Old Apr 05, 2014, 04:51 PM
Against Helicopter Cruelty
Heli Pad's Avatar
Joined Aug 2011
Heli Pad Review Series: SYMA F4 3CH Helicopter
SYMA is well known in the RC helicopter toy segment, especially with its unmatched success found in the S107G 3 channel coaxial helicopter. Many RC hobbyists, including myself, were introduced to this industry with the S107G. There is no doubt in anyone’s mind that the S107G coaxial helicopter was a great design. But it does have its limitations. For starter, Infra-Red (IR) control doesn’t work around strong light sources and has very limited range. Secondly, the S107G is built for stability, not for speed. If you are looking for something that could fly outside and have decent range, you need something with cyclic authority from a swash plate, and range from a 2.4GHz. And those are the exact step-up features that this SYMA F4 brings.
The new SYMA F4 is a 3 channel Single Rotor (SR) Fixed Pitched (FP) with FlyBar (FB), Swash Plate, and a 2.4GHz wide spectrum radio control. Once a rookie pilot has mastered the S107G, what is next? This SYMA F4 could be a good next step, but it is not the only option. Some would go one more step to a 4CH SR FP with FB like a WL V911-Pro, SYMA F3 or a 4CH Quadcopter like a SYMA X1.
What is in the Package?
The SYMA F4 kit comes with everything you need to fly except for the 4AA batteries that you need to provide:
• 1x SYMA F4 helicopter
• 1x 2.4GHz Transmitter (Tx)
• 1x 3.7v 150mAh Lipo Battery
• 2x Spare Main Blades
• 1x Spare Tail Rotor
• 1x Blade Grip
• 1x USB Charging Cable
• 1x Screw Driver
• 1x Instruction Manual
First Impressions
Right out of the box, the high built quality of SYMA is evident. The SYMA F4 is very well built. The tail stabilizers immediately remind you of the S107G heritage. The Lipo is hidden inside the canopy for a super clean look. But instead of an on/off switch, the battery has long leads and a plug that resembles the hobby grade stuff. From the swash plate up, the linkages, fixed pitch blades and fly bar on top reminds you of the Solo Pro or V911 setup. However, unlike most 4CH helicopters that have a flimsy flexible main frame, the SYMA F4 sports a strong, rigid corpus with side frame panels – just like the S107G. It offers the strongest, most durable main frame and landing skids I have seen in this class. It as a bright front LED light that helps night missions and orientation. The canopy has very nice matte paint and lines. No tool is required to remove the canopy or to snap it back tightly onto the frame. Once the canopy is removed, the Lipo is revealed and it can be swapped easily if you have additional Lipos. The SYMA F4 comes in two color choices, Red or Black. I got the Red, which I think is easier on the eyes. All that for under $30, what a bargain!
How does it Fly?
SYMA is famous for building easy to fly, stable aircraft. The F4 is no exception. It hovers hands-free right out of the box. Absolutely no trimming is necessary. Hovering is just rock solid. The 3 channel 2.4GHz radio has the Xbox look and feel. The controls are exactly like the other 3 channel Tx, which are arranged in a Mode 4 configuration – throttle is on the left stick by itself; the right stick controls the turns (rudder) and the forward/back (elevator) movements. Throttle is a lot more responsive than the coaxial. Fast Forward Flight (FFF) is way livelier than the S107G.
What about the 3rd channel? How does it turn? Well, this is where it becomes problematic and challenging, at least for me because I am so used to flying 4 channels. The absence of the aileron control is a bigger loss than I could imagine.
If you are familiar with flying coaxial helicopters, you would appreciate how easy it is to turn your helicopter. The main reason is the completely symmetrical design of the coaxial. Everything is completely balanced. Turning is accomplished by slightly varying the speeds of the upper and lower blades, and the helicopter turns around the main shaft – no problem. However, in a SR helicopter, it is everything but symmetrical. The rotors turn one way and the reactive force turns the body the opposite way, only to be countered by a side pushing tail rotors. To turn the helicopter, you increase or decrease the speed of the tail rotor, but instead of just turning the helicopter nicely about its main shaft, it pushes the helicopter sideways. If you have aileron control, it will be your second nature to compensate. But with the absence of the aileron control, the helicopter just slides hopelessly.
