Old Jun 11, 2015, 06:32 AM
Ib Jensen is offline
Find More Posts by Ib Jensen
Ib Jensen's Avatar
Forest Lake, Minnesota
Joined Apr 2003
Hollow Stainless poshrod source needed
I have a number od performance ships that have to have their pushrods replaced. The originals are hollow thin wall stainless in plastic sleeve or running through well spaced supports.
Any one have a source for these?
Ib Jensen is offline Find More Posts by Ib Jensen
Old Jun 11, 2015, 06:48 AM
jcpatrick is offline
Find More Posts by jcpatrick
Jim C Patrick
jcpatrick's Avatar
Shenandoah County
Component Supply will have it, but why don't you switch to the stronger and lighter carbon fiber?
jcpatrick is offline Find More Posts by jcpatrick
Old Jun 11, 2015, 09:15 AM
Ib Jensen's Avatar
Joined Apr 2003
I may need to do that. I have not yet used carbon as a direct replacement for the SS tube pushrods. I have repaired a broken boom and the existing SS tube was damaged so it seemed that sliding in a replacement of the same type might be the best. I will have to order the carbon anyway since the local hobby shop had stoped carrying anything usefull. Just ARFS and nyrods.
Thanks.
Old Jun 11, 2015, 04:25 PM
Lou is offline
Lou
Find More Posts by Lou
Lou
Ground Penetration Tester
United States, VA, Waynesboro
Joined Dec 2005
Nice link to bookmark. A bit OT but what are the comparisons between aluminum pushrods and CF? Any benefit to using aluminum?
Lou is offline Find More Posts by Lou
Old Jun 11, 2015, 07:43 PM
Jim C Patrick
jcpatrick's Avatar
Shenandoah County
Unlike most other uses (cars, bikes, etc) uni-directional CF as a pushrod is a near-perfect use of CF's best abilities. Aluminum could compete with CF on a strength-to-weight comparison; it's a bit heavier but very close.
The killer for aluminum is it's thermal expansion. CF has negligible expansion in the 30-120 F temperature range.
Old Jun 12, 2015, 06:58 AM
Al M is offline
Find More Posts by Al M
Wallingford, Ct
Joined Sep 2001
But the planes structure's expansion might not be negligible.
Al M is offline Find More Posts by Al M
Discussion Cheerson cx20 open source needs help Tkhoang0219 Multirotor Electronics 1 Jun 02, 2015 11:37 AM
New Product 1" Hollow Aluminum & Stainless Steel Tubing ServoCity ServoCity.com 0 Oct 10, 2012 09:43 AM
Hummer Hollow Stainless Mainshafts kdill2160 Micro Helis 16 Apr 21, 2003 11:56 AM
Hummer Hollow Stainless Mainshafts kdill2160 Aircraft - Electric - Airplanes (FS/W) 1 Apr 18, 2003 07:33 AM
Source for Stainless Steel hollow Shafts? Jim McPherson Electric Plane Talk 4 Apr 30, 2002 01:36 PM
