Old Feb 25, 2015, 03:29 PM
FPV Addict
SlipstreamFPV's Avatar
United States, CA
Joined Nov 2012
Should be fine with 1.3 and 5.8.
SlipstreamFPV is offline Find More Posts by SlipstreamFPV
Old Feb 26, 2015, 02:53 AM
United States, CA, Orange County
Joined Apr 2013
What is the top part of the rear canopy clips that protrudes up through the canopy for? Like the ones shown in this post:
http://www.rcgroups.com/forums/showp...postcount=5060
thehelidude is online now Find More Posts by thehelidude
Old Feb 26, 2015, 03:43 AM
giteart's Avatar
Greece, Attica, Ellinikon
Joined Jan 2014
It helps pulling them and take the canopy off. On the bottom those clips, clip to the carbon spar and hold the canopy in place
giteart is offline Find More Posts by giteart
Old Yesterday, 03:09 PM
Lorte hobby
Booner74's Avatar
Denmark, Central Denmark Region, Hornslet
Joined Jan 2013
Hey guys,
What servo arms do you use for the Hitech HS-82MG? The servoes didn't come with standard type.
Booner74 is online now Find More Posts by Booner74
Old Yesterday, 11:27 PM
Fly safe & help preserve FPV!!
melsailsnorth's Avatar
United States, CA, Chico
Joined Dec 2010
Originally Posted by Booner74 View Post
Hey guys,
Hey there Booner,
If yours didn't come with the singles, I would just take one of the double arms and cut one side off with a pair of wire cutters. You want to use a reasonably small arm on the servo side because otherwise your mech. throw might be too much for most autopilots. If your putting new servos in, have you considered reversing them so that they are on the top of the wing instead of the bottom? That's a really nice mod. and it really helps preserve your servos and linkages and keeps them from getting hung-up on brush, rocks, etc. on skid landings. I learned the hard way on that one Then again, I land in some pretty nasty terrain half the time. I'm amazed I've somehow preserved that joke of a motor mount!!
melsailsnorth is offline Find More Posts by melsailsnorth
Old Today, 05:52 AM
f2001m's Avatar
Joined Feb 2012
Originally Posted by f2001m View Post
I need a little help.
I am ruining APM 2.5 on my FX-61 , every thing work correctly except one thing i cant figure out what is the problem
If raise throttle up motor start spinning but once i toggle to any flight mode motor stop spinning except Manual mode and Low rotate on STAB mode!!!!
I have reload FW several time and all perimeter stock setting.
Any idea?
Thanks to all of guys finally i got it to work, i found where was issue
I have to enable these two
THR_PASS_STAB
THR_SUPP_MAN
Tested today work great. But one thing i have notice
Is it normal if it is in RTH mode if i move throttle control on stick no effect on FC? I tried to move throttle all the way down and up while in RTH not effect throttle.
f2001m is online now Find More Posts by f2001m
Old Today, 06:00 AM
Joined Sep 2009
THR_PASS_STAB
THR_SUPP_MAN
During RTH and some other auto modes the APM controls the throttle.
billhally is offline Find More Posts by billhally
Old Today, 06:39 AM
f2001m's Avatar
Joined Feb 2012
Thanks mate.
Old Today, 06:39 AM
Feivel's Avatar
Joined Jul 2013
It achieves alt and speed which is configured at the mp.
Feivel is offline Find More Posts by Feivel
Old Today, 03:42 PM
Seattle, WA - USA
mark_q's Avatar
Joined Sep 2003
Hey guys,
What Mel says
Also, Hitec makes some swoopy blue aluminum arms that are standard on their higher end servos and you can buy them separetly from Hitec and other places. They are ~30mm from the servo center to the farthest hole center, very light and way strong. Below is a picture of one of these on a Hitec HS82mg (on my talon )
Cheers - Mark
mark_q is online now Find More Posts by mark_q
Old Today, 05:17 PM
Lorte hobby
Booner74's Avatar
Joined Jan 2013
Originally Posted by melsailsnorth View Post
Hey there Booner,
Thank you for great input and help
Old Today, 05:18 PM
Lorte hobby
Booner74's Avatar
Joined Jan 2013
Originally Posted by mark_q View Post
What Mel says
Cheers - Mark
Hi Mark,
That looks really great. Do you have a parts number or link, so I am sure to get the right ones?
New Product NEW flying wings from HObbyking - good for FPV ? i3dm FPV Talk 15 Apr 11, 2014 09:08 PM
Discussion Starting FPV with a flying wing? JYVAI UAV - Unmanned Aerial Vehicles 3 Mar 23, 2014 10:49 PM
Discussion The Fury Flyer- 54" Scratch build FPV Flying Wing Bixler13 FPV Talk 7 Mar 11, 2013 12:00 AM
Help! As3x and flying wing airplanes Jyester Scratchbuilt Indoor and Micro Models 17 Jan 22, 2013 09:29 PM
Discussion HobbyKing - Fox 2.32m EPO Glider for FPV Cralis FPV Talk 19 Sep 14, 2011 04:24 AM