Perhaps, I have been flying 4 channel helicopters too long and my muscle memory is playing tricks on me. Flying the F4 in Mode 4 and missing the 4th channel was a bit difficult for me. Otherwise, the SYMA F4 is a great machine.
Where to Buy?
The SYMA F4 is available through a number of sellers for about $30-40. Shipping costs and time vary. But the lowest shipped price is from Banggood.com:
SYMA F4 3CH SR Helicopter RTF
Pros
• Low price
• Excellent built quality
• Durable parts
• Easy transition from 3 channel coaxial
• 2.4GHz control for range
• Fish-Eye swash plate
• Swappable Lipo
Cons
• Unknown transmission protocol, not compatible with any hobby grade radio
• No aileron control
• Heavy (38.4g)
Summary
Its affordable low cost and its excellent built quality make it a highly desirable upgrade from a 3 channel coaxial toy helicopter. The control configuration is the same, so there is nothing new to learn. The added FFF authority and radio control range allow it to be flown outside, by day and by night. What fun!
The SYMA F4 is a great step up from coaxial, and a good stepping stone to the 4 Channel varieties. However, if 4 Channel is a foreseeable goal, you may want to spend more and skip the intermediate step. Jump right up to the SYMA F3 or the WL V911-Pro, both are 4 Channels of the same size class. They will teach you how to fly 4 Channels in the popular Mode 2 configuration. If you are more ambitious and want to do some stunt flipping, you might skip to the SYMA X1.
Photo Gallery
Heli Pad is offline Find More Posts by Heli Pad
Heli Pad's Avatar
Joined Aug 2011
SYMA F4 Parts List. Click on image or link to teleport to order page.
SYMA F4 RTF Kit
SYMA F4 Canopy
SYMA F4 Tail Fins
SYMA F4 Main Blades
SYMA F4 Tail Rotor
SYMA F4 Flybar
SYMA F4 Landing Skids
SYMA F4 Main Motor
SYMA F4 Lipo
Old Apr 05, 2014, 04:53 PM
Heli Pad's Avatar
Joined Aug 2011
Frequently Asked Questions
Q: How do I adjust the servo links?
A: Check out this post #10
Heli Pad's Avatar
Joined Aug 2011
Reserved for Mods and Troubleshooting
Old Apr 06, 2014, 02:08 AM
Team WarpSquad
Daryoon's Avatar
San Diego, CA
Joined Dec 2010
Cool. Lots of pictures of the F4.
Good job with the write up. I agree with all your points.
Daryoon is offline Find More Posts by Daryoon
Old Apr 07, 2014, 12:19 PM
Heliski: Steep 'n deep
Snow Lynx's Avatar
United Kingdom, England, Manchester
Joined Jul 2011
Thanks for another great review HP and plenty of detailed pictures.
Snow Lynx is offline Find More Posts by Snow Lynx
Old Apr 14, 2014, 10:59 AM
Norfolk, England
Joined Sep 2001
Just bought one of these and first impressions are very promising - it can be flown in our small lounge relatively easily. However, maybe sombody knows if the transmitter trims actually work for forwards/backwards trim. The instructions say adjust the linkage, but there are trims there that sound as if they ought to be doing something - they bleep when pressed.
It flies nicely, but wants to go backwards all the time. I just don't want to start messing with linkages if I don't have to.
Any help much appreciated.
Pete
PETERRAKE is offline Find More Posts by PETERRAKE
Old Apr 14, 2014, 01:17 PM
SeByDocKy's Avatar
France, PACA, La Valette-du-Var
Joined Dec 2012
Did you tried to bind it with the "SYMA X2" protocol with deviationTX ?
SeByDocKy is online now Find More Posts by SeByDocKy
Old Apr 14, 2014, 01:48 PM
Norfolk, England
Joined Sep 2001
Sorry, was that aimed at me, or just a general question? If aimed at me I'm afraid it went straight over my head.
Pete
Old Apr 14, 2014, 02:32 PM
Heli Pad's Avatar
Joined Aug 2011
Pete
Peter,
The trim buttons are for Rudder Left/Right only. That is, if the helicopter is not holding the heading properly, you could adjust the trim. But it does not affect the Elevator, which controls the forward/backward movements.
