.
edge_pilot is offline Find More Posts by edge_pilot
Old Feb 12, 2015, 11:35 AM
derk is offline
Find More Posts by derk
TheyreComingToTakeMeAway!
derk's Avatar
USA, ID, Coeur D'Alene
Joined Dec 2003
I have flown a 12 inch span plane at 96mph, its not too difficult but sometimes you have to have faith that you know what attitude its in when far out.
derk is offline Find More Posts by derk
Old Feb 12, 2015, 02:43 PM
pdawg is online now
Find More Posts by pdawg
Need 4 Speed!
pdawg's Avatar
United States, OH, Dayton
Joined Apr 2004
Jason,
A lot has happened since we met a few years ago in Nashville! Thank you for the wonderful write up! Hope you get try one for yourself sometime...I think you'll like it.
pdawg is online now Find More Posts by pdawg
Latest blog entry: Visiting Edwards AFB
Old Feb 12, 2015, 03:51 PM
nighthawk0077 is offline
Find More Posts by nighthawk0077
Joined Oct 2009
It was on sale last week for $80,
nighthawk0077 is offline Find More Posts by nighthawk0077
Old Feb 12, 2015, 03:59 PM
pavlis is offline
Find More Posts by pavlis
Joined Feb 2013
I actually achieved 100mph with two 50mm foamies. Amx and f-16
pavlis is offline Find More Posts by pavlis
Old Feb 12, 2015, 04:30 PM
Jason Cole is online now
Find More Posts by Jason Cole
RCG Staff Member
Jason Cole's Avatar
United States, TN, Nashville
Joined Oct 2003
Originally Posted by pdawg View Post
Jason,
Love it! Glad to see your creation out on the market.
Jason Cole is online now Find More Posts by Jason Cole
Administrator
Old Feb 12, 2015, 05:31 PM
edge_pilot's Avatar
Lagrange, Ohio
Joined Jun 2005
That would have been bad...............................then I would have bought 2.
Old Feb 13, 2015, 01:43 PM
Little Cow is offline
Find More Posts by Little Cow
Joined Feb 2014
subbed
Little Cow is offline Find More Posts by Little Cow
Old Feb 13, 2015, 04:10 PM
theKM is offline
Find More Posts by theKM
↓↘→ + (punch)
theKM's Avatar
central PA.
Joined Sep 2004
don't think that anyone who was following the development of these and the micro pylon racers will pass one up... was a fun set of threads to follow.
theKM is offline Find More Posts by theKM
Old Feb 14, 2015, 10:24 PM
KCinNC is offline
Find More Posts by KCinNC
that's gonna leave a scar
KCinNC's Avatar
United States, NC, Mooresville
Joined Aug 2007
I get my little Screamer around 100mph (4S)....easy peasy
I do like the aspect of a fiberglass fuselage on a micro edf though ....
KCinNC is offline Find More Posts by KCinNC
Old Feb 16, 2015, 11:40 AM
seeingeyegod is online now
Find More Posts by seeingeyegod
seeingeyegod's Avatar
United States, OR, Portland
that looks like it would be very very very easy to lose orientation on. Small plane, similar colors and shapes on top and bottom and all (at 100mph)
seeingeyegod is online now Find More Posts by seeingeyegod
Build Log Composite 40mm bandit (like electrolyte) jahel Micro EDF Jets and Power Systems 34 Dec 15, 2012 08:22 PM
Wanted Axon Micro F4 Phantom II 30mm/40mm EDF Jet John Boy Aircraft - Electric - Jets (FS/W) 0 Jan 23, 2012 09:31 PM
Discussion Axon Micro F4 Phantom II 30mm/40mm EDF Jet metroidrc Micro EDF Jets and Power Systems 544 May 15, 2011 03:03 PM
Video 375W edf 40mm electrolyte dopler passes corsair nut Electric Plane Talk 12 Feb 02, 2011 10:32 AM
