Old Jun 15, 2015, 06:18 PM
boilo56 is offline
Find More Posts by boilo56
Joined Jun 2015
My FT009 don't work, please help!
I have a bran new FT009 that i bought this winter. i did not ran the boat yet. My problem is when i turn the boat on, nothing happens. i search youtube and i found this video that shows the same problem i have. Please, help me solve this, my little boy would be very happy to play with it.
Thank you for your help!
FT009 reciver/transmiter Not working (1 min 7 sec)
boilo56 is offline Find More Posts by boilo56
Old Jun 16, 2015, 09:57 AM
ApexpretadorGT is offline
Find More Posts by ApexpretadorGT
United States, FL, Fort Lauderdale
Joined Nov 2014
Try binding the transmitter again
ApexpretadorGT is offline Find More Posts by ApexpretadorGT
Old Jun 16, 2015, 04:51 PM
boilo56 is offline
Joined Jun 2015
I would, but i don't have the manual with me, and i never did this with that boat. Do you know how to do it? It would help a lot!
Thank you!
Old Jun 16, 2015, 07:55 PM
boilo56 is offline
Joined Jun 2015
Ok, i figured out how to bind the boat and tx, but now the motor works and the steering doesn't. When i use the steering trim, the servo works fine, but nothing happens when i turn the steering. Does anybody know what is happening?
Thank you!
Old Jun 16, 2015, 09:08 PM
Joined Nov 2014
Strange. When you trim the servo works but doesn't work when you try to steer? I don't have an ft009 boat I wish I could hold the transmitter and see if it's something on there you can adjust. It could be something is off on the tx maybe too much trim or you have the channels plugged in back wards. Servo is typically channel 1 and motor is channel 2, try checking that
Make sure the servo leads are plugged in properly into the rx.
Old Jun 16, 2015, 09:20 PM
Goodwrench is offline
Find More Posts by Goodwrench
Goodwrench's Avatar
Canada, NS, Blockhouse
Joined May 2014
Thank you!
Did you get this issue solved? I'm having the same problem. I can't even get it to bind.
Goodwrench is offline Find More Posts by Goodwrench
Old Jun 16, 2015, 11:33 PM
Maximuss Actual is offline
Find More Posts by Maximuss Actual
Joined Feb 2011
FT Boats will not work
FT series boats will not work out of the water. The boat has to be actually in the water for the circuit to be made to make it operate. Safety device.
Maximuss Actual is offline Find More Posts by Maximuss Actual
Old Jun 17, 2015, 02:25 PM
boilo56 is offline
Joined Jun 2015
Thanks, i already know that. I bypassed the safety.
Old Jun 17, 2015, 02:28 PM
boilo56 is offline
Joined Jun 2015
I managed to bind by leaving the tx on, and plugging and unplugging about 10 times. You need to do this fast.
Old Jun 17, 2015, 03:08 PM
boilo56 is offline
Joined Jun 2015
I found the problem!!! The problem was a bad contact in the Steering switch, in the tx. I just changed the 3 wires and everything work just fine!!!
Question Help My Syma x5c Videos won't work!! JohnPop Multirotor Talk 3 May 08, 2015 11:37 PM
Discussion Naza X1 and my slider don't seem to work correctly Troiano27 Multirotor Electronics 1 Dec 14, 2013 12:43 AM
Question Help! Why don't all my servos work? expo Power Systems 5 Nov 30, 2006 11:26 PM
Help, my Pixi 20P and throttle don't work! LexTalionis Power Systems 19 May 26, 2004 10:40 PM