Yes, I agree with you that the F4 seems a tad tail heavy and has a small tendency to drift backward. I assume that each unit could be slightly different. YMMV.
Yes, to adjust the forward/backward trim, you'd need to adjust the linkage. It is not as scary as it sounds. There are two linkages (with metal rods and screw threads at the end). The left one is fixed to the frame. It controls the aileron of the swashplate. So, if your helicopter is not drifting side to side, leave it alone. The right linkage is attached to the servo (white, motorized). If your helicopter is drifting backwards, you'd want to SHORTEN that linkage. So, you simple pop it out of the ball joint from the swashplate arm. Give the end of the linkage with the eye one full turn CLOCKWISE. Reattach the linkage to the swashplate arm. That's it.
Now test fly the helicopter. If it stops drifting you're done! If it is still drifting back a little, repeat the process. If it is drifting forward (and you don't like it), back it out half a turn.
Old Apr 14, 2014, 02:34 PM
Heli Pad's Avatar
Joined Aug 2011
SBD, My Devo is in the lab for some upgrade. I don't have it with me, and I haven't yet loaded SYMA X2 protocol on it, yet.
But I did try to use the X3 Tx to bind to the F4 and it was no go. So, I doubt very much that the SYMA X2 protocol will bind with this F4, which is very annoying. The F3 uses FlySky.
Old Apr 14, 2014, 08:00 PM
Norfolk, England
Joined Sep 2001
Thanks, that's what I thought you might say. It just seems strange to have those top two trims sound as if they do something without really working anything. The 9113 is much nicer, but almost twice the price so I suppose it's fair enough. I think I can probably manage to adjust a pushrod length.
Thanks again,
Pete
Old Apr 14, 2014, 08:16 PM
Heli Pad's Avatar
Joined Aug 2011
Peter, do give that mechanical trim a try. It is fairly easy to do, takes less than a minute to do and it's usually a one-time adjustment before you have perfectly balanced helicopter.
By 9113, do you mean the Double Horse 9113 Cobra? I'm not familiar with it. But from the pictures I found, it has a "Blade" look alike Tx with more trim buttons on it. Those trims are electronic trims. They just "biased" the control that is sending from the Tx. It is more convenient.
But for a good swash setup, these trim adjustments are not something that needs to be done frequent. So, it is not a big deal.
Old Apr 15, 2014, 05:10 AM
Norfolk, England
Joined Sep 2001
Yep, the Cobra, a nice flying heli that really picks up speed in forward moving turns.
Anyway, after a few adjustments the F4 no longer permanently wants to fly backwards. When you turn it it moves forward immediately after, then drifts back a little before settling into a reasonable hover. For around 17 ($25?) I'm more than happy with it. Around the same price as an IR co-axial but 2.4 gig and much more sprightly. As long as you accept it isn't going to fly quite like a 4 channel FP heli it represents great value - if only I'd stop trying to steer it with a stick not connected to anything.
Thanks for all the help, it is much appreciated.
Pete
Old Apr 15, 2014, 11:15 AM
Heli Pad's Avatar
Joined Aug 2011
Peter, I think you are exactly right about the F4. It is priced cheaply as a 3 CH SR FP helicopter, not much more than what you'd pay for a coaxial. Surely, it cannot match up with a 4 CH helicopter. But you are not paying for one either. If your expectation is misplaced, you will be sorely disappointed with the lack of the 4th channel. But if your expectation is set accordingly, then the F4 is a great helicopter for what you're paying for.
Discussion Heli Pad Review Series: WL-Toys V911-Pro Heli Pad Micro Helis 349 Feb 20, 2015 02:39 PM
Discussion Heli Pad Review Series: SYMA X3 Quadcopter Review Heli Pad Mini Multirotors 120 Feb 18, 2015 04:20 AM
Discussion Heli Pad Review Series: SJ991 3CH IR Coaxial with Programmable LED Messages Heli Pad Coaxial Helicopters 39 Apr 24, 2014 08:07 PM
New Product Heli Pad Review Series: SYMA S107N 3CH Helicopter w/ GYRO and IR remote Heli Pad Coaxial Helicopters 259 Mar 04, 2014 01:22 PM
Discussion Heli Pad Review Series: SYMA S5 Heli Pad Coaxial Helicopters 11 Jan 05, 2014 04:34 PM
